phone book with sqlite
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
My first project with sqlite base, phone book
phone.zip
(24.83 KiB) Downloaded 497 times
Re: phone book with sqlite
Thanks Dragan, I will take a look at it soon !
Dragan,
Please supply HBP file!
dragancesu
It is not necessary, just
build phone.prg
I think, you should build file phone.hbp and put there one line
phone.prg
Then run IDE and in Configuration tab, add one line:
libs=sqlite3
When I've tried add new records, some problems with sql update occurs.
When you try to edit record, you should fill fields for edition - I get empty fields.
It is working fine for me.
Good work done. Thanks a lot for sharing.
Gracias dragancesu
Thanks dragancesu
mol wrote: When you try to edit record, you should fill fields for edition - I get empty fields.
Me pasa igual
the same happens to me
Y con Find / Query da lo siguiente:
And with Find / Query gives the following:
