HMG 2.8.6f error
salamandra
DBs Used: DBF, MySQL, SQL
HMG 2.8.6f error
Post by salamandra »
:) Hi to all,
I don't know if it's a bug in HMGIde 2.8.6f or not.
Error occurred when saving a form that was being edited.
[]'s Salamandra.
:) Hola a todos,
Realmente no se si se trata de un bug en HMGIde 2.8.6f o no.
El error ocurrio al salvar un Form que estaba siendo editado.
[]'s Salamandra
Re: HMG 2.8.6f error
salamandra wrote::) Hi to all,
[]'s Salamandra.
:) Hola a todos,
[]'s Salamandra
Please, post the form that give you this error and the exact circumstances to generate it.
TIA.
salamandra
:) Hi Roberto,
The form (attached) was edited without problems many times.
But yesterday, I'd need to resize it and change some controls color & size.
After change controls and save the form... no problem.
After resize form and save....crash!!!
After this crash, I'd edited and saved the same form 4 or 5 times and no more
crashes ......
Very strange error...
[]'s Salamandra.
:) Hola Roberto,
Este Form (anexado) ya fue editado muchas veces sin ningun problema.
Mas ayer, necesité alterar el tamanho del Form y el color y el tamaño de algunos controles.
Después de alterar los controles, consegui salvar el form sin problemas.
Después de alterar el tamaño del form, salve nuevamente y......crash !!!
Mas tarde, edite el mismo form unas 4 o 5 veces y no tube ningun otro
problema.
Error muy estraño ese...
[]'s Salamandra
fp_main.rar
(3.26 KiB) Downloaded 886 times
Can you please attach a sample project file in full to re-generate the error?
Thanks.
salamandra
;) Hi rathi,
It's not a runtime error of the program that uses the form...
It's a random error that occurs when you edit and save the form
using HMGIde 2.8.6f.
[]'s Salamandra
;) Hola rathi,
No se trata de un error de runtime del programa que usa este form...
Se trata de um error que ocurre aleatoriamente al editar y salvar
el form en HMGIde 2.8.6f.
[]'s Salamandra
salamandra wrote::) Hi Roberto,
crashes ......
[]'s Salamandra.
:) Hola Roberto,
problema.
[]'s Salamandra
At first, thanks for post the file.
I've saved, resized, moved and I've not been able to reproduce the problem.
It will be a difficult one, so any other clue that you can tell me will be very useful.
salamandra
;) Hi Roberto,
At first, thanks for your attention.
I thought it would be really very difficult to reproduce this error...
If my memory not fails, error occurred after something like change font size,
font weight, textbox backcolor and (last line of textboxes) and form resizing.
But unfortunately i have not been able to reproduce the problem again.
I am working with the same form today (all day long) and there
were no more errors like this. :D
Well, i'll notice as soon as i get news about this problem.
[]'s Salamandra
;) Hola Roberto,
Muchas gracias por tu atencion.
Yo imaginaba que no seria muy facil reproducir ese error.
Sila memoria no me falla, ese error ocurrio despues de alterar la
ultima linea de textboxes (font size,font weight, textbox backcolor)
y redimensionar el form.
Mas a pesar de haver intentado algunas opciones no consegui reproducirlo
nuevamente.
Hoy trabaje el dia entero encima de ese form, lo altere innumeras veces
y no hubo ningun erro de ese tipo.
Bien, voy a continuar y asi que tenga qualquier novedad la posto aqui.
Un gran abrazo,
[]'s Salamandra
salamandra wrote:;) Hi Roberto,
[]'s Salamandra
;) Hola Roberto,
nuevamente.
Un gran abrazo,
[]'s Salamandra
Thanks. This info will be very useful to me.
