HMG and USB barcode scanner
hmgchang
Post by hmgchang »
Dear Sirs,
What is the code to read and get data from an USB barcode Scanner ( LS1203) ?
i found the comm is with the RS232, but any sample on USB ?
TIA
best rgds,
Chang
Just Hmg It !
Re: HMG and USB barcode scanner
Hola Chang :
que desea hacer porque no entendi bien su post...
you want to do well because I did not understand your post ...
Solo tienes que definir un control TEXTBOX en tu ventana, y al pasar el lector por el codigo de barras de tu producto, lo guardará en ese control.
Intenta esto, abre el notepad y utiliza el lector con algunos codigos de barras.
Just define a TextBox control in your window, and the reader passing by the barcode of your product, stored in the control.
Try this, open the notepad and uses the reader with some barcodes.
Usb barcode scanners work like keyboard, almost. As I remember well, LS2203 emulates keyboard, too. So, any special threating is needed.
