hmg 3.4.1 error help
kiritved
Post by kiritved »
good evening
can you help me in resolving the following error ?
Unrecoverable error 9003: Too many recursive error handler calls
Called from DEFERROR(73) in source\ErrorSys.prg
Called from (b)ERRORSYS(55) in source\ErrorSys.prg
Called from MYMAIN(12) in ub2911.prg
Called from MAIN(6) in ub2911.prg
best regards,
Carlos Britos
Re: hmg 3.4.1 error help
Post by Carlos Britos »
Hi
can you post the related code of ub2911.prg. MYMAIN() and MAIN
In this way someone can help you
kiritved
Post by kiritved »
hi
good evening
total source code is here
# include <hmg.ch>
//REQUEST HB_GT_WIN_DEFAULT
FUNCTION MAIN
set date brit
set century on
set font to "ms san sarif",15
SET TOOLTIPSTYLE BALLOON
# define RNDCOLOR {RANDOM(255),RANDOM(255),RANDOM(255)}
# define my_red {255,0,0}
# define my_green {0,255,0}
DEFINE WINDOW winK AT 138 , 235 WIDTH 1004 HEIGHT 430 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE 'software developedment assisted by kirit b. ved @9869015508/09167551554' ICON NIL NOSIZE CURSOR NIL ON INIT NIL ON RELEASE NIL ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE NIL ON MINIMIZE Nil ON PAINT Nil BACKCOLOR RNDCOLOR NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil main
define main menu
define popup 'accounts'
menuitem 'accounts normal hotkey alt+a' action acc_main()
separator
menuitem 'account-speed entry hotkey alt+s' action acc_se()
separator
menuitem 'print ledger hotkey alt+l' action my_print()
end popup
define popup 'credits'
menuitem 'credit hotkey alt+c' action credits()
separator
menuitem 'credit speed entry alt+q' action cred_se()
separator
menuitem 'credit report alt+r' action cr_rep()
end popup
define popup 'quit'
menuitem 'quit program' action (wink.release)
end popup
end menu
DEFINE IMAGE Image_1
ROW 0
COL 0
WIDTH 1606
HEIGHT 137
PICTURE "header.bmp"
HELPID Nil
VISIBLE .T.
STRETCH .T.
ACTION Nil
END IMAGE
on key ALT+A of win action acc_main()
on key ALT+S of win action acc_se()
on key ALT+L of win action my_print()
on key ALT+c of win action credits()
on key ALT+q of win action cred_se()
maximize window winK
ACTIVATE WINDOW WINK
retu
procedure acc_main
open_win1()
retu nil
function gen_dbf
if !file("acc.dbf")
sdbf := {}
aadd(sdbf,{'srno','c',8,0})
aadd(sdbf,{'tran_dt','d',8,0})
aadd(sdbf,{'narr','c',80,0})
aadd(sdbf,{'amt','n',12,2})
aadd(sdbf,{'rp','c',1,0})
dbcreate("acc",sdbf)
retu nil
function gen_ind()
sele 0
use acc alias acc
if !file("acc.ntx")
inde on srno to acc
if !file("acc1.ntx")
inde on dtoc(tran_dt) to acc1
set index to acc.NTX,acc1.NTX
set order to 1
return nil
procedure open_win1
DEFINE WINDOW win1 AT 132 , 235 WIDTH 1200 HEIGHT 800 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "" ICON NIL CURSOR NIL ON INIT (bm1(),gen_dbf() ,gen_ind()) ON RELEASE CD() ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE Nil ON MINIMIZE Nil ON PAINT Nil BACKCOLOR RNDCOLOR NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil
DEFINE LABEL Label_1
ROW 70
COL 230
WIDTH 520
HEIGHT 40
VALUE "account data entry form"
FONTNAME "Arial"
FONTSIZE 16
TOOLTIP ""
FONTBOLD .T.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
CENTERALIGN .T.
END LABEL
DEFINE LABEL Label_2
ROW 180
COL 200
WIDTH 120
HEIGHT 24
VALUE "serial number :-"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
DEFINE TEXTBOX Text_1
ROW 180
COL 390
WIDTH 120
HEIGHT 24
field acc->srno
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .f.
RIGHTALIGN .T.
DISABLEDBACKCOLOR Nil
DISABLEDFONTCOLOR Nil
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
NUMERIC .f.
VALUE Nil
END TEXTBOX
DEFINE LABEL Label_3
ROW 230
COL 200
WIDTH 120
HEIGHT 24
VALUE "transaction date :-"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
DEFINE TEXTBOX Text_2
ROW 230
COL 390
WIDTH 120
HEIGHT 24
field acc->tran_dt
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .F.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
DATE .T.
VALUE Nil
END TEXTBOX
DEFINE LABEL Label_4
ROW 280
COL 200
WIDTH 120
HEIGHT 24
VALUE "narration :-"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
DEFINE EDITBOX Edit_1
ROW 280
COL 390
WIDTH 200
HEIGHT 100
field acc->narr
VALUE ""
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
HSCROLLBAR .T.
VSCROLLBAR .T.
BACKCOLOR Nil
FONTCOLOR Nil
MAXLENGTH 100
END EDITBOX
DEFINE LABEL Label_5
ROW 450
COL 200
WIDTH 120
HEIGHT 24
VALUE "amount :-"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
DEFINE TEXTBOX Text_3
ROW 450
COL 390
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
field acc->amt
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .F.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
NUMERIC .T.
VALUE Nil
END TEXTBOX
DEFINE TEXTBOX Text_4
ROW 510
COL 390
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
field acc->rp
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS lb()
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .F.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
NUMERIC .f.
VALUE Nil
tooltip 'enter only r or p for receipt & paid '
END TEXTBOX
DEFINE LABEL Label_6
ROW 510
COL 200
WIDTH 120
HEIGHT 50
VALUE "mode of payment (received or paid)"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
@ 400 ,650 listbox lb items {'r','p'} bold BACKCOLOR RNDCOLOR on dblclick lbproc()
win1.lb.visible:=.f.
DEFINE TOOLBAR ToolBar_1 BUTTONSIZE 100,30 FLAT RIGHTTEXT BORDER BOLD
BUTTON TOP ;
CAPTION '&Top' ;
PICTURE 'primero.bmp' ;
tooltip "go to the top of the file " ;
ACTION ( DbGoTop() , Refresh1() )
BUTTON NEXT ;
CAPTION '&Next';
PICTURE 'siguiente.bmp' ;
ACTION ( DbSkip(1) , if ( eof() , DbGoBottom() , Nil ) , Refresh1() )
tooltip "go to next record of the file"
BUTTON PREVIOUS ;
CAPTION '&Previous';
PICTURE 'anterior.bmp' ;
tooltip "go to previous record of the file";
ACTION ( DbSkip(-1) , Refresh1() )
BUTTON BOTTOM ;
CAPTION '&Bottom' ;
PICTURE 'ultimo.bmp' ;
ACTION ( DbGoBottom() , Refresh1() );
tooltip "go to the last record of the file"
BUTTON SAVE ;
CAPTION '&Save' ;
PICTURE 'guardar.bmp' ;
ACTION ( Save() , Refresh1() );
tooltip "save changes in the file"
BUTTON gUNDO ;
CAPTION '&Undo' ;
PICTURE 'deshacer.bmp' ;
ACTION ( Refresh1() );
tooltip "discard changes made"
BUTTON delete ;
CAPTION '&delete' ;
ACTION ( my_del(),Refresh1() );
tooltip "delete current record of the file"
BUTTON add ;
CAPTION '&add' ;
ACTION ( my_add1() ) ;
tooltip "add new record to the file"
//separator
BUTTON find ;
CAPTION '&find' ;
ACTION (my_search1()) // my_find() );
tooltip "search record of the file"
BUTTON exit ;
CAPTION '&exit' ;
ACTION (thiswindow.release) // my_find() );
tooltip "close this window"
END TOOLBAR
@ 600,80 button b_accept ;
caption 'accept' ;
action ( my_accept1())
@ 600,200 button b_cancel ;
caption 'cancel' ;
action (my_cancel1())
DEFINE STATUSBAR FONT "Arial" SIZE 9
STATUSITEM "software developed by kirit b. ved contact 09167551554 - 09869015508 email:-kiritved@gmail.com kiritved@outlook.com"
DATE
CLOCK
STATUSITEM date()
END STATUSBAR
DEFINE BROWSE Browse_1
ROW 80+100
COL 650
WIDTH 650
HEIGHT 800
VALUE 0
WIDTHS {100,100,100,100,400}
HEADERS {'srno','date','amt','r/p','narr'}
WORKAREA acc
FIELDS {'acc->srno','acc->tran_dt' ,'acc->amt','acc->rp','acc->narr'}
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE refresh11()
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .t.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONDBLCLICK Nil
ALLOWEDIT .f.
ALLOWAPPEND .f.
ONHEADCLICK Nil
ALLOWDELETE .F.
HELPID Nil
VALID Nil
VALIDMESSAGES Nil
LOCK .F.
VSCROLLBAR .T.
INPUTMASK Nil
FORMAT Nil
WHEN Nil
INPUTITEMS Nil
DISPLAYITEMS Nil
BACKCOLOR NIL
FONTCOLOR Nil
IMAGE Nil
JUSTIFY Nil
NOLINES .F.
READONLYFIELDS Nil
HEADERIMAGES Nil
END BROWSE
@ 150,650 LABEL LABEL_61 VALUE 'enter narration key word ' width 150
@ 150,830 textbox text_61 width 50
@ 150,900 button b_1 caption 'search' action (my_find())
maximize window win1
activate window win1
retu nil
Procedure Refresh1
win1.Text_1.Refresh
win1.Text_2.Refresh
win1.edit_1.Refresh
win1.Text_3.Refresh
win1.text_4.Refresh
m:=recno()
win1.browse_1.value:=m
win1.browse_1.refresh
Procedure Refresh11
m:= win1.browse_1.value
go m
win1.text_1.value:=acc->srno
win1.text_2.value:=acc->tran_dt
win1.edit_1.value:=acc->narr
win1.text_3.value:=acc->amt
win1.text_4.value:=acc->rp
refresh1()
text_1
edit_1
monthcal_1
text_2
check_1
procedure bm1
win1.b_accept.enabled := .f.
win1.b_cancel.enabled:= .f.
win1.label_61.visible:= .f.
win1.text_61.visible:= .f.
win1.b_1.visible:= .f.
retu
Procedure Save
Win1.Text_1.Save
Win1.Text_2.Save
win1.text_3.save
win1.edit_1.save
win1.text_4.save
procedure my_del
if msgyesno("are you sure ?","confirm deletion")
dbdelete()
pack
refresh()
retu
procedure my_add1
dbgobottom()
skip 1
refresh1()
win1.text_2.value:=date()
win1.b_accept.enabled := .t.
win1.b_cancel.enabled:= .t.
win1.toolbar_1.top.enabled:=.f.
win1.toolbar_1.next.enabled:=.f.
win1.toolbar_1.previous.enabled:=.f.
win1.toolbar_1.bottom.enabled:=.f.
win1.toolbar_1.save.enabled:=.f.
win1.toolbar_1.gundo.enabled:=.f.
win1.toolbar_1.delete.enabled:=.f.
win1.toolbar_1.add.enabled:=.f.
win1.toolbar_1.find.enabled:=.f.
retu
procedure my_search1
win1.label_61.visible:= .t.
win1.text_61.visible:= .t.
win1.b_1.visible:= .t.
win1.text_61.setfocus
retu
procedure my_accept1
if my_valid(win1.text_1.value,"acc")
dbappend()
acc->srno:=win1.text_1.value
acc->tran_dt:=win1.text_2.value
acc->narr:=win1.edit_1.value
acc->amt:=win1.text_3.value
acc->rp:=win1.text_4.value
dbgotop()
win1.toolbar_1.top.enabled:=.t.
win1.toolbar_1.next.enabled:=.t.
win1.toolbar_1.previous.enabled:=.t.
win1.toolbar_1.bottom.enabled:=.t.
win1.toolbar_1.save.enabled:=.t.
win1.toolbar_1.gundo.enabled:=.t.
win1.toolbar_1.delete.enabled:=.t.
win1.toolbar_1.add.enabled:=.t.
win1.toolbar_1.find.enabled:=.t.
refresh1()
retu
procedure my_cancel1
refresh()
retu
Procedure my_Refresh1
m:=win1.browse_1.value
go m
win1.Text_1.Refresh
win1.Text_2.Refresh
win1.text_3.refresh
win1.edit_1.refresh
win1.text_4.refresh
procedure my_find
//local rs:=alltrim(lower(win1.text_61.value))
//rs:=alltrim(rs)
save_sel:=alias()
sele acc
set filter to alltrim(lower(win1.text_61.value)) $ narr
go top
refresh()
my_refresh()
set filter to
sele &save_sel
retu
go m
Win1.Text_1.Refresh
Win1.Text_2.Refresh
win1.text_3.refresh
win1.text_4.refresh
Procedure Refresh
Win1.Text_1.Refresh
Win1.Text_2.Refresh
Win1.Text_3.Refresh
Win1.Text_4.Refresh
win1.browse_1.value:=recno()
function my_valid(s,als)
local rl:=.f.,rn,save_sel
if len(alltrim(s)) > 0
rl:=.t.
msginfo("code can not be blank")
win1.text_1.setfocus
if rl==.t.
save_sel:=alias()
sele &als
seek s
if found()
rl:=.f.
msginfo("code already exists in database")
sele &save_sel
retu rl
function pqr
local rv
select acc
if acc->rp="r"
rv:=1
rv:=2
retu rv
procedure qwe
my:={'r','p'}
retu nil
//syntex for the function chk is chk({'flat','shop'},"s")
function chk(a,b)
local r:=0
local p:=0
k:=len(a)
for i=1 to k
r=chk1(a,b)
if r==1
p:=i
exit
next
retu p
function chk1(p,q)
local r:=0
if p == q
r:=1
retu r
procedure lb
if chk({'r','p'}, win1.text_4.value)=0
win1.lb.visible:=.t.
win1.lb.setfocus
retu nil
procedure lbproc
win1.text_4.value:=win1.lb.item(win1.lb.value)
retu nil
PROCEDURE CD
CLOSE ALL
RETU
PROCEDURE meri_jaan
run d.exe
RUN DEL *.NTX)
retu
procedure acc_se
define window win2 at 0, 0 height 600 width 600 title 'hi' on init (od(),se()) on release cd1() BACKCOLOR RNDCOLOR
ROW 100
COL 0
WIDTH 450
HEIGHT 600
VALUE 0
WIDTHS {200,30,50}
HEADERS {'narration ','receipt/paid','amount'}
WORKAREA acc
FIELDS {'acc->narr','acc->rp','acc->amt'}
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .t.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONDBLCLICK Nil
ALLOWEDIT .f.
ALLOWAPPEND .f.
ONHEADCLICK Nil
ALLOWDELETE .F.
HELPID Nil
VALID Nil
VALIDMESSAGES Nil
LOCK .F.
VSCROLLBAR .T.
DYNAMICBACKCOLOR Nil
DYNAMICFORECOLOR Nil
INPUTMASK Nil
FORMAT Nil
WHEN Nil
INPUTITEMS Nil
DISPLAYITEMS Nil
BACKCOLOR {0,255,0}
FONTCOLOR Nil
IMAGE Nil
JUSTIFY Nil
NOLINES .F.
READONLYFIELDS Nil
HEADERIMAGES Nil
END BROWSE
@ 5,5 label lbl_1 value 'narration'
@ 25,5 textbox text_1 width 300 height 30
@ 60,5 textbox text_2 width 300 height 30
@ 5, 340 label lbl_2 value 'r/p'
@ 25 ,340 textbox text_3 width 30 height 30 tooltip 'enter only r->receipt and p->paid here' on lostfocus lb1()
@ 5, 380 label lbl_3 value 'amount'
@ 25,380 textbox text_4 width 100 height 30 numeric
@ 60 , 340 button btn_1 caption ' save & continue' on click (pqr1(),se())
@ 60, 440 button btn_3 caption 'save & exit ' on click (pqr1())
@ 60, 540 button btn_4 caption 'exit ' on click (win2.release)
@ 400 ,300 listbox lb items {'r','p'} bold BACKCOLOR RNDCOLOR on dblclick lbproc1()
win2.lb.visible:=.f.
end window
maximize window win2
activate window win2
retu nil
procedure od
use acc alias acc new
select acc
retu nil
procedure cd1
use
run del *.ntx
retu nil
procedure acc_sa
retu
procedure se
win2.text_1.value:=space(40)
win2.text_2.value:=space(40)
win2.text_3.value:='r'
win2.text_4.value:=0
win2.text_1.setfocus
retu
procedure pqr1()
local m1
local m2 :=date()
go bott
m3:=val(acc->srno)
m1:=reccount()
m1:=max(m1,m3)+1
m1:=padl(m1,8,'0')
append blank
repl srno with m1
repl tran_dt with m2
repl narr with alltrim(win2.text_1.value)+' '+alltrim(win2.text_2.value)
repl rp with win2.text_3.value
repl amt with win2.text_4.value
go top
win2.browse_1.refresh
retu nil
procedure lb1
if chk({'r','p'}, win2.text_3.value)=0
MessageBoxTimeout('only r for receipt & p for paid is allowed here','attention',0,3000)
win2.text_3.setfocus
retu nil
procedure lbproc1
msginfo(win2.text_3.value)
retu nil
procedure my_print
set date brit
set century on
DEFINE WINDOW winx AT 138 , 235 WIDTH 808 HEIGHT 494 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "" ICON NIL CURSOR NIL ON INIT Nil ON RELEASE Nil ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE Nil ON MINIMIZE Nil ON PAINT Nil BACKCOLOR RNDCOLOR NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil child
ROW 60
COL 170
WIDTH 450
HEIGHT 30
VALUE "printing of accounts between two dates"
FONTNAME "Arial"
FONTSIZE 18
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
CENTERALIGN .T.
END LABEL
DEFINE MONTHCALENDAR MonthCal_1
ROW 140
COL 140
WIDTH 227
HEIGHT 162
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP "enter start date"
ONCHANGE mc()
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
TABSTOP .T.
VISIBLE .T.
NOTODAY .F.
NOTODAYCIRCLE .F.
WEEKNUMBERS .F.
END MONTHCALENDAR
DEFINE MONTHCALENDAR MonthCal_2
ROW 140
COL 430
WIDTH 227
HEIGHT 162
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP "enter end date"
ONCHANGE mc()
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
TABSTOP .T.
VISIBLE .T.
NOTODAY .F.
NOTODAYCIRCLE .F.
WEEKNUMBERS .F.
END MONTHCALENDAR
define textbox mc_1
row 400
col 140
//autosize .t.
width 100
date .t.
value winx.monthcal_1.value
end textbox
define textbox mc_2
row 400
col 430
width 100
date .t.
value winx.monthcal_2.value
//autosize .t.
end textbox
DEFINE BUTTON Button_1
ROW 350
COL 350
WIDTH 100
HEIGHT 28
ACTION my_pxxx()
CAPTION "get ledger"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
HELPID Nil
FLAT .F.
TABSTOP .T.
VISIBLE .T.
TRANSPARENT .F.
MULTILINE .F.
PICTURE Nil
PICTALIGNMENT TOP
END BUTTON
center window winx
maximize window winx
activate window winx
retu
procedure mc
winx.mc_1.value:=winx.monthcal_1.value
winx.mc_2.value:=winx.monthcal_2.value
retu
procedure my_pxxx
my_od()
set date brit
set century on
go top
m1:=tran_dt
go bott
m2:=tran_dt
mdt1:=winx.monthcal_1.value
mdt2:=winx.monthcal_2.value
if !( (mdt1>=m1 .and. mdt2<=m2 ) .or. (mdt2>=mdt1))
msginfo('dates must be between ' + dtoc(mdt1) +' & '+dtoc(mdt2) )
winx.monthcal_1.setfocus
go top
repl all fl1 with 1 for tran_dt< mdt1
repl all fl1 with 2 for tran_dt>=mdt1 .and. tran_dt<=mdt2
go top
sum(iif(rp='r',amt,-amt)) to myob for fl1=1
sum(iif(rp='r',amt,-amt)) to mycb for fl1=1 .or. fl1=2
if file('tmp.dbf')
run del tmp.dbf
copy to tmp.dbf for fl1=2
use tmp new
appe blank
repl srno with '00000000'
repl narr with 'opening balance'
if myob>=0
repl rp with 'r'
repl rp with 'p'
repl amt with abs(myob)
repl tran_dt with mdt1
appe blank
repl srno with '99999999'
repl narr with 'closing balance'
if mycb>=0
repl rp with 'r'
repl rp with 'p'
repl amt with abs(mycb)
repl tran_dt with mdt2
inde on srno to tmp
go top
set print to tmp.txt
set devi to prin
set print on
set console off
if dtoc(mdt1) = dtoc(mdt2)
ms:='accounts of bhambhani enterprise for '+' ' + dtoc(mdt1)
ms:='accounts of bhambhani enterprise from '+' ' + dtoc(mdt1) + ' to '+dtoc(mdt2)
?padc(ms,88)
? PADR('DATE',10)+' '+padr('narration',40)+' '+padC('amount',30)
? PADR(' ',50)+SPACE(10)+PADR('RECEIVED',10)+PADR('PAID',10)+PADR('CUM.TOTAL',10)
? replicate('-',88)
MYSUM:=0
mysum1:=0
mysum2:=0
m:=reccount()
s:=0
go top
do while ! eof()
s:=s+1
MYSUM:=MYSUM+iif(rp='r',amt,-amt)
if s=m
?replicate('-',88)
?padr('total',56)+str(mysum1,10,2)+str(mysum2,10,2)
?replicate('-',88)
? PADR(dtoc(tran_dt),10)+' '+padr(narr,40)+' '+' '+iif(rp='r',str(amt,10,2)+space(10),space(10)+str(amt,10,2)) +' '+space(10) //STR(MYSUM,10,2)
mysum1:=mysum1+iif(rp='r',amt,0)
mysum2:=mysum2+iif(rp='r',0,amt)
? PADR(dtoc(tran_dt),10)+' '+padr(narr,40)+' '+' '+iif(rp='r',str(amt,10,2)+space(10),space(10)+str(amt,10,2)) +' '+STR(MYSUM,10,2)
skip
enddo
use
set print to
set device to screen
set print off
set console on
//run ed tmp.txt
run txt2pdf tmp.txt acc.pdf -pfs10 -oao -ptc2 -pfn201 -pps7 -pwa -plm32 -prm32
run del tmp.*
run del *.ntx
close all
retu nil
procedure my_od
select 0
inde on srno to acc
inde on dtos(tran_dt) to acc1
set order to 2
retu nil
procedure _se
DEFINE WINDOW winc AT 50 , 50 WIDTH 1000 HEIGHT 900 VIRTUAL WIDTH Nil VIRTUAl HEIGHT Nil TITLE "" ICON NIL CURSOR NIL ON INIT (bm2(),gen_dbf1(),gen_ind1(),od1()) ON RELEASE Nil ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE Nil ON MINIMIZE Nil ON PAINT Nil BACKCOLOR RNDCOLOR NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil
ROW 60
COL 190
WIDTH 450
HEIGHT 30
VALUE "credit module of bhambhani enterprise"
FONTNAME "Arial"
FONTSIZE 18
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
CENTERALIGN .T.
END LABEL
ROW 150
COL 80
WIDTH 120
HEIGHT 24
VALUE "sr. no.:-"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 150
COL 250
WIDTH 120
HEIGHT 24
field cred->srno
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .f.
RIGHTALIGN .F.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
END TEXTBOX
ROW 210
COL 80
WIDTH 120
HEIGHT 24
VALUE "narration"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 210
COL 250
WIDTH 350
HEIGHT 120
VALUE ""
field cred->narr
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
HSCROLLBAR .T.
VSCROLLBAR .T.
BACKCOLOR Nil
FONTCOLOR Nil
END EDITBOX
ROW 360
COL 250
WIDTH 120
HEIGHT 24
field cred->tran_dt
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .T.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
DATE .T.
VALUE Nil
END TEXTBOX
ROW 360
COL 80
WIDTH 120
HEIGHT 24
VALUE "date given:-"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 420
COL 80
WIDTH 120
HEIGHT 24
VALUE "amount given:-"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 420
COL 250
WIDTH 120
HEIGHT 24
field cred->amt
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .T.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
numeric .t.
END TEXTBOX
DEFINE CHECKBOX Check_1
ROW 480
COL 80
WIDTH 100
HEIGHT 28
CAPTION "returned ?"
VALUE .F.
field cred->rp
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
BACKCOLOR Nil
FONTCOLOR Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
TRANSPARENT .F.
END CHECKBOX
ROW 480
COL 200
WIDTH 120
HEIGHT 24
VALUE "date returned :-"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
DEFINE TEXTBOX Text_6
ROW 480
COL 350
WIDTH 120
HEIGHT 24
field cred->ret_dt
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .T.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
date .t.
END TEXTBOX
BUTTON TOP ;
CAPTION '&Top' ;
ACTION ( DbGoTop() , Refresh2() )
BUTTON NEXT ;
CAPTION '&Next';
ACTION ( DbSkip(1) , if ( eof() , DbGoBottom() , Nil ) , Refresh2() )
BUTTON PREVIOUS ;
ACTION ( DbSkip(-1) , Refresh2() )
BUTTON BOTTOM ;
CAPTION '&Bottom' ;
ACTION ( DbGoBottom() , Refresh2() );
BUTTON SAVE ;
CAPTION '&Save' ;
ACTION ( save1() , Refresh2() );
BUTTON gUNDO ;
CAPTION '&Undo' ;
ACTION ( Refresh2() );
BUTTON delete ;
CAPTION '&delete' ;
ACTION ( my_del1(),Refresh2() );
BUTTON add ;
CAPTION '&add' ;
ACTION ( my_add2() ) ;
BUTTON edit ;
CAPTION '&edit' ;
ACTION ( save1(),refresh2()) ;
//separator
BUTTON find ;
CAPTION '&find' ;
ACTION (my_search2()) // my_find() );
BUTTON exit ;
CAPTION '&exit' ;
BUTTON KBV;
CAPTION 'REPORT1';
ACTION (MEKBV());
TOOLTIP 'SEE DATA IN DIFFERENT FORMAT'
END TOOLBAR
caption 'accept' ;
action ( my_accept2())
caption 'cancel' ;
action (my_cancel2())
DATE
CLOCK
STATUSITEM date()
END STATUSBAR
ROW 80+100
COL 650
WIDTH 450
HEIGHT 800
VALUE 0
WIDTHS {100,100,80,100,200}
WORKAREA cred
FIELDS {'cred->srno','cred->tran_dt' ,'cred->amt','cred->rp','cred->narr'}
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE my_refresh2()
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .t.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONDBLCLICK Nil
ALLOWEDIT .f.
ALLOWAPPEND .f.
ONHEADCLICK Nil
ALLOWDELETE .F.
HELPID Nil
VALID Nil
VALIDMESSAGES Nil
LOCK .F.
VSCROLLBAR .T.
INPUTMASK Nil
FORMAT Nil
WHEN Nil
INPUTITEMS Nil
DISPLAYITEMS Nil
BACKCOLOR {0,255,0}
FONTCOLOR Nil
IMAGE Nil
JUSTIFY Nil
NOLINES .F.
READONLYFIELDS Nil
HEADERIMAGES Nil
END BROWSE
@ 150,900 button b_1 caption 'search' action (my_find1())
center window winc
maximize window winc
activate window winc
retu nil
procedure mekbv
LOCAL bColor := { || if(!cred->rp,my_red,my_green) }
define window mekbv at 20,800 height 800 width 700 backcolor RNDCOLOR
set order to 3
DEFINE BROWSE Browse_11
ROW 40
COL 50
WIDTH 450
HEIGHT 600
VALUE 0
WIDTHS {100,100,80,80,200}
WORKAREA cred
FONTNAME "Arial"
dynamicbackcolor {bColor,bColor,bColor,bColor,bColor}
FONTSIZE 9
TOOLTIP ""
ONCHANGE nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .t.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONDBLCLICK Nil
ALLOWEDIT .f.
ALLOWAPPEND .f.
ONHEADCLICK Nil
ALLOWDELETE .F.
HELPID Nil
VALID Nil
VALIDMESSAGES Nil
LOCK .F.
VSCROLLBAR .T.
INPUTMASK Nil
FORMAT Nil
WHEN Nil
INPUTITEMS Nil
DISPLAYITEMS Nil
BACKCOLOR {0,255,0}
FONTCOLOR Nil
IMAGE Nil
JUSTIFY Nil
NOLINES .F.
READONLYFIELDS Nil
HEADERIMAGES Nil
END BROWSE
define button b_0
row 680
col 250
caption 'quit'
action (mekbv.release)
end button
end window
activate window mekbv
retu nil
Procedure Refresh2
winc.Text_1.Refresh
winc.Text_2.Refresh
winc.edit_1.Refresh
winc.text_3.Refresh
winc.text_6.Refresh
winc.check_1.Refresh
winc.browse_1.value:=recno()
winc.browse_1.refresh
procedure my_add2
winc.check_1.visible:=.f.
winc.label_6.visible:=.f.
winc.text_6.visible:=.f.
dbgobottom()
go bott
m3:=val(CRED->srno)
m1:=reccount()
m1:=max(m1,m3)+1
m1:=padl(m1,8,'0')
skip 1
refresh2()
winc.text_3.value:=date()
winc.text_1.value:=M1
winc.b_accept.enabled := .t.
winc.b_cancel.enabled:= .t.
winc.toolbar_1.top.enabled:=.f.
winc.toolbar_1.next.enabled:=.f.
winc.toolbar_1.previous.enabled:=.f.
winc.toolbar_1.bottom.enabled:=.f.
winc.toolbar_1.save.enabled:=.f.
winc.toolbar_1.gundo.enabled:=.f.
winc.toolbar_1.delete.enabled:=.f.
winc.toolbar_1.add.enabled:=.f.
winc.toolbar_1.find.enabled:=.f.
retu
procedure se1
winc.text_1.value:=space(8)
winc.text_2.value:=0
winc.edit_1.value:=space(80)
winc.text_3.value:=ctod(' / / ')
winc.check_1.value:=.f.
winc.text_1.setfocus
retu
Procedure my_Refresh2
m:=winc.browse_1.value
go m
winc.Text_1.Refresh
winc.Text_2.Refresh
winc.edit_1.refresh
winc.text_3.refresh
winc.text_6.refresh
winc.check_1.refresh
procedure my_accept2
winc.check_1.visible:=.t.
winc.label_6.visible:=.t.
winc.text_6.visible:=.t.
if my_valid(winc.text_1.value,"cred")
dbappend()
cred->srno:=winc.text_1.value
cred->tran_dt:=winc.text_3.value
cred->narr:=winc.edit_1.value
cred->amt:=winc.text_2.value
cred->rp:=winc.check_1.value
cred->ret_dt:=winc.text_6.value
dbgotop()
winc.b_accept.enabled := .f.
winc.b_cancel.enabled:= .f.
winc.toolbar_1.top.enabled:=.t.
winc.toolbar_1.next.enabled:=.t.
winc.toolbar_1.previous.enabled:=.t.
winc.toolbar_1.bottom.enabled:=.t.
winc.toolbar_1.save.enabled:=.t.
winc.toolbar_1.gundo.enabled:=.t.
winc.toolbar_1.delete.enabled:=.t.
winc.toolbar_1.add.enabled:=.t.
winc.toolbar_1.find.enabled:=.t.
refresh2()
retu
procedure my_cancel2
refresh2()
retu
function gen_dbf1
if !file("cred.dbf")
sdbf := {}
aadd(sdbf,{'rp','l',1,0})
aadd(sdbf,{'ret_dt','d',8,0})
dbcreate("cred",sdbf)
retu nil
function gen_ind1
sele 0
use cred alias cred
if !file("cred.ntx")
inde on srno to cred
if !file("cred1.ntx")
inde on dtoc(tran_dt) to cred1
if !file("cred2.ntx")
inde on if(rp,'1','0')+dtoc(tran_dt) to cred2
set index to cred.NTX,cred1.NTX,cred2.ntx
set order to 1
//select cred
return nil
procedure od1
select cred
set order to 1
retu nil
Procedure Save1
Winc.Text_1.Save
Winc.Text_2.Save
winc.edit_1.save
winc.text_3.save
winc.text_6.save
winc.check_1.save
procedure my_del1
dbdelete()
pack
refresh2()
retu
procedure bm2
winc.label_61.visible:= .f.
winc.text_61.visible:= .f.
winc.b_1.visible:= .f.
retu
procedure my_search2
winc.label_61.visible:= .t.
winc.text_61.visible:= .t.
winc.b_1.visible:= .t.
winc.text_61.setfocus
retu
procedure my_find1
//local rs:=alltrim(lower(winc.text_61.value))
//rs:=alltrim(rs)
save_sel:=alias()
sele cred
set filter to alltrim(lower(winc.text_61.value)) $ narr
go top
refresh2()
my_refresh2()
set filter to
sele &save_sel
retu
PROCEDURE KBV
LOCAL S1,S2
S1:=THIS.HEIGHT
S2:=THIS.WIDTH
MSGINFO(S1)
MSGINFO(S2)
RETU
procedure cr_rep
run del tmp1.dbf
gen_dbf11()
sele tmp1
appe from cred for rp=.f.
go top
do while ! eof()
msrno=tmp1->srno
mtran_dt=tmp1->tran_dt
mdys=date()-mtran_dt
repl dys with mdys
skip
enddo
gen_ind11()
set console off
set print on
set device to prin
set printer to tmp1.txt
ms:='credi reports of bhambhani enterprise'
?padc(ms,85)
? padr('date',10)+' '+padr('narration',40)+' '+padr('amount',10)+'pending for dys'
? replicate('-',85)
do while ! eof()
? padr(dtoc(tran_dt),10)+' '+padr(narr,40)+' '+ ' '+str(amt,10,2) + ' '+str(dys,12,2)
skip
enddo
use
set print to
set print off
set console on
//run ed tmp.txt
run txt2pdf tmp1.txt acc.pdf -pfs10 -oao -ptc2 -pfn201 -pps7 -pwa -plm32 -prm32
run del tmp.*
close all
run del *.ntx
retu nil
function gen_dbf11
if !file("tmp1.dbf")
sdbf := {}
aadd(sdbf,{ 'dys','n',12,2})
dbcreate("tmp1",sdbf)
sele 0
use tmp1 alias tmp1
retu nil
function gen_ind11
sele tmp1
if !file("tmp1.ntx")
inde on (99999999-dys) to tmp1
set index to tmp1.NTX
set order to 1
//tone(500,20)
return nil
procedure cred_se
define window winpqr at 0, 0 height 600 width 600 title 'hi' on init (odpqr(),se1pqr()) on release cd1pqr() BACKCOLOR RNDCOLOR
ROW 100
COL 0
WIDTH 450
HEIGHT 600
VALUE 0
WIDTHS {200,30,50,100,100}
HEADERS {'narration ','receipt/paid','amount','dt given','dt returned'}
WORKAREA cred
FIELDS {'cred->narr','cred->rp','cred->amt','cred->tran_dt','cred->ret_dt'}
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .t.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONDBLCLICK Nil
ALLOWEDIT .f.
ALLOWAPPEND .f.
ONHEADCLICK Nil
ALLOWDELETE .F.
HELPID Nil
VALID Nil
VALIDMESSAGES Nil
LOCK .F.
VSCROLLBAR .T.
INPUTMASK Nil
FORMAT Nil
WHEN Nil
INPUTITEMS Nil
DISPLAYITEMS Nil
BACKCOLOR {0,255,0}
FONTCOLOR Nil
IMAGE Nil
JUSTIFY Nil
NOLINES .F.
READONLYFIELDS Nil
HEADERIMAGES Nil
END BROWSE
@ 60 , 340 button btn_1 caption ' save & continue' on click (pqr11(),se1pqr())
@ 60, 440 button btn_3 caption 'save & exit ' on click (pqr11())
@ 60, 540 button btn_4 caption 'exit ' on click (winpqr.release)
winpqr.lb.visible:=.f.
end window
maximize window winpqr
activate window winpqr
retu nil
procedure se1pqr
winpqr.text_1.value:=space(40)
winpqr.text_2.value:=space(40)
//winpqr.text_3.value:='r'
winpqr.text_4.value:=0
winpqr.text_1.setfocus
retu
procedure pqr11()
local m1
local m2 :=date()
go bott
m3:=val(cred->srno)
m1:=reccount()
m1:=max(m1,m3)+1
m1:=padl(m1,8,'0')
append blank
repl srno with m1
repl narr with alltrim(winpqr.text_1.value)+' '+alltrim(winpqr.text_2.value)
//repl rp with winpqr.text_3.value
repl amt with winpqr.text_4.value
go top
winpqr.browse_1.refresh
retu nil
procedure odpqr
use cred alias cred new
select cred
retu nil
procedure cd1pqr
use
run del *.ntx
retu nil
function my_hi
local rl
rl=.f.
if !file("c:\windows\system32\mymem.mem")
rl=.f.
restore from "c:\windows\system32\mymem.mem"
mdt1=ctod(enc_str(substr(z4,1,10)))
mdt2=ctod(enc_str(substr(z4,14,10)))
if date()>mdt2
rl=.f.
rl=.t.
retu rl
function enc_chr(s)
local rs
rs=chr(255-asc(s))
retu rs
function enc_str(s)
local rs,l
l=len(s)
rs=""
for i=1 to l
ks=substr(s,i,1)
rs=rs+enc_chr(ks)
next
retu rs
procedure credits
ROW 60
COL 190
WIDTH 450
HEIGHT 30
FONTNAME "Arial"
FONTSIZE 18
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
CENTERALIGN .T.
END LABEL
ROW 150
COL 80
WIDTH 120
HEIGHT 24
VALUE "sr. no.:-"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 150
COL 250
WIDTH 120
HEIGHT 24
field cred->srno
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .f.
RIGHTALIGN .F.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
END TEXTBOX
ROW 210
COL 80
WIDTH 120
HEIGHT 24
VALUE "narration"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 210
COL 250
WIDTH 350
HEIGHT 120
VALUE ""
field cred->narr
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
HSCROLLBAR .T.
VSCROLLBAR .T.
BACKCOLOR Nil
FONTCOLOR Nil
END EDITBOX
ROW 360
COL 250
WIDTH 120
HEIGHT 24
field cred->tran_dt
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .T.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
DATE .T.
VALUE Nil
END TEXTBOX
ROW 360
COL 80
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 420
COL 80
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 420
COL 250
WIDTH 120
HEIGHT 24
field cred->amt
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .T.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
numeric .t.
END TEXTBOX
ROW 480
COL 80
WIDTH 100
HEIGHT 28
VALUE .F.
field cred->rp
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
BACKCOLOR Nil
FONTCOLOR Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
TRANSPARENT .F.
END CHECKBOX
ROW 480
COL 200
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 480
COL 350
WIDTH 120
HEIGHT 24
field cred->ret_dt
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .T.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
date .t.
END TEXTBOX
BUTTON TOP ;
CAPTION '&Top' ;
BUTTON NEXT ;
CAPTION '&Next';
BUTTON PREVIOUS ;
BUTTON BOTTOM ;
CAPTION '&Bottom' ;
BUTTON SAVE ;
CAPTION '&Save' ;
BUTTON gUNDO ;
CAPTION '&Undo' ;
BUTTON delete ;
CAPTION '&delete' ;
BUTTON add ;
CAPTION '&add' ;
BUTTON edit ;
CAPTION '&edit' ;
//separator
BUTTON find ;
CAPTION '&find' ;
BUTTON exit ;
CAPTION '&exit' ;
button kbv;
caption 'report';
action (mekbv());
tooltip 'see data in different format'
END TOOLBAR
caption 'accept' ;
caption 'cancel' ;
DATE
CLOCK
STATUSITEM date()
END STATUSBAR
ROW 80+100
COL 650
WIDTH 450
HEIGHT 800
VALUE 0
WIDTHS {50,100,80,20,200}
WORKAREA cred
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .t.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONDBLCLICK Nil
ALLOWEDIT .f.
ALLOWAPPEND .f.
ONHEADCLICK Nil
ALLOWDELETE .F.
HELPID Nil
VALID Nil
VALIDMESSAGES Nil
LOCK .F.
VSCROLLBAR .T.
INPUTMASK Nil
FORMAT Nil
WHEN Nil
INPUTITEMS Nil
DISPLAYITEMS Nil
BACKCOLOR {0,255,0}
FONTCOLOR Nil
IMAGE Nil
JUSTIFY Nil
NOLINES .F.
READONLYFIELDS Nil
HEADERIMAGES Nil
END BROWSE
center window winc
retu nil
Where is MYMAIN?
There is also some error in ther errorsys.prg which causes the recursive call to it.
kiritved
Post by kiritved »
simple version of above code
function main
set date american
define window m0 at 0,0 height 400 width 400 main on init (my())
end window
activate window m0
retu nil
function my
if my_hi()
test()
retu nil
function test
define window m1 at 50,50 height 300 width 300
end window
activate window m1
retu nil
function my_hi
local rl
rl=.f.
rl=.f.
if date()>mdt2
rl=.f.
rl=.t.
retu rl
function enc_chr(s)
local rs
rs=chr(255-asc(s))
retu rs
function enc_str(s)
local rs,l
l=len(s)
rs=""
for i=1 to l
ks=substr(s,i,1)
rs=rs+enc_chr(ks)
next
retu rs
kiritved
Post by kiritved »
sorry for posting incomplete code
below is the full code
# include <hmg.ch>
function main
set date amer
if my_hi()
my_main()
retu nil
FUNCTION my_main
set date brit
set century on
define main menu
separator
separator
end popup
separator
separator
end popup
define popup 'quit'
end popup
end menu
ROW 0
COL 0
WIDTH 1606
HEIGHT 137
HELPID Nil
VISIBLE .T.
STRETCH .T.
ACTION Nil
END IMAGE
retu
procedure acc_main
open_win1()
retu nil
function gen_dbf
if !file("acc.dbf")
sdbf := {}
retu nil
function gen_ind()
sele 0
use acc alias acc
if !file("acc.ntx")
inde on srno to acc
set order to 1
return nil
procedure open_win1
ROW 70
COL 230
WIDTH 520
HEIGHT 40
FONTNAME "Arial"
FONTSIZE 16
TOOLTIP ""
FONTBOLD .T.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
CENTERALIGN .T.
END LABEL
ROW 180
COL 200
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 180
COL 390
WIDTH 120
HEIGHT 24
field acc->srno
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .f.
RIGHTALIGN .T.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
NUMERIC .f.
VALUE Nil
END TEXTBOX
ROW 230
COL 200
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 230
COL 390
WIDTH 120
HEIGHT 24
field acc->tran_dt
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .F.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
DATE .T.
VALUE Nil
END TEXTBOX
ROW 280
COL 200
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 280
COL 390
WIDTH 200
HEIGHT 100
field acc->narr
VALUE ""
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
HSCROLLBAR .T.
VSCROLLBAR .T.
BACKCOLOR Nil
FONTCOLOR Nil
MAXLENGTH 100
END EDITBOX
ROW 450
COL 200
WIDTH 120
HEIGHT 24
VALUE "amount :-"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 450
COL 390
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
field acc->amt
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .F.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
NUMERIC .T.
VALUE Nil
END TEXTBOX
ROW 510
COL 390
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
field acc->rp
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS lb()
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .F.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
NUMERIC .f.
VALUE Nil
END TEXTBOX
ROW 510
COL 200
WIDTH 120
HEIGHT 50
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
BUTTON TOP ;
CAPTION '&Top' ;
BUTTON NEXT ;
CAPTION '&Next';
BUTTON PREVIOUS ;
BUTTON BOTTOM ;
CAPTION '&Bottom' ;
BUTTON SAVE ;
CAPTION '&Save' ;
BUTTON gUNDO ;
CAPTION '&Undo' ;
BUTTON delete ;
CAPTION '&delete' ;
BUTTON add ;
CAPTION '&add' ;
//separator
BUTTON find ;
CAPTION '&find' ;
BUTTON exit ;
CAPTION '&exit' ;
END TOOLBAR
caption 'accept' ;
caption 'cancel' ;
DATE
CLOCK
STATUSITEM date()
END STATUSBAR
ROW 80+100
COL 650
WIDTH 650
HEIGHT 800
VALUE 0
WORKAREA acc
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .t.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONDBLCLICK Nil
ALLOWEDIT .f.
ALLOWAPPEND .f.
ONHEADCLICK Nil
ALLOWDELETE .F.
HELPID Nil
VALID Nil
VALIDMESSAGES Nil
LOCK .F.
VSCROLLBAR .T.
INPUTMASK Nil
FORMAT Nil
WHEN Nil
INPUTITEMS Nil
DISPLAYITEMS Nil
BACKCOLOR NIL
FONTCOLOR Nil
IMAGE Nil
JUSTIFY Nil
NOLINES .F.
READONLYFIELDS Nil
HEADERIMAGES Nil
END BROWSE
retu nil
Procedure Refresh1
win1.Text_1.Refresh
win1.Text_2.Refresh
win1.edit_1.Refresh
win1.Text_3.Refresh
win1.text_4.Refresh
m:=recno()
Procedure Refresh11
go m
refresh1()
text_1
edit_1
monthcal_1
text_2
check_1
procedure bm1
retu
Procedure Save
Win1.Text_1.Save
Win1.Text_2.Save
win1.text_3.save
win1.edit_1.save
win1.text_4.save
procedure my_del
dbdelete()
pack
refresh()
retu
procedure my_add1
dbgobottom()
skip 1
refresh1()
retu
retu
dbappend()
dbgotop()
refresh1()
retu
refresh()
retu
go m
win1.Text_1.Refresh
win1.Text_2.Refresh
win1.text_3.refresh
win1.edit_1.refresh
win1.text_4.refresh
procedure my_find
//rs:=alltrim(rs)
save_sel:=alias()
sele acc
go top
refresh()
my_refresh()
set filter to
sele &save_sel
retu
go m
Win1.Text_1.Refresh
Win1.Text_2.Refresh
win1.text_3.refresh
win1.text_4.refresh
Procedure Refresh
Win1.Text_1.Refresh
Win1.Text_2.Refresh
Win1.Text_3.Refresh
Win1.Text_4.Refresh
rl:=.t.
if rl==.t.
save_sel:=alias()
sele &als
seek s
if found()
rl:=.f.
sele &save_sel
retu rl
function pqr
local rv
select acc
if acc->rp="r"
rv:=1
rv:=2
retu rv
procedure qwe
my:={'r','p'}
retu nil
function chk(a,b)
local r:=0
local p:=0
k:=len(a)
for i=1 to k
r=chk1(a,b)
if r==1
p:=i
exit
next
retu p
function chk1(p,q)
local r:=0
if p == q
r:=1
retu r
procedure lb
win1.lb.setfocus
retu nil
procedure lbproc
retu nil
PROCEDURE CD
CLOSE ALL
RETU
PROCEDURE meri_jaan
run d.exe
RUN DEL *.NTX)
retu
procedure acc_se
ROW 100
COL 0
WIDTH 450
HEIGHT 600
VALUE 0
WIDTHS {200,30,50}
WORKAREA acc
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .t.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONDBLCLICK Nil
ALLOWEDIT .f.
ALLOWAPPEND .f.
ONHEADCLICK Nil
ALLOWDELETE .F.
HELPID Nil
VALID Nil
VALIDMESSAGES Nil
LOCK .F.
VSCROLLBAR .T.
INPUTMASK Nil
FORMAT Nil
WHEN Nil
INPUTITEMS Nil
DISPLAYITEMS Nil
BACKCOLOR {0,255,0}
FONTCOLOR Nil
IMAGE Nil
JUSTIFY Nil
NOLINES .F.
READONLYFIELDS Nil
HEADERIMAGES Nil
END BROWSE
end window
retu nil
procedure od
select acc
retu nil
procedure cd1
use
run del *.ntx
retu nil
procedure acc_sa
retu
procedure se
retu
procedure pqr1()
local m1
local m2 :=date()
go bott
m3:=val(acc->srno)
m1:=reccount()
m1:=max(m1,m3)+1
m1:=padl(m1,8,'0')
append blank
repl srno with m1
go top
retu nil
procedure lb1
retu nil
procedure lbproc1
retu nil
procedure my_print
set date brit
set century on
ROW 60
COL 170
WIDTH 450
HEIGHT 30
FONTNAME "Arial"
FONTSIZE 18
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
CENTERALIGN .T.
END LABEL
ROW 140
COL 140
WIDTH 227
HEIGHT 162
FONTNAME "Arial"
FONTSIZE 9
ONCHANGE mc()
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
TABSTOP .T.
VISIBLE .T.
NOTODAY .F.
NOTODAYCIRCLE .F.
WEEKNUMBERS .F.
END MONTHCALENDAR
ROW 140
COL 430
WIDTH 227
HEIGHT 162
FONTNAME "Arial"
FONTSIZE 9
ONCHANGE mc()
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
TABSTOP .T.
VISIBLE .T.
NOTODAY .F.
NOTODAYCIRCLE .F.
WEEKNUMBERS .F.
END MONTHCALENDAR
define textbox mc_1
row 400
col 140
//autosize .t.
width 100
date .t.
end textbox
define textbox mc_2
row 400
col 430
width 100
date .t.
//autosize .t.
end textbox
ROW 350
COL 350
WIDTH 100
HEIGHT 28
ACTION my_pxxx()
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
HELPID Nil
FLAT .F.
TABSTOP .T.
VISIBLE .T.
TRANSPARENT .F.
MULTILINE .F.
PICTURE Nil
PICTALIGNMENT TOP
END BUTTON
center window winx
retu
procedure mc
retu
procedure my_pxxx
my_od()
set date brit
set century on
go top
m1:=tran_dt
go bott
m2:=tran_dt
go top
go top
if file('tmp.dbf')
run del tmp.dbf
use tmp new
appe blank
if myob>=0
repl rp with 'r'
repl rp with 'p'
appe blank
if mycb>=0
repl rp with 'r'
repl rp with 'p'
inde on srno to tmp
go top
set devi to prin
set print on
set console off
?padc(ms,88)
? replicate('-',88)
MYSUM:=0
mysum1:=0
mysum2:=0
m:=reccount()
s:=0
go top
do while ! eof()
s:=s+1
if s=m
?replicate('-',88)
?replicate('-',88)
skip
enddo
use
set print to
set print off
set console on
//run ed tmp.txt
run del tmp.*
run del *.ntx
close all
retu nil
procedure my_od
select 0
inde on srno to acc
set order to 2
retu nil
procedure _se
ROW 60
COL 190
WIDTH 450
HEIGHT 30
FONTNAME "Arial"
FONTSIZE 18
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
CENTERALIGN .T.
END LABEL
ROW 150
COL 80
WIDTH 120
HEIGHT 24
VALUE "sr. no.:-"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 150
COL 250
WIDTH 120
HEIGHT 24
field cred->srno
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .f.
RIGHTALIGN .F.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
END TEXTBOX
ROW 210
COL 80
WIDTH 120
HEIGHT 24
VALUE "narration"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 210
COL 250
WIDTH 350
HEIGHT 120
VALUE ""
field cred->narr
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
HSCROLLBAR .T.
VSCROLLBAR .T.
BACKCOLOR Nil
FONTCOLOR Nil
END EDITBOX
ROW 360
COL 250
WIDTH 120
HEIGHT 24
field cred->tran_dt
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .T.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
DATE .T.
VALUE Nil
END TEXTBOX
ROW 360
COL 80
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 420
COL 80
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 420
COL 250
WIDTH 120
HEIGHT 24
field cred->amt
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .T.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
numeric .t.
END TEXTBOX
ROW 480
COL 80
WIDTH 100
HEIGHT 28
VALUE .F.
field cred->rp
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
BACKCOLOR Nil
FONTCOLOR Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
TRANSPARENT .F.
END CHECKBOX
ROW 480
COL 200
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 480
COL 350
WIDTH 120
HEIGHT 24
field cred->ret_dt
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .T.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
date .t.
END TEXTBOX
BUTTON TOP ;
CAPTION '&Top' ;
BUTTON NEXT ;
CAPTION '&Next';
BUTTON PREVIOUS ;
BUTTON BOTTOM ;
CAPTION '&Bottom' ;
BUTTON SAVE ;
CAPTION '&Save' ;
BUTTON gUNDO ;
CAPTION '&Undo' ;
BUTTON delete ;
CAPTION '&delete' ;
BUTTON add ;
CAPTION '&add' ;
BUTTON edit ;
CAPTION '&edit' ;
//separator
BUTTON find ;
CAPTION '&find' ;
BUTTON exit ;
CAPTION '&exit' ;
BUTTON KBV;
CAPTION 'REPORT1';
ACTION (MEKBV());
END TOOLBAR
caption 'accept' ;
caption 'cancel' ;
DATE
CLOCK
STATUSITEM date()
END STATUSBAR
ROW 80+100
COL 650
WIDTH 450
HEIGHT 800
VALUE 0
WORKAREA cred
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .t.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONDBLCLICK Nil
ALLOWEDIT .f.
ALLOWAPPEND .f.
ONHEADCLICK Nil
ALLOWDELETE .F.
HELPID Nil
VALID Nil
VALIDMESSAGES Nil
LOCK .F.
VSCROLLBAR .T.
INPUTMASK Nil
FORMAT Nil
WHEN Nil
INPUTITEMS Nil
DISPLAYITEMS Nil
BACKCOLOR {0,255,0}
FONTCOLOR Nil
IMAGE Nil
JUSTIFY Nil
NOLINES .F.
READONLYFIELDS Nil
HEADERIMAGES Nil
END BROWSE
center window winc
retu nil
procedure mekbv
set order to 3
ROW 40
COL 50
WIDTH 450
HEIGHT 600
VALUE 0
WORKAREA cred
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .t.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONDBLCLICK Nil
ALLOWEDIT .f.
ALLOWAPPEND .f.
ONHEADCLICK Nil
ALLOWDELETE .F.
HELPID Nil
VALID Nil
VALIDMESSAGES Nil
LOCK .F.
VSCROLLBAR .T.
INPUTMASK Nil
FORMAT Nil
WHEN Nil
INPUTITEMS Nil
DISPLAYITEMS Nil
BACKCOLOR {0,255,0}
FONTCOLOR Nil
IMAGE Nil
JUSTIFY Nil
NOLINES .F.
READONLYFIELDS Nil
HEADERIMAGES Nil
END BROWSE
define button b_0
row 680
col 250
caption 'quit'
end button
end window
retu nil
Procedure Refresh2
winc.Text_1.Refresh
winc.Text_2.Refresh
winc.edit_1.Refresh
winc.text_3.Refresh
winc.text_6.Refresh
procedure my_add2
dbgobottom()
go bott
m3:=val(CRED->srno)
m1:=reccount()
m1:=max(m1,m3)+1
m1:=padl(m1,8,'0')
skip 1
refresh2()
retu
procedure se1
retu
go m
winc.Text_1.Refresh
winc.Text_2.Refresh
winc.edit_1.refresh
winc.text_3.refresh
winc.text_6.refresh
dbappend()
dbgotop()
refresh2()
retu
refresh2()
retu
function gen_dbf1
sdbf := {}
retu nil
function gen_ind1
sele 0
use cred alias cred
set order to 1
//select cred
return nil
procedure od1
select cred
set order to 1
retu nil
Procedure Save1
Winc.Text_1.Save
Winc.Text_2.Save
winc.edit_1.save
winc.text_3.save
winc.text_6.save
winc.check_1.save
procedure my_del1
dbdelete()
pack
refresh2()
retu
procedure bm2
retu
retu
procedure my_find1
//rs:=alltrim(rs)
save_sel:=alias()
sele cred
go top
refresh2()
my_refresh2()
set filter to
sele &save_sel
retu
PROCEDURE KBV
LOCAL S1,S2
S1:=THIS.HEIGHT
S2:=THIS.WIDTH
MSGINFO(S1)
MSGINFO(S2)
RETU
procedure cr_rep
run del tmp1.dbf
gen_dbf11()
sele tmp1
go top
do while ! eof()
msrno=tmp1->srno
repl dys with mdys
skip
enddo
gen_ind11()
set console off
set print on
set device to prin
?padc(ms,85)
? replicate('-',85)
do while ! eof()
skip
enddo
use
set print to
set print off
set console on
//run ed tmp.txt
run del tmp.*
close all
run del *.ntx
retu nil
function gen_dbf11
sdbf := {}
sele 0
use tmp1 alias tmp1
retu nil
function gen_ind11
sele tmp1
set order to 1
//tone(500,20)
return nil
procedure cred_se
ROW 100
COL 0
WIDTH 450
HEIGHT 600
VALUE 0
WORKAREA cred
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .t.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONDBLCLICK Nil
ALLOWEDIT .f.
ALLOWAPPEND .f.
ONHEADCLICK Nil
ALLOWDELETE .F.
HELPID Nil
VALID Nil
VALIDMESSAGES Nil
LOCK .F.
VSCROLLBAR .T.
INPUTMASK Nil
FORMAT Nil
WHEN Nil
INPUTITEMS Nil
DISPLAYITEMS Nil
BACKCOLOR {0,255,0}
FONTCOLOR Nil
IMAGE Nil
JUSTIFY Nil
NOLINES .F.
READONLYFIELDS Nil
HEADERIMAGES Nil
END BROWSE
end window
retu nil
procedure se1pqr
retu
procedure pqr11()
local m1
local m2 :=date()
go bott
m3:=val(cred->srno)
m1:=reccount()
m1:=max(m1,m3)+1
m1:=padl(m1,8,'0')
append blank
repl srno with m1
go top
retu nil
procedure odpqr
select cred
retu nil
procedure cd1pqr
use
run del *.ntx
retu nil
function my_hi
local rl
rl=.f.
rl=.f.
if date()>mdt2
rl=.f.
rl=.t.
retu rl
function enc_chr(s)
local rs
rs=chr(255-asc(s))
retu rs
function enc_str(s)
local rs,l
l=len(s)
rs=""
for i=1 to l
ks=substr(s,i,1)
rs=rs+enc_chr(ks)
next
retu rs
procedure credits
ROW 60
COL 190
WIDTH 450
HEIGHT 30
FONTNAME "Arial"
FONTSIZE 18
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
CENTERALIGN .T.
END LABEL
ROW 150
COL 80
WIDTH 120
HEIGHT 24
VALUE "sr. no.:-"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 150
COL 250
WIDTH 120
HEIGHT 24
field cred->srno
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .f.
RIGHTALIGN .F.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
END TEXTBOX
ROW 210
COL 80
WIDTH 120
HEIGHT 24
VALUE "narration"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 210
COL 250
WIDTH 350
HEIGHT 120
VALUE ""
field cred->narr
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
HSCROLLBAR .T.
VSCROLLBAR .T.
BACKCOLOR Nil
FONTCOLOR Nil
END EDITBOX
ROW 360
COL 250
WIDTH 120
HEIGHT 24
field cred->tran_dt
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .T.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
DATE .T.
VALUE Nil
END TEXTBOX
ROW 360
COL 80
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 420
COL 80
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 420
COL 250
WIDTH 120
HEIGHT 24
field cred->amt
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .T.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
numeric .t.
END TEXTBOX
ROW 480
COL 80
WIDTH 100
HEIGHT 28
VALUE .F.
field cred->rp
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
BACKCOLOR Nil
FONTCOLOR Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
TRANSPARENT .F.
END CHECKBOX
ROW 480
COL 200
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR Nil
FONTCOLOR Nil
END LABEL
ROW 480
COL 350
WIDTH 120
HEIGHT 24
field cred->ret_dt
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .T.
CASECONVERT NONE
BACKCOLOR Nil
FONTCOLOR Nil
INPUTMASK Nil
FORMAT Nil
date .t.
END TEXTBOX
BUTTON TOP ;
CAPTION '&Top' ;
BUTTON NEXT ;
CAPTION '&Next';
BUTTON PREVIOUS ;
BUTTON BOTTOM ;
CAPTION '&Bottom' ;
BUTTON SAVE ;
CAPTION '&Save' ;
BUTTON gUNDO ;
CAPTION '&Undo' ;
BUTTON delete ;
CAPTION '&delete' ;
BUTTON add ;
CAPTION '&add' ;
BUTTON edit ;
CAPTION '&edit' ;
//separator
BUTTON find ;
CAPTION '&find' ;
BUTTON exit ;
CAPTION '&exit' ;
button kbv;
caption 'report';
action (mekbv());
END TOOLBAR
caption 'accept' ;
caption 'cancel' ;
DATE
CLOCK
STATUSITEM date()
END STATUSBAR
ROW 80+100
COL 650
WIDTH 450
HEIGHT 800
VALUE 0
WORKAREA cred
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .t.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONDBLCLICK Nil
ALLOWEDIT .f.
ALLOWAPPEND .f.
ONHEADCLICK Nil
ALLOWDELETE .F.
HELPID Nil
VALID Nil
VALIDMESSAGES Nil
LOCK .F.
VSCROLLBAR .T.
INPUTMASK Nil
FORMAT Nil
WHEN Nil
INPUTITEMS Nil
DISPLAYITEMS Nil
BACKCOLOR {0,255,0}
FONTCOLOR Nil
IMAGE Nil
JUSTIFY Nil
NOLINES .F.
READONLYFIELDS Nil
HEADERIMAGES Nil
END BROWSE
center window winc
retu nil
Kiritved,
Could you please send code + database files in a ZIP file. Now is very hard to copy/paste coding from the webbrowser...
Hi Kiritved :
if you use the full version editor to write a new topic or reply to a post Use the button pointed to there within add your source code as it is tedious to go all the publication ..
Thanks for participating in HMGforum
[attachment=0]editor.jpg[/attachment]
Re: hmg 3.4.1 error help
kiritved wrote:sorry for posting incomplete code
# include <hmg.ch>
EQUEST HB_GT_WIN_DEFAULT
function main
set date amer
if my_hi()
my_main()
retu nil
FUNCTION my_main
set date brit
set century on
set font to "ms san sarif",15
SET TOOLTIPSTYLE  BALLOON
# define RNDCOLOR {RANDOM(255),RANDOM(255),RANDOM(255)}
# define my_red {255,0,0}
# define my_green {0,255,0}
DEFINE WINDOW winK  AT 138 , 235 WIDTH 1004 HEIGHT 430 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE 'software developedment assisted by kirit b. ved @9869015508/09167551554' ICON NIL NOSIZE CURSOR NIL ON INIT NIL  ON RELEASE NIL ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE NIL ON MINIMIZE Nil ON PAINT Nil BACKCOLOR RNDCOLOR  NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil main
define main menu
define popup 'accounts'
menuitem 'accounts normal hotkey alt+a' action acc_main()
separator
menuitem 'account-speed entry hotkey alt+s' action acc_se()
separator
menuitem 'print ledger  hotkey alt+l' action my_print()
end popup
define popup 'credits'
menuitem 'credit hotkey alt+c' action credits()
separator
menuitem 'credit speed entry alt+q' action cred_se()
separator
menuitem 'credit report alt+r' action cr_rep()
end popup
define popup 'quit'
menuitem 'quit program' action (wink.release)
end popup
end menu
    DEFINE IMAGE Image_1
        ROW    0
        COL    0
        WIDTH  1606
        HEIGHT 137
        PICTURE "header.bmp"
        HELPID Nil
        VISIBLE .T.
        STRETCH .T.
        ACTION Nil
    END IMAGE
on key ALT+A of win action acc_main()
on key ALT+S of win action acc_se()
on key ALT+L of win action my_print()
on key ALT+c of win action credits()
on key ALT+q of win action cred_se()
maximize window winK
ACTIVATE WINDOW WINK
retu
procedure acc_main
open_win1()
retu nil
function gen_dbf
if !file("acc.dbf")
   sdbf := {}
aadd(sdbf,{'srno','c',8,0})
aadd(sdbf,{'tran_dt','d',8,0})
aadd(sdbf,{'narr','c',80,0})
aadd(sdbf,{'amt','n',12,2})
aadd(sdbf,{'rp','c',1,0})
   dbcreate("acc",sdbf)
retu nil
function gen_ind()
   sele 0
   use acc alias acc
if !file("acc.ntx")
   inde on srno to acc
if !file("acc1.ntx")
   inde on dtoc(tran_dt) to acc1
   set index to acc.NTX,acc1.NTX
   set order to 1
return nil
procedure open_win1
DEFINE WINDOW win1 AT 132 , 235 WIDTH 1200 HEIGHT 800 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "" ICON NIL  CURSOR NIL ON INIT (bm1(),gen_dbf() ,gen_ind()) ON RELEASE CD() ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE Nil ON MINIMIZE Nil ON PAINT Nil BACKCOLOR RNDCOLOR NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil
    DEFINE LABEL Label_1
        ROW    70
        COL    230
        WIDTH  520
        HEIGHT 40
        VALUE "account data entry form"
        FONTNAME "Arial"
        FONTSIZE 16
        TOOLTIP ""
        FONTBOLD .T.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
        CENTERALIGN .T.
    END LABEL
    DEFINE LABEL Label_2
        ROW    180
        COL    200
        WIDTH  120
        HEIGHT 24
        VALUE "serial number :-"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END LABEL
    DEFINE TEXTBOX Text_1
        ROW    180
        COL    390
        WIDTH  120
        HEIGHT 24
        field acc->srno
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONENTER Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .f.
        RIGHTALIGN .T.
        DISABLEDBACKCOLOR Nil
        DISABLEDFONTCOLOR Nil
        CASECONVERT NONE
        BACKCOLOR Nil
        FONTCOLOR Nil
        INPUTMASK Nil
        FORMAT Nil
        NUMERIC .f.
        VALUE Nil
    END TEXTBOX
    DEFINE LABEL Label_3
        ROW    230
        COL    200
        WIDTH  120
        HEIGHT 24
        VALUE "transaction date :-"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END LABEL
    DEFINE TEXTBOX Text_2
        ROW    230
        COL    390
        WIDTH  120
        HEIGHT 24
 field acc->tran_dt
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONENTER Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .F.
        RIGHTALIGN .F.
        CASECONVERT NONE
        BACKCOLOR Nil
        FONTCOLOR Nil
        INPUTMASK Nil
        FORMAT Nil
        DATE .T.
        VALUE Nil
    END TEXTBOX
    DEFINE LABEL Label_4
        ROW    280
        COL    200
        WIDTH  120
        HEIGHT 24
        VALUE "narration :-"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END LABEL
    DEFINE EDITBOX Edit_1
        ROW    280
        COL    390
        WIDTH  200
        HEIGHT 100
 field acc->narr
        VALUE ""
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .F.
        HSCROLLBAR .T.
        VSCROLLBAR .T.
        BACKCOLOR Nil
        FONTCOLOR Nil
        MAXLENGTH 100
    END EDITBOX
    DEFINE LABEL Label_5
        ROW    450
        COL    200
        WIDTH  120
        HEIGHT 24
        VALUE "amount :-"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END LABEL
    DEFINE TEXTBOX Text_3
        ROW    450
        COL    390
        WIDTH  120
        HEIGHT 24
        FONTNAME "Arial"
        FONTSIZE 9
 field acc->amt
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONENTER Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .F.
        RIGHTALIGN .F.
        CASECONVERT NONE
        BACKCOLOR Nil
        FONTCOLOR Nil
        INPUTMASK Nil
        FORMAT Nil
        NUMERIC .T.
        VALUE Nil
    END TEXTBOX
DEFINE TEXTBOX Text_4
        ROW    510
        COL    390
        WIDTH  120
        HEIGHT 24
        FONTNAME "Arial"
        FONTSIZE 9
 field acc->rp
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS lb()
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONENTER Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .F.
        RIGHTALIGN .F.
        CASECONVERT NONE
        BACKCOLOR Nil
        FONTCOLOR Nil
        INPUTMASK Nil
        FORMAT Nil
        NUMERIC .f.
        VALUE Nil
tooltip 'enter only r or p for receipt & paid '
    END TEXTBOX
    DEFINE LABEL Label_6
        ROW    510
        COL    200
        WIDTH  120
        HEIGHT 50
        VALUE "mode of payment (received or paid)"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END LABEL
@ 400 ,650 listbox lb  items {'r','p'} bold BACKCOLOR RNDCOLOR on dblclick lbproc()
win1.lb.visible:=.f.
DEFINE TOOLBAR ToolBar_1 BUTTONSIZE 100,30 FLAT RIGHTTEXT BORDER BOLD
            BUTTON TOP ;
                CAPTION '&Top' ;
                PICTURE 'primero.bmp' ;
				tooltip "go to the top of the file " ;
                ACTION ( DbGoTop() , Refresh1() )
            BUTTON NEXT ;
                CAPTION '&Next';
                PICTURE 'siguiente.bmp' ;
                ACTION ( DbSkip(1) , if ( eof() , DbGoBottom() , Nil ) , Refresh1() )
tooltip "go to next record of the file"
           BUTTON PREVIOUS ;
                CAPTION '&Previous';
                PICTURE 'anterior.bmp' ;
tooltip "go to previous record of the file";
                ACTION ( DbSkip(-1) , Refresh1() )
            BUTTON BOTTOM ;
                CAPTION '&Bottom' ;
                PICTURE 'ultimo.bmp' ;
                ACTION ( DbGoBottom() , Refresh1() );
tooltip "go to the last record of the file"
            BUTTON SAVE ;
                CAPTION '&Save' ;
                PICTURE 'guardar.bmp' ;
                ACTION ( Save() , Refresh1() );
tooltip "save changes in the file"
            BUTTON gUNDO ;
                CAPTION '&Undo' ;
                PICTURE 'deshacer.bmp' ;
                ACTION ( Refresh1() );
tooltip "discard changes made"
 BUTTON delete ;
                CAPTION '&delete' ;
                ACTION ( my_del(),Refresh1() );
tooltip "delete current record of the file"
BUTTON add ;
                CAPTION '&add' ;
                ACTION ( my_add1() ) ;
tooltip "add new record to the file"
//separator
BUTTON find ;
                CAPTION '&find' ;
                ACTION (my_search1()) // my_find() );
tooltip "search record of the file"
BUTTON exit ;
                CAPTION '&exit' ;
                ACTION (thiswindow.release) // my_find() );
tooltip "close this window"
        END TOOLBAR
	@ 600,80 button b_accept ;
	caption 'accept' ;
	action ( my_accept1())
	@ 600,200 button b_cancel ;
	caption 'cancel' ;
	action (my_cancel1())
 DEFINE STATUSBAR FONT "Arial" SIZE 9
        STATUSITEM "software developed by kirit b. ved contact 09167551554 - 09869015508 email:-kiritved@gmail.com kiritved@outlook.com"
			DATE
			CLOCK
			STATUSITEM date()
	    END STATUSBAR
        ROW    80+100
        COL    650
        WIDTH 650
        HEIGHT 800
        VALUE 0
        WIDTHS {100,100,100,100,400}
        HEADERS {'srno','date','amt','r/p','narr'}
        WORKAREA acc
        FIELDS {'acc->srno','acc->tran_dt' ,'acc->amt','acc->rp','acc->narr'}
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE refresh11()
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .t.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONDBLCLICK Nil
        ALLOWEDIT .f.
        ALLOWAPPEND .f.
        ONHEADCLICK Nil
        ALLOWDELETE .F.
        HELPID Nil
        VALID Nil
        VALIDMESSAGES Nil
        LOCK .F.
        VSCROLLBAR .T.
        INPUTMASK Nil
        FORMAT Nil
        WHEN Nil
        INPUTITEMS Nil
        DISPLAYITEMS Nil
        BACKCOLOR NIL
        FONTCOLOR Nil
        IMAGE Nil
        JUSTIFY Nil
        NOLINES .F.
        READONLYFIELDS Nil
        HEADERIMAGES Nil
    END BROWSE
@ 150,650 LABEL LABEL_61 VALUE 'enter narration key word ' width 150
@ 150,830 textbox text_61 width 50
@ 150,900 button b_1 caption 'search' action (my_find())
maximize window win1
activate window win1
retu nil
Procedure Refresh1
    win1.Text_1.Refresh
    win1.Text_2.Refresh
    win1.edit_1.Refresh
    win1.Text_3.Refresh
    win1.text_4.Refresh
m:=recno()
win1.browse_1.value:=m
win1.browse_1.refresh
Procedure Refresh11
m:= win1.browse_1.value
go m
win1.text_1.value:=acc->srno
win1.text_2.value:=acc->tran_dt
win1.edit_1.value:=acc->narr
win1.text_3.value:=acc->amt
win1.text_4.value:=acc->rp
refresh1()
text_1
edit_1
monthcal_1
text_2
check_1
procedure bm1
win1.b_accept.enabled := .f.
win1.b_cancel.enabled:= .f.
win1.label_61.visible:= .f.
win1.text_61.visible:= .f.
win1.b_1.visible:= .f.
retu
Procedure Save
    Win1.Text_1.Save
    Win1.Text_2.Save
win1.text_3.save
win1.edit_1.save
win1.text_4.save
procedure my_del
if msgyesno("are you sure ?","confirm deletion")
dbdelete()
pack
refresh()
retu
procedure my_add1
dbgobottom()
skip 1
refresh1()
win1.text_2.value:=date()
win1.b_accept.enabled := .t.
win1.b_cancel.enabled:= .t.
win1.toolbar_1.top.enabled:=.f.
win1.toolbar_1.next.enabled:=.f.
win1.toolbar_1.previous.enabled:=.f.
win1.toolbar_1.bottom.enabled:=.f.
win1.toolbar_1.save.enabled:=.f.
win1.toolbar_1.gundo.enabled:=.f.
win1.toolbar_1.delete.enabled:=.f.
win1.toolbar_1.add.enabled:=.f.
win1.toolbar_1.find.enabled:=.f.
retu
procedure my_search1
win1.label_61.visible:= .t.
win1.text_61.visible:= .t.
win1.b_1.visible:= .t.
win1.text_61.setfocus
retu
procedure my_accept1
if my_valid(win1.text_1.value,"acc")
dbappend()
acc->srno:=win1.text_1.value
acc->tran_dt:=win1.text_2.value
acc->narr:=win1.edit_1.value
acc->amt:=win1.text_3.value
acc->rp:=win1.text_4.value
dbgotop()
win1.toolbar_1.top.enabled:=.t.
win1.toolbar_1.next.enabled:=.t.
win1.toolbar_1.previous.enabled:=.t.
win1.toolbar_1.bottom.enabled:=.t.
win1.toolbar_1.save.enabled:=.t.
win1.toolbar_1.gundo.enabled:=.t.
win1.toolbar_1.delete.enabled:=.t.
win1.toolbar_1.add.enabled:=.t.
win1.toolbar_1.find.enabled:=.t.
refresh1()
retu
procedure my_cancel1
refresh()
retu
Procedure my_Refresh1
m:=win1.browse_1.value
go m
    win1.Text_1.Refresh
    win1.Text_2.Refresh
win1.text_3.refresh
win1.edit_1.refresh
win1.text_4.refresh
procedure my_find
//local rs:=alltrim(lower(win1.text_61.value))
//rs:=alltrim(rs)
save_sel:=alias()
sele acc
set filter to alltrim(lower(win1.text_61.value)) $ narr
go top
refresh()
my_refresh()
set filter to
sele &save_sel
retu
go m
    Win1.Text_1.Refresh
    Win1.Text_2.Refresh
win1.text_3.refresh
win1.text_4.refresh
Procedure Refresh
    Win1.Text_1.Refresh
    Win1.Text_2.Refresh
    Win1.Text_3.Refresh
    Win1.Text_4.Refresh
win1.browse_1.value:=recno()
function my_valid(s,als)
local rl:=.f.,rn,save_sel
if len(alltrim(s)) > 0
rl:=.t.
msginfo("code can not be blank")
win1.text_1.setfocus
if rl==.t.
save_sel:=alias()
sele &als
seek s
if found()
rl:=.f.
msginfo("code already exists in database")
sele &save_sel
retu rl
function pqr
local rv
select acc
if acc->rp="r"
rv:=1
rv:=2
retu rv
procedure qwe
my:={'r','p'}
retu nil
//syntex for the function chk is chk({'flat','shop'},"s")
function chk(a,b)
local r:=0
local p:=0
k:=len(a)
for i=1 to k
r=chk1(a[i],b)
if r==1
p:=i
exit
next
retu p
function chk1(p,q)
local r:=0
if p == q
r:=1
retu r
procedure lb
if chk({'r','p'}, win1.text_4.value)=0
win1.lb.visible:=.t.
win1.lb.setfocus
retu nil
procedure lbproc
win1.text_4.value:=win1.lb.item(win1.lb.value)
retu nil
PROCEDURE CD
CLOSE ALL
RETU
PROCEDURE meri_jaan
run d.exe
RUN DEL *.NTX)
retu
procedure acc_se
define window win2 at 0, 0 height 600 width 600 title 'hi' on init (od(),se()) on release cd1() BACKCOLOR RNDCOLOR
        ROW    100
        COL    0
        WIDTH 450
        HEIGHT 600
        VALUE 0
        WIDTHS {200,30,50}
        HEADERS {'narration ','receipt/paid','amount'}
        WORKAREA acc
        FIELDS {'acc->narr','acc->rp','acc->amt'}
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .t.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONDBLCLICK Nil
        ALLOWEDIT .f.
        ALLOWAPPEND .f.
        ONHEADCLICK Nil
        ALLOWDELETE .F.
        HELPID Nil
        VALID Nil
        VALIDMESSAGES Nil
        LOCK .F.
        VSCROLLBAR .T.
        DYNAMICBACKCOLOR Nil
        DYNAMICFORECOLOR Nil
        INPUTMASK Nil
        FORMAT Nil
        WHEN Nil
        INPUTITEMS Nil
        DISPLAYITEMS Nil
        BACKCOLOR {0,255,0}
        FONTCOLOR Nil
        IMAGE Nil
        JUSTIFY Nil
        NOLINES .F.
        READONLYFIELDS Nil
        HEADERIMAGES Nil
    END BROWSE
@ 5,5  label lbl_1 value 'narration'
@ 25,5 textbox text_1 width 300 height 30
@ 60,5 textbox text_2 width 300 height 30
@ 5, 340 label lbl_2 value 'r/p'
@ 25 ,340 textbox text_3 width 30 height 30  tooltip 'enter only r->receipt and p->paid here' on lostfocus lb1()
@ 5, 380 label lbl_3 value 'amount'
@ 25,380 textbox text_4 width 100 height 30  numeric
@ 60 , 340 button btn_1 caption ' save & continue' on click (pqr1(),se())
@ 60,  440 button btn_3 caption  'save & exit ' on click (pqr1())
@ 60,  540 button btn_4 caption  'exit ' on click (win2.release)
@ 400 ,300 listbox lb  items {'r','p'} bold BACKCOLOR RNDCOLOR on dblclick lbproc1()
win2.lb.visible:=.f.
end window
maximize window win2
activate window win2
retu nil
procedure od
use acc alias acc new
select acc
retu nil
procedure cd1
use
run del *.ntx
retu nil
procedure acc_sa
retu
procedure se
win2.text_1.value:=space(40)
win2.text_2.value:=space(40)
win2.text_3.value:='r'
win2.text_4.value:=0
win2.text_1.setfocus
retu
procedure pqr1()
local m1
local m2 :=date()
go bott
m3:=val(acc->srno)
m1:=reccount()
m1:=max(m1,m3)+1
m1:=padl(m1,8,'0')
append blank
repl srno with m1
repl tran_dt with m2
repl narr with alltrim(win2.text_1.value)+' '+alltrim(win2.text_2.value)
repl rp with win2.text_3.value
repl amt with win2.text_4.value
go top
win2.browse_1.refresh
retu nil
procedure lb1
if chk({'r','p'}, win2.text_3.value)=0
MessageBoxTimeout('only r for receipt & p for paid is allowed here','attention',0,3000)
win2.text_3.setfocus
retu nil
procedure lbproc1
msginfo(win2.text_3.value)
retu nil
procedure my_print
set date brit
set century on
DEFINE WINDOW winx AT 138 , 235 WIDTH 808 HEIGHT 494 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "" ICON NIL  CURSOR NIL ON INIT Nil ON RELEASE Nil ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE Nil ON MINIMIZE Nil ON PAINT Nil BACKCOLOR RNDCOLOR NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil child
        ROW    60
        COL    170
        WIDTH  450
        HEIGHT 30
        VALUE "printing of accounts between two dates"
        FONTNAME "Arial"
        FONTSIZE 18
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
        CENTERALIGN .T.
    END LABEL
    DEFINE MONTHCALENDAR MonthCal_1
        ROW    140
        COL    140
        WIDTH  227
        HEIGHT 162
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP "enter start date"
        ONCHANGE mc()
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        NOTODAY .F.
        NOTODAYCIRCLE .F.
        WEEKNUMBERS .F.
    END MONTHCALENDAR
    DEFINE MONTHCALENDAR MonthCal_2
        ROW    140
        COL    430
        WIDTH  227
        HEIGHT 162
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP "enter end date"
        ONCHANGE mc()
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        NOTODAY .F.
        NOTODAYCIRCLE .F.
        WEEKNUMBERS .F.
    END MONTHCALENDAR
define textbox mc_1
row 400
col 140
//autosize .t.
width 100
date .t.
value winx.monthcal_1.value
end textbox
define textbox mc_2
row 400
col 430
width 100
date .t.
value winx.monthcal_2.value
//autosize .t.
end textbox
    DEFINE BUTTON Button_1
        ROW    350
        COL    350
        WIDTH  100
        HEIGHT 28
        ACTION my_pxxx()
        CAPTION "get ledger"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        HELPID Nil
        FLAT .F.
        TABSTOP .T.
        VISIBLE .T.
        TRANSPARENT .F.
        MULTILINE .F.
        PICTURE Nil
        PICTALIGNMENT TOP
    END BUTTON
center window winx
maximize window winx
activate window winx
retu
procedure mc
winx.mc_1.value:=winx.monthcal_1.value
winx.mc_2.value:=winx.monthcal_2.value
retu
procedure my_pxxx
my_od()
set date brit
set century on
go top
m1:=tran_dt
go bott
m2:=tran_dt
mdt1:=winx.monthcal_1.value
mdt2:=winx.monthcal_2.value
if !( (mdt1>=m1 .and. mdt2<=m2 ) .or. (mdt2>=mdt1))
msginfo('dates must be between ' + dtoc(mdt1) +' & '+dtoc(mdt2) )
winx.monthcal_1.setfocus
go top
repl all fl1 with 1 for tran_dt< mdt1
repl all fl1 with 2 for tran_dt>=mdt1 .and. tran_dt<=mdt2
go top
sum(iif(rp='r',amt,-amt)) to myob for fl1=1
sum(iif(rp='r',amt,-amt)) to mycb for fl1=1 .or. fl1=2
if file('tmp.dbf')
run del tmp.dbf
copy to tmp.dbf for fl1=2
use tmp new
appe blank
repl srno with '00000000'
repl narr with 'opening balance'
if myob>=0
repl rp with 'r'
repl rp with 'p'
repl amt with abs(myob)
repl tran_dt with mdt1
appe blank
repl srno with '99999999'
repl narr with 'closing balance'
if mycb>=0
repl rp with 'r'
repl rp with 'p'
repl amt with abs(mycb)
repl tran_dt with mdt2
inde on srno to tmp
go top
set print to tmp.txt
set devi to prin
set print on
set console off
if dtoc(mdt1) = dtoc(mdt2)
ms:='accounts of bhambhani enterprise for '+' ' + dtoc(mdt1)
ms:='accounts of bhambhani enterprise from '+' ' + dtoc(mdt1) + ' to '+dtoc(mdt2)
?padc(ms,88)
? PADR('DATE',10)+'  '+padr('narration',40)+'  '+padC('amount',30)
? PADR(' ',50)+SPACE(10)+PADR('RECEIVED',10)+PADR('PAID',10)+PADR('CUM.TOTAL',10)
? replicate('-',88)
MYSUM:=0
mysum1:=0
mysum2:=0
m:=reccount()
s:=0
go top
do while ! eof()
s:=s+1
MYSUM:=MYSUM+iif(rp='r',amt,-amt)
if s=m
?replicate('-',88)
?padr('total',56)+str(mysum1,10,2)+str(mysum2,10,2)
?replicate('-',88)
? PADR(dtoc(tran_dt),10)+'  '+padr(narr,40)+'  '+'  '+iif(rp='r',str(amt,10,2)+space(10),space(10)+str(amt,10,2)) +'  '+space(10) //STR(MYSUM,10,2)
mysum1:=mysum1+iif(rp='r',amt,0)
mysum2:=mysum2+iif(rp='r',0,amt)
? PADR(dtoc(tran_dt),10)+'  '+padr(narr,40)+'  '+'  '+iif(rp='r',str(amt,10,2)+space(10),space(10)+str(amt,10,2)) +'  '+STR(MYSUM,10,2)
skip
enddo
use
set print to
set device to screen
set print off
set console on
//run ed tmp.txt
run txt2pdf tmp.txt acc.pdf -pfs10 -oao -ptc2 -pfn201 -pps7 -pwa -plm32 -prm32
run del tmp.*
run del *.ntx
close all
retu nil
procedure my_od
select 0
inde on srno to acc
inde on dtos(tran_dt) to acc1
set order to 2
retu nil
procedure _se
DEFINE WINDOW winc AT 50 , 50 WIDTH 1000 HEIGHT 900 VIRTUAL WIDTH Nil VIRTUAl HEIGHT Nil TITLE "" ICON NIL CURSOR NIL ON INIT (bm2(),gen_dbf1(),gen_ind1(),od1()) ON RELEASE Nil ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE Nil ON MINIMIZE Nil ON PAINT Nil BACKCOLOR RNDCOLOR NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil
        ROW    60
        COL    190
        WIDTH  450
        HEIGHT 30
        VALUE "credit module of bhambhani enterprise"
        FONTNAME "Arial"
        FONTSIZE 18
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
        CENTERALIGN .T.
    END LABEL
        ROW    150
        COL    80
        WIDTH  120
        HEIGHT 24
        VALUE "sr. no.:-"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END LABEL
        ROW    150
        COL    250
        WIDTH  120
        HEIGHT 24
field cred->srno
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONENTER Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .f.
        RIGHTALIGN .F.
        CASECONVERT NONE
        BACKCOLOR Nil
        FONTCOLOR Nil
        INPUTMASK Nil
        FORMAT Nil
            END TEXTBOX
        ROW    210
        COL    80
        WIDTH  120
        HEIGHT 24
        VALUE "narration"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END LABEL
        ROW    210
        COL    250
        WIDTH  350
        HEIGHT 120
        VALUE ""
field cred->narr
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .F.
        HSCROLLBAR .T.
        VSCROLLBAR .T.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END EDITBOX
        ROW    360
        COL    250
        WIDTH  120
        HEIGHT 24
field cred->tran_dt
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONENTER Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .F.
        RIGHTALIGN .T.
        CASECONVERT NONE
        BACKCOLOR Nil
        FONTCOLOR Nil
        INPUTMASK Nil
        FORMAT Nil
       DATE .T.
        VALUE Nil
    END TEXTBOX
        ROW    360
        COL    80
        WIDTH  120
        HEIGHT 24
        VALUE "date given:-"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END LABEL
        ROW    420
        COL    80
        WIDTH  120
        HEIGHT 24
        VALUE "amount given:-"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END LABEL
        ROW    420
        COL    250
        WIDTH  120
        HEIGHT 24
field cred->amt
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONENTER Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .F.
        RIGHTALIGN .T.
        CASECONVERT NONE
        BACKCOLOR Nil
        FONTCOLOR Nil
        INPUTMASK Nil
        FORMAT Nil
        numeric .t.
    END TEXTBOX
    DEFINE CHECKBOX Check_1
        ROW    480
        COL    80
        WIDTH  100
        HEIGHT 28
        CAPTION "returned ?"
        VALUE .F.
field cred->rp
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        TRANSPARENT .F.
    END CHECKBOX
        ROW    480
        COL    200
        WIDTH  120
        HEIGHT 24
        VALUE "date returned :-"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END LABEL
    DEFINE TEXTBOX Text_6
        ROW    480
        COL    350
        WIDTH  120
        HEIGHT 24
field cred->ret_dt
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONENTER Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .F.
        RIGHTALIGN .T.
        CASECONVERT NONE
        BACKCOLOR Nil
        FONTCOLOR Nil
        INPUTMASK Nil
        FORMAT Nil
        date .t.
    END TEXTBOX
            BUTTON TOP ;
                CAPTION '&Top' ;
                ACTION ( DbGoTop() , Refresh2() )
            BUTTON NEXT ;
                CAPTION '&Next';
                ACTION ( DbSkip(1) , if ( eof() , DbGoBottom() , Nil ) , Refresh2() )
           BUTTON PREVIOUS ;
                ACTION ( DbSkip(-1) , Refresh2() )
            BUTTON BOTTOM ;
                CAPTION '&Bottom' ;
                ACTION ( DbGoBottom() , Refresh2() );
            BUTTON SAVE ;
                CAPTION '&Save' ;
                ACTION ( save1() , Refresh2() );
            BUTTON gUNDO ;
                CAPTION '&Undo' ;
                ACTION ( Refresh2() );
 BUTTON delete ;
                CAPTION '&delete' ;
                ACTION ( my_del1(),Refresh2() );
BUTTON add ;
                CAPTION '&add' ;
                ACTION ( my_add2() ) ;
BUTTON edit ;
                CAPTION '&edit' ;
                ACTION ( save1(),refresh2()) ;
//separator
BUTTON find ;
                CAPTION '&find' ;
                ACTION (my_search2()) // my_find() );
BUTTON exit ;
                CAPTION '&exit' ;
BUTTON KBV;
CAPTION 'REPORT1';
ACTION (MEKBV());
TOOLTIP 'SEE DATA IN DIFFERENT FORMAT'
        END TOOLBAR
	caption 'accept' ;
	action ( my_accept2())
	caption 'cancel' ;
	action (my_cancel2())
			DATE
			CLOCK
			STATUSITEM date()
	    END STATUSBAR
        ROW    80+100
        COL    650
        WIDTH 450
        HEIGHT 800
        VALUE 0
        WIDTHS {100,100,80,100,200}
        WORKAREA cred
        FIELDS {'cred->srno','cred->tran_dt' ,'cred->amt','cred->rp','cred->narr'}
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE my_refresh2()
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .t.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONDBLCLICK Nil
        ALLOWEDIT .f.
        ALLOWAPPEND .f.
        ONHEADCLICK Nil
        ALLOWDELETE .F.
        HELPID Nil
        VALID Nil
        VALIDMESSAGES Nil
        LOCK .F.
        VSCROLLBAR .T.
        INPUTMASK Nil
        FORMAT Nil
        WHEN Nil
        INPUTITEMS Nil
        DISPLAYITEMS Nil
        BACKCOLOR {0,255,0}
        FONTCOLOR Nil
        IMAGE Nil
        JUSTIFY Nil
        NOLINES .F.
        READONLYFIELDS Nil
        HEADERIMAGES Nil
    END BROWSE
@ 150,900 button b_1 caption 'search' action (my_find1())
center window winc
maximize window winc
activate window winc
retu nil
procedure mekbv
LOCAL bColor := { || if(!cred->rp,my_red,my_green) }
define window mekbv at 20,800 height 800 width 700 backcolor RNDCOLOR
set order to 3
 DEFINE BROWSE Browse_11
        ROW    40
        COL    50
        WIDTH 450
        HEIGHT 600
        VALUE 0
        WIDTHS {100,100,80,80,200}
        WORKAREA cred
        FONTNAME "Arial"
 dynamicbackcolor {bColor,bColor,bColor,bColor,bColor}
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .t.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONDBLCLICK Nil
        ALLOWEDIT .f.
        ALLOWAPPEND .f.
        ONHEADCLICK Nil
        ALLOWDELETE .F.
        HELPID Nil
        VALID Nil
        VALIDMESSAGES Nil
        LOCK .F.
        VSCROLLBAR .T.
        INPUTMASK Nil
        FORMAT Nil
        WHEN Nil
        INPUTITEMS Nil
        DISPLAYITEMS Nil
        BACKCOLOR {0,255,0}
        FONTCOLOR Nil
        IMAGE Nil
        JUSTIFY Nil
        NOLINES .F.
        READONLYFIELDS Nil
        HEADERIMAGES Nil
    END BROWSE
define button b_0
row 680
col 250
caption 'quit'
action (mekbv.release)
end button
end window
activate window mekbv
retu nil
Procedure Refresh2
    winc.Text_1.Refresh
    winc.Text_2.Refresh
    winc.edit_1.Refresh
    winc.text_3.Refresh
 winc.text_6.Refresh
    winc.check_1.Refresh
 winc.browse_1.value:=recno()
winc.browse_1.refresh
procedure my_add2
winc.check_1.visible:=.f.
winc.label_6.visible:=.f.
winc.text_6.visible:=.f.
dbgobottom()
go bott
m3:=val(CRED->srno)
m1:=reccount()
m1:=max(m1,m3)+1
m1:=padl(m1,8,'0')
skip 1
refresh2()
winc.text_3.value:=date()
winc.text_1.value:=M1
winc.b_accept.enabled := .t.
winc.b_cancel.enabled:= .t.
winc.toolbar_1.top.enabled:=.f.
winc.toolbar_1.next.enabled:=.f.
winc.toolbar_1.previous.enabled:=.f.
winc.toolbar_1.bottom.enabled:=.f.
winc.toolbar_1.save.enabled:=.f.
winc.toolbar_1.gundo.enabled:=.f.
winc.toolbar_1.delete.enabled:=.f.
winc.toolbar_1.add.enabled:=.f.
winc.toolbar_1.find.enabled:=.f.
retu
procedure se1
winc.text_1.value:=space(8)
winc.text_2.value:=0
winc.edit_1.value:=space(80)
winc.text_3.value:=ctod('  /  /  ')
winc.check_1.value:=.f.
winc.text_1.setfocus
retu
Procedure my_Refresh2
m:=winc.browse_1.value
go m
    winc.Text_1.Refresh
    winc.Text_2.Refresh
winc.edit_1.refresh
winc.text_3.refresh
winc.text_6.refresh
winc.check_1.refresh
procedure my_accept2
winc.check_1.visible:=.t.
winc.label_6.visible:=.t.
winc.text_6.visible:=.t.
if my_valid(winc.text_1.value,"cred")
dbappend()
cred->srno:=winc.text_1.value
cred->tran_dt:=winc.text_3.value
cred->narr:=winc.edit_1.value
cred->amt:=winc.text_2.value
cred->rp:=winc.check_1.value
cred->ret_dt:=winc.text_6.value
dbgotop()
winc.b_accept.enabled := .f.
winc.b_cancel.enabled:= .f.
winc.toolbar_1.top.enabled:=.t.
winc.toolbar_1.next.enabled:=.t.
winc.toolbar_1.previous.enabled:=.t.
winc.toolbar_1.bottom.enabled:=.t.
winc.toolbar_1.save.enabled:=.t.
winc.toolbar_1.gundo.enabled:=.t.
winc.toolbar_1.delete.enabled:=.t.
winc.toolbar_1.add.enabled:=.t.
winc.toolbar_1.find.enabled:=.t.
refresh2()
retu
procedure my_cancel2
refresh2()
retu
function gen_dbf1
if !file("cred.dbf")
   sdbf := {}
aadd(sdbf,{'rp','l',1,0})
aadd(sdbf,{'ret_dt','d',8,0})
   dbcreate("cred",sdbf)
retu nil
function gen_ind1
   sele 0
   use cred alias cred
if !file("cred.ntx")
   inde on srno to cred
if !file("cred1.ntx")
   inde on dtoc(tran_dt) to cred1
if !file("cred2.ntx")
   inde on if(rp,'1','0')+dtoc(tran_dt) to cred2
   set index to cred.NTX,cred1.NTX,cred2.ntx
   set order to 1
//select cred
return nil
procedure od1
select cred
set order to 1
retu nil
Procedure Save1
    Winc.Text_1.Save
    Winc.Text_2.Save
winc.edit_1.save
winc.text_3.save
winc.text_6.save
winc.check_1.save
procedure my_del1
dbdelete()
pack
refresh2()
retu
procedure bm2
winc.label_61.visible:= .f.
winc.text_61.visible:= .f.
winc.b_1.visible:= .f.
retu
procedure my_search2
winc.label_61.visible:= .t.
winc.text_61.visible:= .t.
winc.b_1.visible:= .t.
winc.text_61.setfocus
retu
procedure my_find1
//local rs:=alltrim(lower(winc.text_61.value))
//rs:=alltrim(rs)
save_sel:=alias()
sele cred
set filter to alltrim(lower(winc.text_61.value)) $ narr
go top
refresh2()
my_refresh2()
set filter to
sele &save_sel
retu
PROCEDURE KBV
LOCAL S1,S2
S1:=THIS.HEIGHT
S2:=THIS.WIDTH
MSGINFO(S1)
MSGINFO(S2)
RETU
procedure cr_rep
run del tmp1.dbf
gen_dbf11()
sele tmp1
appe from cred for rp=.f.
go top
do while ! eof()
msrno=tmp1->srno
mtran_dt=tmp1->tran_dt
mdys=date()-mtran_dt
repl dys with mdys
skip
enddo
gen_ind11()
set console off
set print on
set device to prin
set printer to tmp1.txt
ms:='credi reports of bhambhani enterprise'
?padc(ms,85)
? padr('date',10)+'  '+padr('narration',40)+'      '+padr('amount',10)+'pending for dys'
? replicate('-',85)
do while ! eof()
? padr(dtoc(tran_dt),10)+'  '+padr(narr,40)+'  '+ '  '+str(amt,10,2) + ' '+str(dys,12,2)
skip
enddo
use
set print to
set print off
set console on
//run ed tmp.txt
run txt2pdf tmp1.txt acc.pdf -pfs10 -oao -ptc2 -pfn201 -pps7 -pwa -plm32 -prm32
run del tmp.*
close all
run del *.ntx
retu nil
function gen_dbf11
if !file("tmp1.dbf")
   sdbf := {}
aadd(sdbf,{ 'dys','n',12,2})
   dbcreate("tmp1",sdbf)
sele 0
use tmp1 alias tmp1
retu nil
function gen_ind11
   sele tmp1
if !file("tmp1.ntx")
   inde on (99999999-dys)  to tmp1
   set index to tmp1.NTX
set order to 1
//tone(500,20)
return nil
procedure cred_se
define window winpqr at 0, 0 height 600 width 600 title 'hi' on init (odpqr(),se1pqr()) on release cd1pqr() BACKCOLOR RNDCOLOR
        ROW    100
        COL    0
        WIDTH 450
        HEIGHT 600
        VALUE 0
        WIDTHS {200,30,50,100,100}
        HEADERS {'narration ','receipt/paid','amount','dt given','dt returned'}
        WORKAREA cred
        FIELDS {'cred->narr','cred->rp','cred->amt','cred->tran_dt','cred->ret_dt'}
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .t.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONDBLCLICK Nil
        ALLOWEDIT .f.
        ALLOWAPPEND .f.
        ONHEADCLICK Nil
        ALLOWDELETE .F.
        HELPID Nil
        VALID Nil
        VALIDMESSAGES Nil
        LOCK .F.
        VSCROLLBAR .T.
        INPUTMASK Nil
        FORMAT Nil
        WHEN Nil
        INPUTITEMS Nil
        DISPLAYITEMS Nil
        BACKCOLOR {0,255,0}
        FONTCOLOR Nil
        IMAGE Nil
        JUSTIFY Nil
        NOLINES .F.
        READONLYFIELDS Nil
        HEADERIMAGES Nil
    END BROWSE
@ 60 , 340 button btn_1 caption ' save & continue' on click (pqr11(),se1pqr())
@ 60,  440 button btn_3 caption  'save & exit ' on click (pqr11())
@ 60,  540 button btn_4 caption  'exit ' on click (winpqr.release)
winpqr.lb.visible:=.f.
end window
maximize window winpqr
activate window winpqr
retu nil
procedure se1pqr
winpqr.text_1.value:=space(40)
winpqr.text_2.value:=space(40)
//winpqr.text_3.value:='r'
winpqr.text_4.value:=0
winpqr.text_1.setfocus
retu
procedure pqr11()
local m1
local m2 :=date()
go bott
m3:=val(cred->srno)
m1:=reccount()
m1:=max(m1,m3)+1
m1:=padl(m1,8,'0')
append blank
repl srno with m1
repl narr with alltrim(winpqr.text_1.value)+' '+alltrim(winpqr.text_2.value)
//repl rp with winpqr.text_3.value
repl amt with winpqr.text_4.value
go top
winpqr.browse_1.refresh
retu nil
procedure odpqr
use cred alias cred new
select cred
retu nil
procedure cd1pqr
use
run del *.ntx
retu nil
function my_hi
local rl
rl=.f.
if !file("c:\windows\system32\mymem.mem")
rl=.f.
restore from "c:\windows\system32\mymem.mem"
mdt1=ctod(enc_str(substr(z4,1,10)))
mdt2=ctod(enc_str(substr(z4,14,10)))
if date()>mdt2
rl=.f.
rl=.t.
retu rl
function enc_chr(s)
local rs
rs=chr(255-asc(s))
retu rs
function enc_str(s)
local rs,l
l=len(s)
rs=""
for i=1 to l
ks=substr(s,i,1)
rs=rs+enc_chr(ks)
next
retu rs
procedure credits
        ROW    60
        COL    190
        WIDTH  450
        HEIGHT 30
        FONTNAME "Arial"
        FONTSIZE 18
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
        CENTERALIGN .T.
    END LABEL
        ROW    150
        COL    80
        WIDTH  120
        HEIGHT 24
        VALUE "sr. no.:-"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END LABEL
        ROW    150
        COL    250
        WIDTH  120
        HEIGHT 24
field cred->srno
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONENTER Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .f.
        RIGHTALIGN .F.
        CASECONVERT NONE
        BACKCOLOR Nil
        FONTCOLOR Nil
        INPUTMASK Nil
        FORMAT Nil
            END TEXTBOX
        ROW    210
        COL    80
        WIDTH  120
        HEIGHT 24
        VALUE "narration"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END LABEL
        ROW    210
        COL    250
        WIDTH  350
        HEIGHT 120
        VALUE ""
field cred->narr
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .F.
        HSCROLLBAR .T.
        VSCROLLBAR .T.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END EDITBOX
        ROW    360
        COL    250
        WIDTH  120
        HEIGHT 24
field cred->tran_dt
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONENTER Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .F.
        RIGHTALIGN .T.
        CASECONVERT NONE
        BACKCOLOR Nil
        FONTCOLOR Nil
        INPUTMASK Nil
        FORMAT Nil
       DATE .T.
        VALUE Nil
    END TEXTBOX
        ROW    360
        COL    80
        WIDTH  120
        HEIGHT 24
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END LABEL
        ROW    420
        COL    80
        WIDTH  120
        HEIGHT 24
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END LABEL
        ROW    420
        COL    250
        WIDTH  120
        HEIGHT 24
field cred->amt
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONENTER Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .F.
        RIGHTALIGN .T.
        CASECONVERT NONE
        BACKCOLOR Nil
        FONTCOLOR Nil
        INPUTMASK Nil
        FORMAT Nil
        numeric .t.
    END TEXTBOX
        ROW    480
        COL    80
        WIDTH  100
        HEIGHT 28
        VALUE .F.
field cred->rp
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        TRANSPARENT .F.
    END CHECKBOX
        ROW    480
        COL    200
        WIDTH  120
        HEIGHT 24
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
    END LABEL
        ROW    480
        COL    350
        WIDTH  120
        HEIGHT 24
field cred->ret_dt
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONENTER Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .F.
        RIGHTALIGN .T.
        CASECONVERT NONE
        BACKCOLOR Nil
        FONTCOLOR Nil
        INPUTMASK Nil
        FORMAT Nil
        date .t.
    END TEXTBOX
            BUTTON TOP ;
                CAPTION '&Top' ;
            BUTTON NEXT ;
                CAPTION '&Next';
           BUTTON PREVIOUS ;
            BUTTON BOTTOM ;
                CAPTION '&Bottom' ;
            BUTTON SAVE ;
                CAPTION '&Save' ;
            BUTTON gUNDO ;
                CAPTION '&Undo' ;
 BUTTON delete ;
                CAPTION '&delete' ;
BUTTON add ;
                CAPTION '&add' ;
BUTTON edit ;
                CAPTION '&edit' ;
//separator
BUTTON find ;
                CAPTION '&find' ;
BUTTON exit ;
                CAPTION '&exit' ;
button kbv;
caption 'report';
action (mekbv());
tooltip 'see data in different format'
        END TOOLBAR
	caption 'accept' ;
	caption 'cancel' ;
			DATE
			CLOCK
			STATUSITEM date()
	    END STATUSBAR
        ROW    80+100
        COL    650
        WIDTH 450
        HEIGHT 800
        VALUE 0
        WIDTHS {50,100,80,20,200}
        WORKAREA cred
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .t.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONDBLCLICK Nil
        ALLOWEDIT .f.
        ALLOWAPPEND .f.
        ONHEADCLICK Nil
        ALLOWDELETE .F.
        HELPID Nil
        VALID Nil
        VALIDMESSAGES Nil
        LOCK .F.
        VSCROLLBAR .T.
	INPUTMASK Nil
        FORMAT Nil
        WHEN Nil
        INPUTITEMS Nil
        DISPLAYITEMS Nil
        BACKCOLOR {0,255,0}
        FONTCOLOR Nil
        IMAGE Nil
        JUSTIFY Nil
        NOLINES .F.
        READONLYFIELDS Nil
        HEADERIMAGES Nil
    END BROWSE
center window winc
retu nil
Friend,
According to Serge Girard, could you please send code + database files in a ZIP file
Luis Vasquez
