Hello friends,
QR Code BarCode Generator doesn't work correctly for string (field) with more than 60 characters.
You can't read the QR code (png Picture).
Hmg 3.4.0\samples\hfcl\hmg_Zebra
The same was also in older HMG versions.
br Rado
Re: QR Code BarCode Generator
It seems that just some combinations doesn't work:
String OK:
2231750879236870751122344025289731667551234567815081510133212
String NOK:
If at the end is 2 , then is OK, without 2 doesn't work.
br rado
String OK:
String NOK:
br rado
Hola
Leyendo sobre el tema de los "QR Code", me encontré esta liga donde habla
que se pueden leer estos tipos de código con la WebCam.
No se si el Dr. Soto pudiera revisarlo y ver si es posible tener esa funcionalidad en HMG.
Hello
I read about the "QR Code", I found this link which talks
you can read these types of code with the WebCam.
Not if Dr. Soto could review it and see if we can have that functionality in HMG.
http://geeks.ms/blogs/cpsaez/archive/20 ... ebcam.aspx
Hello
hfcl\hmg_Zebra is only a wrapper for \hmg.3.4.2\HARBOUR\contrib\hbzebra.
So, we can ask Harbour Community.
