problem with IDE 2.8.6f
I've reached strange problem with IDE 2.8.6.f
I have installed hmg 2.9.1 in c:\hmg - I've checked time and date of files - all libs has 2009.05.10
But, while compiling project with IDE, an error occurs:
and IDE is out.
But, compiled EXE file is built and works good!
And, internal signature of HMG in .exe file points on HMG 2.9.1
(I've deleted all previous HMG from disk, so it's not possible to reach 2.8.9 version)
What's going on?
Re: problem with IDE 2.8.6f
After few compilations, IDE generated .exe file and still lives!!!
Very strange :lol:
mol wrote:I've reached strange problem with IDE 2.8.6.f
and IDE is out.
What's going on?
The version of IDE that you are using are compile with 2.8.9.
As the fatal error is in IDE, the HMG version shown is 2.8.9.
I could be more helpful on this if you give some clue about how to reproduce the problem.
TIA.
And...
Had you edited the form code with an external text editor?
When the first time of error occus, I'm sure that I didn't use any external editor to edit form code - I've copied my project from one computer to second via pendrive.
Second occurance of error - I've use editor to edit main window to duplicate two lines in Main Menu of form - error occured.
Now, I've saved main form from IDE and everythink is OK.
I think, errors was linked with editing forms...
Best regards, Marek
mol wrote:When the first time of error occus, I'm sure that I didn't use any external editor to edit form code - I've copied my project from one computer to second via pendrive.
Best regards, Marek
Ok.
I've not documented clearly the fact that reading 'by hand-edited' forms could produce unexpected results and is not guaranteed to work.
I'll remedy in the next release.
Error occurs after successful compilation - so everything inf form is OK, I think.
Maybe my editor (I use notepad++) puts some extra characters?
I've tried edit form by notepad++ and incremental compiling - it's OK.
But resetting incremental compiling and full building crashes IDE.
