ErrorSys HMG Custom
pctoledo
ErrorSys HMG Custom
Post by pctoledo »
This function displays all the details about the error (runtime), with text (English) indicating the cause and possible solutions. There is also option to print or export to PDF.
CAUTION: To avoid multiple-definition message of ErrorSys () function, in the file BPH put the command -ldflag=-Wl,--allow-multiple-definition, then it is advisable to include this command, and the file in Hmg_Error.prg compilation list, only after making every test your program, with the above command in the HBP, any functions that are duplicated will not be alerted in the build.
Link Download
Toledo
Clipper On Line
Re: ErrorSys HMG Custom
pctoledo wrote:This function displays all the details about the error (runtime), with text (English) indicating the cause and possible solutions. There is also option to print or export to PDF.
Link Download
Very nice, thanks!
Thank you Toledo for sharing
Thx Toledo !
quartz565
Post by quartz565 »
Thank you Toledo !
Nikos.
os: Windows Server 2019 - 64
