Greetings !
Bug?
If the input mask option is a TextBox t2, when compiled program then this error message:
t3 of Form_Main not defined.
Without inputmask is ok.
FUNCTION Main()
DEFINE Window Form_Main at 0,0 width getdesktopwidth() height Getdesktopheight() title 'Error' main on init BizFrissit()
@ 335,20 texTbox t1 height 22 width 100 value '' maxlength 5 on change BizFrissit()
@ 335,130 texTbox t2 height 22 width 100 value '' on change BizFrissit()
//@ 335,130 texTbox t2 height 22 width 100 value '' inputmask '9999-99-99' on change BizFrissit()
@ 335,240 texTbox t3 height 22 width 100 value '' maxlength 40 on change BizFrissit()
Form_Main.s3.Setfocus; Form_Main.activate
RETURN(NIL)
FUNCTION BizFrissit()
IF !Empty (Form_Main.t1.Value)
MsgInfo( Form_Main.t1.Value )
IF !Empty (Form_Main.t2.Value)
MsgInfo( Form_Main.t2.Value )
IF !Empty (Form_Main.t3.Value)
MsgInfo( Form_Main.t3.Value )
RETURN(NIL)
Problem with on change
- miszler.zoltan
- dragancesu
Re: Problem with on change
Try
...numeric inputmask...
Hi Zoltan,miszler.zoltan wrote:Greetings !
Bug?
Please be so kind to update your 'On Change' function with the following code:
IF !Empty (Form_Main.t2.Value) .and. !(Form_Main.t2.Value == " - - ")
RETURN(NIL)
- miszler.zoltan
Dear Grigory and Dragancesu!
The problem, when in textbox is inputmask (numeric or text), the compiler not compiling the program!
Version: HMG 3.4.2 Stable Patch 3 (32bits)
Called from getproperty(8449)
Called from Bizfrissit(23)...
This line has error:
According to the manual does not contain only numeric input textbox mask!
TEXTBOX ( Character InputMask ):
@ <nRow>,<nCol> TEXTBOX <ControlName>
[ OF | PARENT <ParentWindowName> ]
[ HEIGHT <nHeight> ]
[ WIDTH <nWidth> ]
[ FIELD <FieldName> ]
[ VALUE <cValue> ]
[ READONLY ]
[ FONT <cFontName> SIZE <nFontSize> ]
[ BOLD ] [ ITALIC ] [ UNDERLINE ] [ STRIKEOUT ]
[ TOOLTIP <ToolTipText> ]
[ BACKCOLOR <aBackColor> ]
[ FONTCOLOR <aFontColor> ]
[ DISABLEDBACKCOLOR <aDisabledBackColor> ]
[ DISABLEDFONTCOLOR <aDisabledFontColor> ]
INPUTMASK <cMask>
[ ON CHANGE <OnChangeProcedure> ]
Best regards, Zoltan
[ WIDTH <nWidth> ]
[ VALUE <cValue> ]
[ READONLY ]
INPUTMASK <cMask>
Szia Zoli,
A probléma nem az inputmask-nak köszönhető, hanem az on change függyvény miatt.
Kipróbáltam és nálam is előjött a hiba, de a Grigory amit tanácsolt, avval tökéletesen működik.
Hi Zoltan,
I'm tried and i have the same issue, but what Grigory advised, program is works perfectly.
Hi Zoltan,
Sorry, what i wrote is wrong.
try this
hmmm interesting
try this
It Works
FUNCTION Main()
Form_Main.t1.Setfocus; Form_Main.activate
RETURN(NIL)
If IsControlDefined("t3","Form_Main") .and. !Empty (Form_Main.t3.Value)
Endif
RETURN(NIL)
