HMG 2.8.6f 'control order' window error
There is a small issue in the 'Control Order' window with the following errorlog:
Harbour MiniGui Errorlog File
Date:2009.05.28 Time: 18:22:36
Error BASE/1132 Bound error: array access
Called from UP(28098)
Called from (b)EDITTABORDER(27733)
Called from _DOCONTROLEVENTPROCEDURE(4680)
Called from EVENTS(1360)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4344)
Called from EDITTABORDER(27757)
Called from (b)MAIN(1061)
Called from _ACTIVATEWINDOW(4368)
Called from DOMETHOD(7224)
Called from OPEN(25801)
Called from EDITFILE(29692)
Called from (b)MAIN(1189)
Called from EVENTS(1553)
Called from _ACTIVATEWINDOW(4322)
Called from MAIN(1297)
How to reproduce:
1. open project in folder samples\hello
2. open form hello.fmg on tab 'Forms'
3. open 'Control Order' window by press an appropriate button on buttonbar
4. press 'Control Up' button in aboved window and you have a progam error :arrow:
Re: HMG 2.8.6f 'control order' window error
gfilatov wrote:There is a small issue in the 'Control Order' window with the following errorlog:
How to reproduce:
Thanks for reporting.
I'll review it ASAP.
