HMG and MySQL
Posted: Sun May 17, 2009 5:56 am
by CCH4CLIPPER
Hi All
Is there a sample showing how you can access MySQL and process a table using Clipper Commands ?
CCH
http://cch4clipper.blogspot.com
Re: HMG and MySQL
Posted: Sun May 17, 2009 7:08 am
You can find out here about HMG and MySQL.
Here Sudip had created an utility to convert dbf tables to MySQL. It can show you how to use HMG along with MySQL.
Re: HMG and MySQL
Posted: Sun May 17, 2009 8:02 am
by CCH4CLIPPER
Hi Rathinagiri
Thanx for your speedy response and yes, Sudip has been kind enough to send me his codes which is now published at Clipper... Clipper... Clipper. But it is not exactly what I want.
I am trying to convert a Harbour+HMG app to read from MySQL instead of DBFs
This is an extract from ADORDD-2 which works
* Copyright 2002-2008 Roberto Lopez <harbourminigui@gmail.com>
* http://harbourminigui.googlepages.com/
* To test this sample:
* - 'root' at 'localhost' with no password is assumed.
* - 'NAMEBOOK' database and 'NAMES' existence is assumed
* (you may create them using 'demo_2.prg' sample
* at \minigui\samples\basic\mysql)
#include "adordd.ch"
#include "minigui.ch"
Function Main()
WIDTH 800 HEIGHT 600 ;
TITLE 'MiniGUI MySql Browse Demo' ;
MAIN NOMAXIMIZE
DEFINE MAIN MENU
POPUP 'File'
MENUITEM 'Query' ACTION Query()
SEPARATOR
ITEM "Exit" ACTION ThisWindow.Release()
END POPUP
END MENU
CENTER WINDOW Form_1
Procedure Query
Local cDatabase := 'FAR4MYSQL' //'NAMEBOOK'
Local cTable := 'FARDAT' //'Names'
Local cServer := 'localhost'
Local cUser := 'root'
Local cPass := ''
Local aFieldNames := {}
Local aHeaders := {}
Local aWidths := {}
Local i
If InputWindow( 'Login' , ;
{'Server' , 'User', 'Password', 'Database', 'Table'} , ;
{cServer , cUser, cPass, cDatabase, cTable } , ;
{ 16 , 16 , 16 , 16 , 16 } ) [1] # Nil
USE (cDataBase) VIA "ADORDD" TABLE cTable MYSQL ;
FROM cServer USER cUser PASSWORD cPass
For i := 1 To FCount()
aadd ( aFieldNames , cDataBase + '->' + FieldName(i) )
aadd ( aHeaders , FieldName(i) )
aadd ( aWidths , 160 )
Next i
DEFINE WINDOW Query ;
WIDTH 640 HEIGHT 480 ;
TITLE 'MiniGUI ADO RDD Sample' ;
NOMAXIMIZE
@ 10,10 BROWSE Browse_1 ;
WIDTH 610 ;
HEIGHT 390 ;
HEADERS aHeaders ;
WIDTHS aWidths ;
WORKAREA &(cDataBase) ;
FIELDS aFieldNames
CENTER WINDOW Query
ACTIVATE WINDOW Query
USE
EndIf
What if I need to open multiple tables which I usually accomplish as follows :-
USE (DBF1)
oldarea::=Select()
SELECT 0
USE (DBF2)
SELECT(oldarea)
This does not work
cTable:='DBF1'
oldArea:=SELECT()
cch: ok
cTable:='DBF2'
cch: HMG insists that FAR4MYSQL workarea already in use
What is the correct manner to access multiple tables from MySQL using xBase syntax
CCH
Re: HMG and MySQL
Posted: Sun May 17, 2009 9:55 am
by sudip
Hello CCH,
IMHO, tMySql library is a better choice as long as RDDSQL doesn't have it's full power like updating database with simple xbase commands (and some other points).
For tMySql we have created a very simple project (with help of Rathi) viewtopic.php?f=15&t=297 (Please go to the last page of this topic for latest version of this project)
Regards.
Re: HMG and MySQL
Posted: Sun May 17, 2009 1:35 pm
by CCH4CLIPPER
Hi All
Solution
Add ALIAS after "ADORDD" and before TABLE
cTable:='DBF1'
USE (cDataBase) VIA "ADORDD" ALIAS "DBF1" TABLE cTable MYSQL ;
oldArea:=SELECT()
cTable:='DBF2'
CCH
