Modify mdb files? [EDITED]
EDIT: I've solved. It was a problem with field name (sorry).
HMG includes a demo (samples\hfcl\sql\rdd_sql\demo.prg) That I've adapted from Harbour showing how to read an mdb file.
My problem now, is that I need to modify an mdb file.
Following the MySql demo, I've added the following:
RDDINFO(RDDI_EXECUTE, "DELETE FROM test WHERE last = 'Logan'")
In fact, I've tried lots of variants (including INSERT and UPDATE) with other mdb files and the result is always the same: RDDINFO call returns .F. and table is not affected.
Any ideas?
TIA.
PS: And... by the way... why is this demo located in HFCL foder?
apais
Re: Modify mdb files? [EDITED]
Post by apais »
You could use ADORDD (see harbour group )
Angel Pais
apais
Post by apais »
Found it !
New version of adordd at https://github.com/AHFERREIRA/adordd.git
HTH
Angel
Angel Pais
Hola Roberto haber si te puede servir
mi sample
http://hmgforum.com/viewtopic.php?f=9&t ... 207#p45207
Un cordial saludo
Many thanks to all.
As I've added in the edit note, my problem was a fieldname.
I've been working with a lot of different tools in the last months and I'm making some silly mistakes :)
I'll test ADO too and I'll take a rest this week, I need it :)
Thanks again!
