import dbf to SQLite
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
I'm sure there are many tools to help you do this, but I still made another. Based on the DBF structure program will create a table in SQLite database, and transfer data, 1: 1, and you later make optimize
The result is a program that you need to compile
First step: compile imp_gen.prg
Second: compile result program
File sql1.prg you can found on c:\hmg\samples\hfcl\sql\sqlite // author Rathinagiri
p.s. in hmg folder, in file hmg.hbc line #libs=hbsqlit3 remove #
import3.zip
(3.55 KiB) Downloaded 508 times
Re: import dbf to SQLite
Thanks a lot for the sharing.
Rathinagiri wrote:Thanks a lot for the sharing.
Thanks a lot for the sharing Dragan
Thanks Dragan!
