Grid: Dbf and CHECKBOXENABLED
PiotrM
Post by PiotrM »
Hello
hmg.3.4.3
Based on the example Grid_CheckBoxes did Grid connected with the base dbf and I wanted to use CheckBoxEnabled but it did not work. The first column expands and makes room for the CheckBox but she does not, does not work either event handler ON CHECKBOXCLICKED. Did I do something wrong, or is it impossible for a grid connected with dbf.
     use koszty
   DEFINE WINDOW Form_1 ;
      WIDTH 800 ;
      HEIGHT 600 ;
      TITLE "Demo: GRID CheckBox" ;
      MAIN
      @ 50,10 GRID Grid_1 WIDTH 750 HEIGHT 350 HEADERS {'Last Name', 'First Name'} ;
       WIDTHS {140, 140}  ROWSOURCE 'koszty' COLUMNFIELDS {'SYMB_KONT','NAZWA'} VALUE {1,1} CELLNAVIGATION ;
       ON CHECKBOXCLICKED MsgInfo ({"Row: ", This.CellRowClicked, " is checked: ", Form_1.Grid_1.CheckBoxItem (This.CellRowClicked)}, "On CheckBoxClicked")
      @ 450, 155 BUTTON Button_1 CAPTION "CheckBoxEnabled ON/OFF" ACTION wlacz() WIDTH 200
      @ 450, 555 BUTTON Button_2 CAPTION "Check List" ACTION GetListCheckBox()
   CENTER WINDOW Form_1
   ACTIVATE WINDOW Form_1
procedure wlacz()
if !Form_1.Grid_1.CheckBoxEnabled
 Form_1.Grid_1.CheckBoxEnabled:=.t.
 Form_1.Grid_1.CheckBoxEnabled:=.f.
return
PROCEDURE GetListCheckBox
Local i, cList := ""
   IF Form_1.Grid_1.CheckBoxEnabled == .T.
      FOR i = 1 TO Form_1.Grid_1.ItemCount
         IF Form_1.Grid_1.CheckBoxItem ( i ) == .T.
            cList := cList + Form_1.Grid_1.CellEx (i, 1) +", "+ Form_1.Grid_1.CellEx (i, 2) + HB_OsNewLine()
      IF EMPTY (cList)
         cList := "Empty List"
      MsgInfo (cList, "Check List")
      MsgInfo ("CheckBoxEnabled is FALSE")
In Annex example.
I looked online but did not find anything similar.
I tried to run the debugger joining the project h_controlmisc.prg to trace where the problem is but when you start getting an error:
HMG Errorlog File
Date:05/11/16 Time: 19:26:56
Error BASE/1070 Argument error: ==
Called from EVENTS(528)
Called from INITWINDOW(0)
Called from _DEFINEWINDOW(4293)
Called from HMG_DEBUGGERWAITMESSAGE(1513)
Called from PROCINITGUIDEBUGGER(151)
Called from (b)HMGDEBUGGER(245)
Called from (b)HMGDEBUGGER(253)
Called from HMGDEBUGGER:GUICREATEFORMDEBUGGER(0)
Called from HMGDEBUGGER:ACTIVATE(276)
Called from __DBGENTRY(114)
Called from _HMG_PRINTER_INITUSERMESSAGES(6106)
Called from INITMESSAGES(915)
Called from INIT(794)
Called from ERRORSYS(67)
Called from __HBVMINIT(0)
greetings
Piotr
Google translation
Grid_CheckBoxes.zip
(2.34 KiB) Downloaded 280 times
Piotr Michalski
www.infospec.com.pl
Re: Grid: Dbf and CHECKBOXENABLED
It is not a bug, Virtual Grid (as rowsource) not work with checkbox.
For fix the error when you compile see this post: viewtopic.php?f=43&t=4738&start=30#p45165
PiotrM
Post by PiotrM »
Hello
Thank you for your answer Dr. Claudio Soto, but the compilation of the file h_controlmisc.prg attached to the project ends with an error as shown in the Annex. Of course, I fixed line in 2843 and he has compiled the file h_grid.prg
greetings
Piotr
Piotr Michalski
www.infospec.com.pl
Piotr, do you have incremental compilation turned on? Maybe reset incremental data and rebuild project
PiotrM
Post by PiotrM »
Witaj
Na to wpadłem, resetowałem, ale błąd się powtarza.
Pozdrowienia
Piotr
Hello
It ran, reboot, but the error persists.
greetings
Piotr
Piotr Michalski
www.infospec.com.pl
tonton2
Post by tonton2 »
the same program compiled with HMG_3.4.2 gives different results in HMG_3.4.3
Compiled with HMG 3.4.3
Compiles With HMG 3.4.2
GRID_Filter.rar
(2.15 KiB) Downloaded 279 times
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
tonton2 wrote:the same program compiled with HMG_3.4.2 gives different results in HMG_3.4.3
I will check.
Hola amigo PiotrM
el tema Grid CheckBoxClicked con Base de datos DBF ya puse en su momento un Pos:
viewtopic.php?f=20&t=4236&hilit=CheckBox&start=10
y provisionalmente lo solucione a no tener solución del foro con "IMAGE bmp"
El maestro Rathinagiri en su programa "FuelWare.zip" usa CheckBoxClicked pero
no logro implementarlo a un fichero DBF como en tu caso que no sale la columna
para marcar o desmarcar
viewtopic.php?f=15&t=4650&hilit=sqlite
FuelWare.zip
Un saludo
Hello friend PiotrM
Grid theme CheckBoxClicked with DBF database and put it at the time a Pos:
and temporarily solve it have no solution to the Forum with "IMAGE bmp"
The Master Rathinagiri in his "FuelWare.zip" program uses CheckBoxClicked but
profit not a DBF file implement in your case that does not leave the column
to mark or unmark
FuelWare.zip
a greeting
