Display Image from bitmap
RussBaker
Post by RussBaker »
Silly language question. I have an image on a form. How do I display from a bitmap in memory?
I need to display a cropped section of an image file to anIMAGE
DEFINE IMAGE myphoto
ROW 10
COL 10
WIDTH 220
HEIGHT 180
PICTURE myfile
HELPID Nil
VISIBLE .T.
STRETCH .F.
ACTION Nil
END IMAGE
eg:
hBitmap1 := BT_BitmapLoadfile("myfile.jpg")
hBitmap2 := BT_BitmapClone(hBitmap1, 1,160,160,100)
How do I get the image to display the cropped image hBitmap2 ?
I saved the bitmap to a file and then place the file name in myfile
eg: myfile:="Newfile.jpg"
I would like to display directly from the bitmap and not need to save the file.
--Russ
Re: Display Image from bitmap
RussBaker wrote:Silly language question. I have an image on a form. How do I display from a bitmap in memory?
Hi Russ,
Please take a look for the following function from the BosTaurus library:
Function BT_HMGSetImage (cFormName, cControlName, hBitmap, lReleasePreviousBitmap)
LOCAL hWnd, k
   IF ValType (lReleasePreviousBitmap) <> "L"
      lReleasePreviousBitmap := .T.
   k := GetControlIndex (cControlName, cFormName)
   IF k > 0
      #ifdef __HMG__    // HMG Extended
         IF _HMG_aControlContainerHandle [k] <> 0 .AND. lReleasePreviousBitmap == .T.
            BT_BitmapRelease (_HMG_aControlContainerHandle [k])
         _HMG_aControlContainerHandle [k] := hBitmap
         _HMG_aControlWidth  [k] := BT_BitmapWidth  (hBitmap)
         _HMG_aControlHeight [k] := BT_BitmapHeight (hBitmap)
      #else             // HMG Official
         IF _HMG_SYSDATA [37, k] <> 0 .AND. lReleasePreviousBitmap == .T.
            BT_BitmapRelease (_HMG_SYSDATA [37, k])
         _HMG_SYSDATA [37, k] := hBitmap
         _HMG_SYSDATA [20, k] := BT_BitmapWidth  (hBitmap)
         _HMG_SYSDATA [21, k] := BT_BitmapHeight (hBitmap)
      #endif
      hWnd := GetControlHandle (cControlName, cFormName)
      #define _STM_SETIMAGE_ 0x0172
      #define _IMAGE_BITMAP_ 0
      SendMessage (hWnd, _STM_SETIMAGE_, _IMAGE_BITMAP_, hBitmap)
      #undef _IMAGE_BITMAP_
      #undef _STM_SETIMAGE_
Return NIL
Hope that helps :idea:
Grigory Filatov is correct
Refer following example for Resize Image and Set Control Image
C:\hmg\SAMPLES\BosTaurus\demo13.prg
RussBaker
Post by RussBaker »
gfilatov,
Thanks.
I've browsed the BosTaurus samples and believe this is my new friend. So much power in those.
I think BosTaurus will answer many of my graphic challenges.
--Russ
