HMG 2.9.2 (Forum test)
Please test and report any problem you found.
- Harbour MiniGUI 2.9.2 Changelog:
	English:
	- Fixed: Print Preview. 'go to page' window not refresh preview window.
	- New: Property style synonyms for the following DEFINE WINDOW command clauses:
		- WindowType (Main/Modal/Child/SpltChild Clauses)
		- Visible (NoShow Clause)
		- AutoRelease (NoAutoRelease Clause)
		- MinButton (NoMinimize Clause)
		- MaxButton (NoMaximize Clause)
		- Sizable (NoSize Clause)
		- SysMenu (NoSysMenu Clause)
		- TitleBar (NoCaption Clause)
		- FontName (Font Clause)
		- FontSize (Size Clause)
		- HelpButton (HelpButton Clause)
		- Break (Break Clause)
		- Focused (Focused Clause)
		- Topmost (Topmost Clause)
Thanks in advance.
hmg292.rar
(386.73 KiB) Downloaded 368 times
Re: HMG 2.9.2 (Forum test)
So, now we have many options. Thanks Roberto.
rathinagiri wrote:So, now we have many options. Thanks Roberto.
The idea is to give to the window definition a 'property style' for all clauses used at definition time, being consistent with controls that have full 'property style' via alternate syntax for all properties.
Vanguarda
Post by Vanguarda »
HI all,
Thanks Master Roberto. Very nice this update...
with best reagrds,
shridhar
Post by shridhar »
Thanks a lot ..! Master.
Roberto,
I want to say about some optimization again :)
How about to change this multiline definition in the i_window.ch
	#xcommand DEFINE WINDOW <w> ;
			[ FONT <FontName> SIZE <FontSize> ] ;
			[ FONTNAME <FontName> FONTSIZE <FontSize> ] ;
with the following one line
			[ <dummy1: FONT, FONTNAME> <FontName> <dummy2: SIZE, FONTSIZE> <FontSize> ] ;
Just my 2 cents... ;)
gfilatov wrote:Roberto,
Thanks!
Roberto Lopez wrote: ... test and report any problem you found.
Hi Maestro
While
MsgBox( "Window Row is : " + LTRIM( STR( ThisWindow.Row ) ) )
and
MsgBox( "Window Row is : " + LTRIM( STR( GetProperty( <cWindowName>, "Row" ) ) ) )
producing correct values;
MsgBox( "Window type is : " + ThisWindow.WindowType )
produced :
Error E0030 Syntax error: "syntax error at '.'"
and
MsgBox(  VALTYPE( GetProperty( <cWindowName>, "WindowType" ) ) )
produced : "U"
Other "property style synonyms" are seeming the same.
Best Regards
Hi Maestro
While
and
produced :
and
produced : "U"
Best Regards
It's an error, but in documentation, since these new properties are available at control definition only and should be tagged with (D) in the documentation.
Properties available at control definition are not available at SetProperty and GetProperty functions nor semi-oop syntax.
I'll fix the documentation.
Thanks for reporting.
Ok. Here it is.
We always had three property types:
D: Available only at control definition
R: Read-Only (*)
W: Write-Only (*)
(*): at runtime only via Getproperty, SetProperty or semi-oop
This had be never properly documented (until now:) )
Properties:
      - Row
      - Col
      - Width
      - Height
      - Title
      - NotifyIcon
      - NotifyTooltip
      - FocusedControl (R)
      - Cursor (W)
      - VirtualWidth (D)
      - VirtualHeight (D)
      - Icon (R)
      - WindowType (Main/Modal/Child/SpltChild/Standard Clauses) (D)
      - Visible (NoShow Clause) (D)
      - AutoRelease (NoAutoRelease Clause) (D)
      - MinButton (NoMinimize Clause)(D)
      - MaxButton (NoMaximize Clause) (D)
      - Sizable (NoSize Clause) (D)
      - SysMenu (NoSysMenu Clause) (D)
      - TitleBar (NoCaption Clause) (D)
      - BackColor (D)
      - FontName (Font Clause) (D)
      - FontSize (Size Clause) (D)
      - HelpButton (HelpButton Clause) (D)
      - GripperText (D)
      - Break (Break Clause) (D)
      - Focused (Focused Clause) (D)
      - Topmost (Topmost Clause) (D)
      - Name (R)
R: Read-Only
W: Write-Only
D: Available at definition only
