Using Open Office
Using Open Office
Is there any way to use Open Office Apps, eg., Calc instead of Excel from HMG.
A discussion regarding this topic will be great helpful for all who are using Open Source Software :-)
Thank you in advace :-)
Regards.
Re: Using Open Office
I use 95% of open source products including OpenOffice. I would list them, in a short while.
I have a pattern to write to open office calc. I will find it later and put on the forum. (I saved it on one of my computers and don't know on which... :-))
I found that example!!!
It really works!
i don't know, who is author, but regards to him.
It also contains sample to create PDF, but something is wrong with aligning in PDF document.
MiTPRINTOv23.zip
(34.02 KiB) Downloaded 408 times
mol wrote:...
Hello Mol,
The homepage of MiTPRINTO v2.3 for HMG is
http://www.embalajesterra.com/misdoc/pr ... ramas.html
:idea:
of course, Grigory!
I found it during looking patterns with Excel.
Thanks for the file and the link Mol and Filatov..
Hello Mareck, Grigory,
Thanks a lot :)
Sorry for my delayed response :( (My net connection was out of order for some hours)
Regards.
Today, another friend, Antonio searched for the same topic in another group (xHarbour group).
I hope this mail will be helpful for all :)
Antonio wrote:Sudip,
To seems AutomateIt program (OLE conversor) not running; i obtain a Run time
error at worksheets in
oExcel:CreateObject("Excel.Application")
oExcel:WorkSheets:Count // here RTE
I'm developmeting a layer for to use OLE Calc throw OLE Excel syntax.
I don´t know if this option it's the better ???
Initial layer's code:
#Define lSISTEMA_CALC .T.
FUNCTION CreateObjectExcelLayer()
Local oExcel:= NIL
Local oErr:= NIL
IF !lSISTEMA_CALC
   TRY
       // Siempre crea objeto (evito algunos problemas pe. en saveas())
       oExcel:= CreateObject( "Excel.Application" )
   CATCH oErr
       MERROR_( "­ No se pudo conectar con Excel !", OLE2TXTERROR(),
oExcel,;
                oErr:SubSystem(),;
                oErr:Description,;
                oErr:Operation )
       oExcel:= NIL
   END
   oExcel:= TExcelLayer():New()
RETURN oExcel
CLASS TExcelLayer
  METHOD New()
//  ASSIGN Visible(x) INLINE (msginfo("hola", x))
  METHOD Get(cMessage) //INLINE msginfo(cMessage, "falta implementar !")
  // Datas Excel simuladas ----------------------------------------
  // Estas datas seran las que se manjen desde fuera... pero aqui
  // dentro deben tener valores apropiados
  DATA oSheet
  DATA WorkBooks
  DATA TmpWorkSheets        HIDDEN
  METHOD WorkSheets(nSheet)
  #Define ACTIVE_SHEET ::oOOCalc:getCurrentController():getActiveSheet()
  ACCESS ActiveSheet INLINE TWorkSheetExcelLayer():New(Self, NIL, NIL,
ACTIVE_SHEET)
  // Datas Calc reales --------------------------------------------
     DATA oOOEngine         READONLY
     DATA oOOCore           READONLY
     DATA oOODesktop        READONLY
     DATA oOOCalc           READONLY
ENDCLASS
Local xRet:= NIL
#Define lCOMO_DATA PCount() == 0
IF lCOMO_DATA
   xRet:= ::TmpWorkSheets
   xRet:= TWorkSheetExcelLayer():New(Self, NIL, nSheet- 1)
RETURN xRet
cMessage:= Upper(cMessage)
DO CASE
   CASE cMessage == "ACTIVESHEET"
      xRet:= ::ActiveSheet
   CASE .T.
      MERROR_("Falta implementar mensaje", cMessage)
ENDCASE
RETURN xRet
METHOD New() CLASS TExcelLayer
Local oErr
TRY
    ::oOOEngine:= CreateObject( "com.sun.star.ServiceManager" )
CATCH oErr
    MERROR_( "­ No se pudo conectar con Open Office !", OLE2TXTERROR(),
::oOOEngine,;
             oErr:SubSystem(),;
             oErr:Description,;
             oErr:Operation )
END
::oOOcore   :=
::oOOEngine:CreateInstance("com.sun.star.refelection.CoreReflection")
::oOODesktop := ::oOOEngine:createInstance("com.sun.star.frame.Desktop")
::oOOCalc := ::oOODesktop:loadComponentFromURL("private:factory/scalc",
"_blank", 0, {})
::WorkBooks := TWorkBooksExcelLayer():New(Self)
::TmpWorkSheets:= TWorkSheetsExcelLayer():New(Self)
RETURN Self
CLASS TWorkBooksExcelLayer
   EXPORTED:
      METHOD New()
      METHOD Add()
   HIDDEN:
      DATA oExcelLayer
ENDCLASS
METHOD New(oExcelLayer) CLASS TWorkBooksExcelLayer
::oExcelLayer:= oExcelLayer
RETURN Self
METHOD Add() CLASS TWorkBooksExcelLayer
Local oBook
oBook:= TWorkBookExcelLayer():New(::oExcelLayer) //, Self)
RETURN oBook
CLASS TWorkBookExcelLayer
   EXPORTED:
      METHOD New()
   HIDDEN:
      DATA oExcelLayer
      DATA oWorkBooksExcelLayer
ENDCLASS
METHOD New(oExcelLayer, oWorkBooksExcelLayer) CLASS TWorkBookExcelLayer
::oExcelLayer         := oExcelLayer
::oWorkBooksExcelLayer:= oWorkBooksExcelLayer
RETURN Self
CLASS TWorkSheetsExcelLayer
   EXPORTED:
      METHOD New()
//      // -1 pq parece que indica una hoja mas de la cuenta !!!
//      ACCESS Count  INLINE Len( ::oExcelLayer:oOOCalc:getSheets() )- 1
      ACCESS Count  INLINE ::oExcelLayer:oOOCalc:getSheets():getCount()
   HIDDEN:
      DATA oExcelLayer
ENDCLASS
METHOD New(oExcelLayer) CLASS TWorkSheetsExcelLayer
RETURN Self
CLASS TWorkSheetExcelLayer
   EXPORTED:
      METHOD New()
      METHOD Delete() INLINE
::oExcelLayer:oOOCalc:getSheets():removeByName(::oOOSheet:Name  )
      ACCESS Name        INLINE ::oOOSheet:Name
      ASSIGN Name(cName) INLINE ::oOOSheet:Name:= cName
   HIDDEN:
      DATA oExcelLayer
      DATA oWorkSheetsExcelLayer
      DATA nSheet
      DATA oOOSheet
ENDCLASS
METHOD New(oExcelLayer, oWorkSheetsExcelLayer, nSheet, oOOSheet) CLASS
::oWorkSheetsExcelLayer:= oWorkSheetsExcelLayer
::nSheet               := nSheet
DO CASE
   CASE ::nSheet != NIL
      ::oOOSheet:= ::oExcelLayer:oOOCalc:getSheets():getByIndex(nSheet)
   CASE oOOSheet != NIL
      ::oOOSheet:= oOOSheet
ENDCASE
RETURN Self
Regards.
I also got some information regarding OpenOffice from another group
Using OpenOffice Calc with MiniGui
http://www.embalajesterra.com/misdoc/ma ... fice1.html
Using OpenOffice Write with MiniGui
http://www.embalajesterra.com/misdoc/ma ... fice2.html
Thank you all.
