Grid Sort (Function / Method)
Source code related resources
Another little thing I've added to my personal library to easy my work: It is a grid sort utility.
I've created as a function but could be added to DoMethod().
SortGrid Function:
PROCEDURE SortGrid( cWindow , cGrid , nColumn , cSortAs )
LOCAL L
LOCAL I
LOCAL aGrid := {}
LOCAL J
LOCAL TEMP
	WAIT WINDOW 'Sorting...' NOWAIT
	* nColumn Parameter is Optional. Default is 1
	IF VALTYPE(nColumn) = 'U'
		nColumn := 1
	* cSrotAs parameter is optional. Default is 'C'
	IF VALTYPE(cSortAs) = 'U'
		cSortAs := 'C'
	* Copy the grid content to an array.
	L := GetProperty ( cWindow , cGrid , 'ItemCount' )
	FOR I := 1 TO L
		AADD( aGrid , GetProperty( cWindow , cGrid , 'Item' , I ) )
	NEXT I
	* Then Sort The Array...
	IF	ALLTRIM(UPPER(cSortAs)) == 'C' // Sort As Character
		FOR i=1 TO L
			FOR j=1 TO (L-1)
				IF aGrid[j,nColumn] > aGrid[j+1,nColumn]
					temp = aGrid[j]
					aGrid[j]=aGrid[j+1]
					aGrid[j+1]=temp
			NEXT j
		NEXT i
	ELSEIF	ALLTRIM(UPPER(cSortAs)) == 'N' // Sort As Number
		FOR i=1 TO L
			FOR j=1 TO (L-1)
				IF VAL(aGrid[j,nColumn]) > VAL(aGrid[j+1,nColumn])
					temp = aGrid[j]
					aGrid[j]=aGrid[j+1]
					aGrid[j+1]=temp
			NEXT j
		NEXT i
	ELSEIF	ALLTRIM(UPPER(cSortAs)) == 'D' // Sort As Date
		FOR i=1 TO L
			FOR j=1 TO (L-1)
				IF CTOD(aGrid[j,nColumn]) > CTOD(aGrid[j+1,nColumn])
					temp = aGrid[j]
					aGrid[j]=aGrid[j+1]
					aGrid[j+1]=temp
			NEXT j
		NEXT i
	* Finally, Fill The Grid With The Sorted Array Content...
	DoMethod( cWindow , cGrid , 'DeleteAllItems' )
	FOR I := 1 TO L
		DoMethod( cWindow , cGrid , 'AddItem' , aGrid[I] )
	NEXT I
	* End
	WAIT CLEAR
To use as a Grid method:
Since the 'nColumn' and 'cSortAs' parameters are optional, it should be handled differently according the parameter count:
// Pcount() == 3 // CONTROL
    elseIf     Arg3 == 'SORT'
        SortGrid ( Arg1 , Arg2  )
// Pcount() == 4    // CONTROL WITH 1 ARGUMENT
    ElseIf Arg3 == 'SORT'
        SortGrid ( Arg1 , Arg2 , Arg4 )
// Pcount() == 5 .And. ValType (Arg3) == 'C' // CONTROL WITH 2 ARGUMENTS
        SortGrid ( Arg2 , Arg1 , Arg4 , Arg5 )
I hope this be useful for someone.
Re: Grid Sort (Function / Method)
Very nice, you used "burbuja" as sort method?
I will adapted for Unicode.
srvet_claudio wrote:Very nice, you used "burbuja" as sort method?
Oh Yeah... I like bubble sort!
But if you consider that another method could be more efficient... no problem from my part.
srvet_claudio wrote: I will adapted for Unicode.
Thanks!
My two cents:
1. We can use aSort() function
2. Before we start we can use DisableUpdate and after we finish, use EnableUpdate.
3. Add another parameter to allow ascending/descending order.
What would be the position for a virtually managed grid?
I use ON HEADCLICK to sort a grid on a specific field. Like this:
   ON HEADCLICK { { || Sort_Grid_Tree(1)} , {|| Sort_Grid_Tree(2)}  , { || Sort_Grid_Tree(3)}, { || Sort_Grid_Tree(4)} , { || Sort_Grid_Tree(5)} , {|| Sort_Grid_Tree(6)},  { || Sort_Grid_Tree(7)}  ,  { || Sort_Grid_Tree(8)} ,  { || Sort_Grid_Tree(9)},  { || Sort_Grid_Tree(10)} ,  { || Sort_Grid_Tree(11)}  } ;
So for every field the sort function is called. In the SORT_GRID_TREE some fields need to be sorted as numerics (but displayed as chars).
This is the most unconvenience I found. But overall it works great.
But a default sort would be great!
Rathinagiri wrote:My two cents:
Very good idea!!!
With virtual grid, you have to provide the already sorted data when they are loaded with the query method
serge_girard wrote:Hi,
And... dreaming a little... You could set an arrow icon for the column header clicked, to indicate that it is sorted and switch from ascending to descending when you click it again (changing the icon of course)
I agree with Claudio: Very good ideas.
Regarding virtual grid: ListView requires the data it needs, according the user navigation actions (among other things) so, there is nothing more to do, that assure that the data be sorted when is required to show it.
Hi
Are you about something like this :?:
Viva HMG :D
It seems Esgici did this MANY years ago! Bravo!
