Basics about Umlauts
APi
Post by APi »
Hi, first of all I want to thank you for this forum and for HMG.
I work with HMG 3.4.2 and W7. I have an old (1987) Programm written in Clipper.
When I open a *.dbf from this program with MS-Excel, I can see Umlauts (öäü ÖÄÜ)
When I work with HMG-IDE Unicode 1.0.9, there are all Umlauts stolen.
When I use the sample tutor21.hbp and I edit a name to "Müller" the name looks in Excel "M├╝ller".
Thanks in advance for an answer.
Arnulf W. Pickert (APi)
Re: Basics about Umlauts
Welcome to HMG Forum.
Can you please give a small sample or screenshot?
APi
Post by APi »
नमस्ते श्री Rathinagiri,
thank you for your welcome. Here are the screenschoots.
APi
Post by APi »
...or look please here: http://www.api-gm.de/HMG.pdf
Rathi,
I have the same problem with umlauts in german names/cities.
Perhaps it is because the DBF file is in ANSI and the program code is in Unicode.
Thanks Claudio, this could be the cause. I'll check.
more ...
After years since Unicode, we can not expect MS-Excel will recognize and right implement ANSI character sets :?
Viva HMG Unicoded :D ;)
APi
Post by APi »
I think I solved the problem:
SET LANGUAGE TO GERMAN
SET DATE TO GERMAN
SET CODEPAGE TO GERMAN
EXTERNAL HB_CODEPAGE_ES850
REQUEST HB_SETCODEPAGE
HB_SETCODEPAGE ('ES850')
... and in the PSPad-Editor I use as Format "OEM"
Arnulf,
Can you please try
REQUEST HB_CODEPAGE_UTF8
(instead of your 6 lines of code) and let me known if it works.
Thx/Serge
