Yesterday I've started to think, if is right, writing about JMG here.
In fact, JMG does not uses Harbour at all, and is not related with HMG in any way.
So... what I'm doing here?
Well... maybe JMG has nothing in common with HMG, but they could work together to do things that HMG can't.
HBTIP is the Harbour contrib that can do the trick:
You could use the same php scripts located on a server that JMG uses, from HMG too. ie:
cGet := cWebAddress + '/script/getdata.php'
cGet += '?'
cGet += 'code=' + alltrim ( lower(main.code.value) )
// to add more parameters, you must add an '&' between them
oHttp:= TIpClientHttp():new( cGet )
IF .NOT. oHttp:open()
MsgStop ( "Connection not available!" )
oHttp:close()
EndIf
cData := oHttp:readAll()
MSGINFO('Data returned from server: ' + cData)
oHttp:close()
There is other possible schemes to achieve that, ie, you could access MySql data directly from HMG without using the PHP scripts that JMG uses, but, this way, you should code the database handling code twice.
Wel... finally JMG and HMG could be friends... who knows
