hb_Regex Try-out
hmgchang
hb_Regex Try-out
Post by hmgchang »
Dear Masters,
I hv a simple code to list out hbp UDF & functions called.
I applied the hb_regex to find the functions.
1. Can be used to open an .hbp, prg, hb files and list it on the listbox
2. On listbox changed, will find the functions and UDF and display on grids
3. There is a regex textbox to try any combination of regEx...
4. See the result by pressing hb_regexAll or hb_regex Button... see the differences
5. The projectUDF button works for the .hbp projects...
Some troubles i cant solve :
1. The editbox / richedit cannot display the whole editbox.prg
when included the ASCII box characters ( ASCII 128-255 checked).
Even the hb_regex/All functions generate errors ...
2. for the regex_fail.prg, I cannot find the {||AddData} functions by hb_regex...
Hope its useful and any suggestions and corrections are welcome....
Esp. on the hb_regex... ( the more i try the more i confuse :()
Lets Learn HMG... :)
TIA
best rgds
Chang
2016_funcref.zip
(37.87 KiB) Downloaded 317 times
Just Hmg It !
Re: hb_Regex Try-out
Thank you Chang. Wonderful bird's eye view utility to go through all the functions in a project.
Thanks Chang !
Hi Chang!
You've missed to attach adm.ch file.
Can you post it?
Steed
Post by Steed »
Thanks,
