some wishes
dragancesu
DBs Used: DBF, MySQL, Oracle
some wishes
Post by dragancesu »
Excellent software, great forum
It is difficult to look for something that does not have, but when it comes to still get to hear ideas and desires
Menu:
1 that you can increase the font size in the menu, it is a question of user
2 that the item menus can highlight like bold, italic
Database access:
1 harbour HMG and work nicely with DBF, Sqlite and MySQL (MSSQL/Access do not use, do not know)
2 harbour works with Oracle and PostgreSQL, HMG does not work, I think something is not well integrated / inclusive
Re: some wishes
I will add few wishes:
1. When I use On Key ESCAPE.... to release form and I activate main or context menu, the form is released. The natural way is to leave menu. It should be possibility to test if menu is active.
2. Context menu called by keyboard is always activate at the right bottom corner of desktop - when I'm working with two displays - my app is on first screen, but menu at the second
Re: some wishes
I found solution for detecting Context Menu.
Maybe it's not elegant now, but, I don't know how to get value of public variable from C code, so my scenario is:
1. declare public variable - in my sample it's Public nContextMenuIsActive := 0
2. Modified function NEW_TrackPopupMenu with added 5th parameter - my public variable nContextMenuIsActive passed by reference.
3. This new function set nContextMenuIsActive to value 999 ( it should be logical value - 999 is for test) and calls original TrackPopupMenu
4. After releasing context menu, Public nContextMenuIsActive has to be set to 0.
Modified context menu is called by simply left-clicking label!
Look at this sample code:
 2016.05.10 Marek Olszewski MOL
Detection of Context Menu sample
	DEFINE WINDOW Context ;
        WIDTH 600 HEIGHT 600 ;
        TITLE 'Context Menu Test' ;
		Main
		DEFINE CONTEXT MENU
			MENUITEM "Item 1" ACTION MsgInfo("Item 1")
			MENUITEM "Item 2" ACTION MsgInfo("Item 2")
			MENUITEM "Item 3" ACTION MsgInfo("Item 3")
		END MENU
		DEFINE LABEL Label_2
			ROW    220
			COL    180
			WIDTH  190
			HEIGHT 30
			VALUE "Click to activate New Context Menu Test"
			FONTNAME "Arial"
			FONTSIZE 9
			ACTION CallNewContextMenu()
		END LABEL
	ON KEY ESCAPE OF CONTEXT ACTION DO_RELEASE()
	Activate Window Context
FUNCTION DO_RELEASE
	MsgDebug("nContextMenuIsActive",nContextMenuIsActive)
	if nContextMenuIsActive <> 0
		MsgInfo("Context menu is activated!!!")
		if MsgYesNo("Close application?")
			Context.Release
 return
function CallNewContextMenu()
	local i
	i := GetFormIndex ( "Context" )
	xContextMenuHandle := _HMG_SYSDATA [ 74 ][i]
	//xFormHandle := _HMG_SYSDATA [ 67 ] [i]
	xFormHandle := Context.Handle
	NEW_TrackPopupMenu ( xContextMenuHandle  , 400 , 400 , xFormHandle, @nContextMenuIsActive )
return
#pragma BEGINDUMP
#include "windows.h"
#include <hbapi.h>
   #define HMG_parnl         hb_parnl
   #define HMG_parvnl        hb_parvnl
   #define HMG_retnl         hb_retnl
   #define HMG_retnllen      hb_retnllen
   #define HMG_stornl        hb_stornl
   #define HMG_storvnl       hb_storvnl
   #define HMG_arraySetNL    hb_arraySetNL
   #define HMG_arrayGetNL    hb_arrayGetNL
 HB_FUNC ( NEW_TRACKPOPUPMENU )
   HWND hWnd = (HWND) HMG_parnl (4);
   SetForegroundWindow( hWnd );
   BOOL lTopMost = HMG_IsWindowStyle( hWnd, WS_EX_TOPMOST, TRUE );
   if( lTopMost )   // ADD September 2015
      SetWindowPos( hWnd, HWND_NOTOPMOST, 0, 0, 0, 0, SWP_SHOWWINDOW | SWP_NOACTIVATE | SWP_ASYNCWINDOWPOS | SWP_NOOWNERZORDER | SWP_NOMOVE | SWP_NOSIZE );
   // Marek Olszewski MOL 2016.05.10 added one line to set 5th parameter
   hb_storni(999,5);
   TrackPopupMenu ( (HMENU) HMG_parnl(1), TPM_LEFTALIGN | TPM_TOPALIGN | TPM_LEFTBUTTON, hb_parni(2), hb_parni(3), 0, hWnd, NULL );
   hb_storni(0,5);
      SetWindowPos( hWnd, HWND_TOPMOST, 0, 0, 0, 0, SWP_SHOWWINDOW | SWP_NOACTIVATE | SWP_ASYNCWINDOWPOS | SWP_NOOWNERZORDER | SWP_NOMOVE | SWP_NOSIZE );
// PostMessage( hWnd, WM_NULL, 0, 0 );
#pragma ENDDUMP
Re: some wishes
Hi guys!
Do somebody know how can I access Public variable or Public array element from C level?
Re: some wishes
mol wrote:Hi guys!
Someone can help me?
Re: some wishes
Desconozco "C", pero si le pasas como parametro el valor ???
I do not know "C", but if you pass it as a parameter the value ???
If capGetDriverDescription(i, @cDriverName, 128, @cDriverVersion, 128)
          webcam.Combo_1.AddItem(cDriverName)
EndIf
	HB_FUNC( CAPGETDRIVERDESCRIPTION )
        TCHAR lpszName[128];
        int iName = hb_parni(3);
        TCHAR lpszVer[128];
        int iVer = hb_parni(5);
        BOOL bRet;
        bRet = capGetDriverDescription( (WORD) hb_parnl(1), lpszName, iName, lpszVer, iVer );
        hb_storc( lpszName, 2 );
        hb_storc( lpszVer, 4 );
        hb_retl( bRet );
Re: some wishes
My idea is to define something like this:
cForm.IsMainMenuActive
and switch this value before activation menu and after release.
Such solution requires minimum change of source code
