main form value after logon
RussBaker
Post by RussBaker »
I have my main form loading with a login routine. At the bottom of my form I have the
The problem is _opid is initialized before the form loads. After logon, the form displays the initialized value, not my new _opid that was set at loginattemp()
How do I get my form to load after the logon with the new value _opid
I want the form to reflect the operator ID after logon.
DEFINE WINDOW TEMPLATE AT 281 , 491 WIDTH 683 HEIGHT 530 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "" ICON NIL MAIN CURSOR NIL ON INIT loginattempt()
  DEFINE STATUSBAR
			STATUSITEM "User: "+_opid
			CLOCK
			DATE
		END STATUSBAR
Re: main form value after logon
RussBaker wrote:I have my main form loading with a login routine. At the bottom of my form I have the
  DEFINE STATUSBAR
			CLOCK
			DATE
		END STATUSBAR
Hi RussBaker,
see:
Procedure loginattempt()
   FormName.StatusBar.Item(1) := "User: "+_opid
dhaine_adp
Post by dhaine_adp »
  DEFINE STATUSBAR
			CLOCK
			DATE
		END STATUSBAR
Hi RussBaker,
Please have a look in the code snippet below. Pay attention to this variable "lhWndMainActive". It blocks premature execution and reentry of windows event during definition/initialization. I have also provided a sample code for a modal window shown below (METHOD UserLogin() CLASS UserManager). Also look on the events attached to MainForm ON INIT Method. You can also use the functions included for you to jumpstart.
REQUEST DBFCDX, DBFFPT
function Main()
   PRIVATE TrashFolder := "\trash\"
   PRIVATE AppHome     := LOWER( GETSTARTUPFOLDER() )
   PRIVATE HomeFolder  := AppHome + "\data\"
   PRIVATE ArchiveHome := AppHome + "\archive\"
   PRIVATE DefDrive   := HB_CURDRIVE()
   PRIVATE oDBsession          // Global Window session manager
   PRIVATE lPanicState := .f.  // Mainform Panic State flag to disable all close database calls to all child windows
                               // It will ensure clean program termination. All changes on data entry forms will not be saved.
   PRIVATE dbDeltaD  := HomeFolder + "DELTA.UAF"       // Table: User File
   PRIVATE dbDeltaI  := HomeFolder + "DELTA.UIX"       // Index: User File
   PRIVATE dbPathTbl   := HomeFolder + "pathcase"    // Pathology Case Main Table
   PRIVATE dbWeight    := HomeFolder + "weighthis"   // Weight Historical Record
   PRIVATE dbBPSummary := HomeFolder + "bpsummary"   // Blood Pressure Summary
   PRIVATE dbBPHistory := HomeFolder + "bphistory"   // Blood Pressure History
   PRIVATE dbGlucoSum  := HomeFolder + "glucossum"   // Glucose Record Summary
   PRIVATE dbGlucoHis  := HomeFolder + "glucosehis"  // Glucose Record Details
   PRIVATE dbTblUnit := HomeFolder + "unitTbl"  // Unit Table
   PRIVATE dbFoodGrp := HomeFolder + "foodGrp"  // Food Pyramid Group
   PRIVATE dbtblFood := HomeFolder + "foodTbl"  // Food Table
   PRIVATE dbDSgroups := HomeFolder + "usdaDSgroups"  // USDA Dietary Source Food Group
   PRIVATE dbDSnutr_1 := HomeFolder + "usdaDSnutr_1"  // USDA Nutrients Table per 100 gm
   PRIVATE dbFdDescr  := HomeFolder + "usdaFdDescr"   // USDA Food Descriptions
   PRIVATE dbDietkcal := HomeFolder + "dietkcal"   // Kilo-Calorie Diet Plan Database
   PRIVATE dbDietTmpl := HomeFolder + "diettmpl"   // Diet Plan (Template) - Used for Food Exchange
   PRIVATE dbDietUnit := HomeFolder + "dietsrvu"   // Diet Serving Unit Table
   PRIVATE dbDietExch := HomeFolder + "dietexch"   // Diet Template Food Exchange
   PRIVATE dbDietPlan := HomeFolder + "dietplan"     // Diet Plan based in Food Exchange and Diet Template
   PRIVATE dbPlanDiet := HomeFolder + "dietplanned"  // Diet Plan based in Food Exchange and Diet Template
   PRIVATE dbPlanExch := HomeFolder + "dietplanexc"  // Diet Plan based in Food Exchange and Diet Template
   PRIVATE oUser
   PRIVATE acPrivilege_ := {"ZZ","ZY","99","98","97","96","95","94","93","92","91","90","89","87","86","85","84"}
   PRIVATE acPrivDesc_  := {"Admin Privilege","Power User Priv.","Regular User","Restricted - 98","Restricted - 97",;
                            "Restricted - 96","Restricted - 95","Restricted - 94","Restricted - 93",;
                            "Restricted - 92","Restricted - 91","Restricted - 90","Restricted - 89",;
                            "Restricted - 87","Restricted - 86","Restricted - 85","Restricted - 84"}
   PRIVATE acAdminType_ := {"A","P","R","X"}
   PRIVATE acAdminDesc_ := {"Admin Account","Power User Account","Regular User Account","Restricted Account"}
   PRIVATE lhWndMainActive := .f.
   ANNOUNCE RDDSYS
   SET FIXED ON
   SET DECIMALS TO 2
   SET MULTIPLE OFF WARNING
   SET DATE AMERICAN
   SET CENTURY ON
   SET EPOCH TO 1950
   SET WRAP ON
   SET SCOREBOARD OFF
   SET DELETED ON
   SET CONFIRM ON
   SET BELL ON
   SET FONT TO "Arial" , 9
   SET NAVIGATION EXTENDED
   SET BROWSESYNC ON
   SET TOOLTIPSTYLE BALLOON
   SET TOOLTIPBACKCOLOR { 255 , 255, 0 }
   **SET TOOLTIPFORECOLOR { 0 , 0 , 0 }
   RDDSETDEFAULT("DBFCDX")
   IF .NOT. VerifyAppFolders()
      RELEASE ALL
      DBCLOSEALL()
      RELEASE WINDOW ALL
      QUIT
   oUser := UserManager():New( dbDeltaD, dbDeltaI, AppHome, HomeFolder, .t. )  // Toggle Developer's Test Account
   IF .NOT. oUser:lStatusOk
      MSGSTOP("The Application cannot create folder or read system files due to insufficient rights.","Critical Error")
      DBCLOSEALL()
      RELEASE WINDOW ALL
      QUIT
   oUser:cImageHome := ""
   oUser:cImageFile := "LOGINPIC"
   oDBsession := dbSession():New( TrashFolder, "SESSION" )
   DEFINE WINDOW MainForm;
      AT 0,0;
      WIDTH 548 HEIGHT 378;
      TITLE " " + ProductName() ;
      ICON "MAINICON";
      MAIN;
      FONT "Tahoma" SIZE 10;
      ON PAINT checkVGAResolution() ;
      ON INIT ( MakeFile(), BeginLogon(), WinAutoAdjust( "MainForm" ) );
      ON SIZE WinAutoAdjust( "MainForm" );
      ON MAXIMIZE WinAutoAdjust( "MainForm" );
      ON RELEASE NIL;
      ON INTERACTIVECLOSE DestroyWindow()
      DEFINE STATUSBAR OF MainForm FONT "Verdana" Size 8
         STATUSITEM "Blood Glucose and Blood Pressure Information Systems Version 1.0 - Freeware, " + LegPub();
            ICON "EUNICE" RAISED;
            TOOLTIP ""
      END STATUSBAR
      DEFINE SPLITBOX
         DEFINE TOOLBAR tbrMain OF MainForm BUTTONSIZE 32, 32 FONT "Arial" SIZE 8
            BUTTON btnExit   CAPTION "E&xit" PICTURE "IMGEXIT24" ACTION DestroyWindow()
            BUTTON btnLogOff CAPTION "Lo&g-off" PICTURE "IMGTBLOG" ACTION ( oUser:Destroy(), BeginLogon() )
         END TOOLBAR
         DEFINE TOOLBAR tbrMaint OF MainForm BUTTONSIZE 32, 32 FONT "Arial" SIZE 8
            BUTTON btnPath CAPTION "Pathology" PICTURE "IMGPATH32" ACTION PathologyCase( "PATHCASE" )
            BUTTON btnHealth CAPTION "Health State" PICTURE "HEALTH24" ACTION treeGraphView()
         END TOOLBAR
         DEFINE TOOLBAR  tbrArchive  OF MainForm BUTTONSIZE 32, 32 FONT "Arial" SIZE 8 BORDER
            BUTTON btnBackup CAPTION "Backup" PICTURE "IMGCOMP32";
            ACTION StartBackup();
            TOOLTIP "Backup database."
            BUTTON btnRestore CAPTION "Restore" PICTURE "IMGRBRES32";
            ACTION ( StartRestore(), DbfMakeTableCommon() ) ;
            TOOLTIP "Restore database."
            BUTTON btnExplore CAPTION "Open Folder" PICTURE "HP_FOLDER";
            ACTION ArchiveExplore();
            TOOLTIP "Explore archive folder."
         END TOOLBAR
      END SPLITBOX
      DEFINE MAINMENU OF MainForm
         DEFINE POPUP "&File"
            ITEM FILLER + "Pathology Case Registry" ACTION PathologyCase( "PATHCASE" ) NAME mnPathCase IMAGE "IMGPATH16"
            ITEM FILLER + "Health State" ACTION treeGraphView() NAME mnTrGrView IMAGE "HEALTH16"
            SEPARATOR
            ITEM FILLER + "&User Manager" ACTION oUser:UserProfile() NAME mnUser IMAGE "IMGPEOPLE"
            SEPARATOR
            ITEM FILLER + "E&xit" ACTION MainForm.Release IMAGE "IMGEXIT16"
         END POPUP
         DEFINE POPUP "&Help"
            ITEM FILLER + "&Contents" ACTION MSGDEBUG( "Active", countActiveForms(),GetDesktopWidth(), GetDesktopHeight(), AppHome + "\ErrVGA.txt", hb_memowrit( "test.txt", "haha" ) )
            SEPARATOR
            ITEM FILLER + "&About" ACTION AboutBGP()
         END POPUP
      END MENU
      @ 52, 0 IMAGE imgMainBK OF MainForm PICTURE "MAINIMGBK" WIDTH MainForm.ClientAreaWidth HEIGHT ( MainForm.ClientAreaHeight - 25 ) ADJUSTIMAGE //STRETCH
   MainForm.Center()
   MainForm.Minimize()
   DEFINE WINDOW frmSplash;
      AT 0,0;
      WIDTH 400 HEIGHT 260;
      TITLE "";
      TOPMOST NOCAPTION;
      ON INIT NIL ;
      ON RELEASE MainForm.Maximize()
      @ 0,0 IMAGE imgSplash OF frmSplash PICTURE "BGPBANNER" WIDTH 400 HEIGHT 260 STRETCH
   frmSplash.Center()
   lhWndMainActive := .t.
   ACTIVATE WINDOW frmSplash, MainForm
   oDBsession:Destroy()
   DestroyWindow()
static procedure SplashDelay()
   LOCAL nTimeDelay := 0
   nTimeDelay := SECONDS()
   DO WHILE SECONDS() - nTimeDelay < 2
   ENDDO
   frmSplash.Release
static function BeginLogon()
   LOCAL LoginCancelled
   MainForm.tbrMain.btnExit.Enabled := .f.
   MainForm.tbrMain.btnLogOff.Enabled := .f.
   MainForm.tbrMaint.btnPath.Enabled := .f.
   MainForm.tbrArchive.btnBackup.Enabled := .f.
   MainForm.tbrArchive.btnRestore.Enabled := .f.
   MainForm.tbrArchive.btnExplore.Enabled := .f.
   MainForm.imgMainBK.Hide()
   LoginCancelled := oUser:UserLogin()
   IF oUser:AccessDenied
      MSGSTOP( "Excessive log-on tries is not allowed. Program will be terminated.","Access Denied")
      DestroyWindow()
   MainForm.Title :=  IIF( EMPTY( oUser:currentUser() ), MainForm.Title, " " + ProductName() + " - [User: " + PROPERCASE( oUser:currentUser() ) + ;
                        " on " + GETENV( "COMPUTERNAME" ) + " as " + UPPER( GETENV( "USERNAME" ) ) + " ]" )
   IF LoginCancelled = FALSE
      DestroyWindow()
   IF alltrim( oUser:aUserInfo_[ 1 ] ) == "ADMIN"
      MainForm.mnUser.Enabled := TRUE
      MainForm.mnUser.Enabled := FALSE
   MainForm.tbrMain.btnExit.Enabled := .t.
   MainForm.tbrMain.btnLogOff.Enabled := .t.
   MainForm.tbrMaint.btnPath.Enabled := .t.
   MainForm.tbrArchive.btnBackup.Enabled := .t.
   MainForm.tbrArchive.btnRestore.Enabled := .t.
   MainForm.tbrArchive.btnExplore.Enabled := .t.
   MainForm.imgMainBK.Show()
static function DestroyWindow()
   DBCLOSEALL()
   DaleAid_DelTempFile( "*.*", TrashFolder )
   IF countActiveForms() > 2  // It must be 2 instead of one maybe because of the splash window and or perhaps HMG Lib is using a hidden window.
                              // However it seems that _HMG_SYSDATA [68] is related to windows release and interactive close event.
      lPanicState := .t.      // toggle panic state ON
   RELEASE ALL
   RELEASE WINDOW ALL
   QUIT
**  Function: countActiveForms()                                              **
**   Purpose: Count how many forms are active.                                **
**    Syntax:        **
** Arguments:        **
**   Returns: Returns the number of active forms, including those that are    **
**            minimized and those behind the visible windows.                 **
**     Notes: Document source, see <hmg>\source\h_init.prg                    **
**            _HMG_SYSDATA [  65 ] -> _HMG_aFormDeleted                       **
**            _HMG_SYSDATA [  66 ] -> _HMG_aFormNames                         **
**            _HMG_SYSDATA [  67 ] -> _HMG_aFormHandles                       **
**            _HMG_SYSDATA [  68 ] -> _HMG_aFormActive                        **
**            _HMG_SYSDATA [  69 ] -> _HMG_aFormType                          **
**            _HMG_SYSDATA [  70 ] -> _HMG_aFormParentHandle                  **
function countActiveForms()
   LOCAL ii := 0
   LOCAL nCount := 0
   FOR ii := 1 TO LEN( _HMG_SYSDATA [ 68 ] )
      IF _HMG_SYSDATA [ 68, ii ] == .t.
         nCount++
   RETURN nCount
Function ISAPPXPTHEMED()
   RETURN ( OS_ISWINXP_OR_LATER() .AND. IsAppThemed() )
function WinAutoAdjust( cForm, lMaxEvent )
   LOCAL hWnd := GetFormHandle( cForm )
   LOCAL i  // Form Number
   LOCAL k  // Control Number
   LOCAL ParentForm
   LOCAL ControlCount
   LOCAL ControlName
   LOCAL ControlType
   LOCAL nWidth
   LOCAL nHeight
   LOCAL lvisible:= .T.
   LOCAL nDivw
   LOCAL nDivh
   DEFAULT lMaxEvent TO .f.
   IF .NOT. lhWndMainActive
   IF GetDesktopWidth() < GetWindowWidth ( hWnd )
      nWidth := GetDesktopWidth()
      nWidth := GetWindowWidth ( hWnd )
   IF GetDesktopHeight() < GetWindowHeight ( hWnd )
      nHeight := GetDesktopHeight()
      nHeight := GetWindowHeight ( hWnd )
   IF IsWindowVisible ( hWnd ) .And. ! IsAppXPThemed()
      HideWindow ( hWnd )
      lvisible := .F.
   i := ASCAN ( _HMG_SYSDATA[ 67 ] , hWnd )
   ParentForm := _HMG_SYSDATA[ 66, i ]
   IF _HMG_SYSDATA[ 92, i ] > 0 .and. _HMG_SYSDATA[ 91, i ] > 0
      nDivw := nWidth  / _HMG_SYSDATA[ 92, i ]
      nDivh := nHeight / _HMG_SYSDATA[ 91, i ]
      nDivw := 1
      nDivh := 1
   ControlCount := LEN ( _HMG_SYSDATA[ 3 ] )
   FOR k := 1 To ControlCount
      ControlName := _HMG_SYSDATA[ 2, k ]
      IF _IsControlDefined ( ControlName, ParentForm )
         ControlType := _HMG_SYSDATA[ 1, k ]
         IF !EMPTY( ControlName ) .AND. ;
            !( ControlType $ "MENU,HOTKEY,TOOLBAR,MESSAGEBAR,ITEMMESSAGE,TIMER" )
            DO CASE
               //CASE ControlType == "RADIOGROUP"
                  // _HMG_aControlSpacing     := _HMG_SYSDATA[ 22 ]
                  // _HMG_aControlMiscData1   := _HMG_SYSDATA[  8 ]
                  // _HMG_aControlSpacing [k] := _HMG_aControlSpacing [k] * IIF(_HMG_aControlMiscData1 [k], nDivw, nDivh)
               CASE ControlType == "SLIDER"     // do nothing
               CASE ControlType == "STATUSBAR"  // do nothing
               CASE ControlType == "LABEL"
                  _SetControlSizePos( ControlName, ParentForm,;
                  _GetControlRow( ControlName, ParentForm ) * nDivh, ;   // row
                  _GetControlCol ( ControlName, ParentForm ) * nDivw ,;  // column
                  _GetControlWidth( ControlName, ParentForm ) * nDivw,;  // with
                  _GetControlHeight ( ControlName, ParentForm ) )        // height
               CASE ControlType $ "TEXT,RADIOGROUP"
               CASE ControlType == "BUTTON"
                  IF !_GetControlRow( ControlName, ParentForm ) == NIL .AND. ;
                     !_GetControlCol ( ControlName, ParentForm ) == NIL
                     _SetFontSize ( ControlName, ParentForm , 9 )
                     _GetControlHeight ( ControlName, ParentForm ) )        // _GetControlHeight ( ControlName, ParentForm ) * nDivh )
               CASE !ControlType $ "TOOLBUTTON"
                  _SetControlSizePos ( ControlName, ParentForm,;
                  _GetControlRow ( ControlName, ParentForm ) * nDivh, _GetControlCol ( ControlName, ParentForm ) * nDivw,;
                  _GetControlWidth ( ControlName, ParentForm ) * nDivw, _GetControlHeight ( ControlName, ParentForm ) * nDivh )
            OTHERWISE
               IF EMPTY( _HMG_SYSDATA[ 28, k ] )
                  _SetFontSize ( ControlName, ParentForm , 8 * nDivh )
                  //_SetFontSize ( ControlName, ParentForm , _HMG_SYSDATA[28] [k] * nDivh )
            ENDCASE
   NEXT k
   //MSGDEBUG( "Widths", GetDesktopWidth(), GetWindowWidth ( hWnd ), "Height",;
   //       GetDesktopHeight(), GetWindowHeight ( hWnd ),;
   //       GetDesktopWidth() < GetWindowWidth ( hWnd ),;
   //       GetDesktopHeight() < GetWindowHeight ( hWnd ),;
   //        ParentForm, nWidth, nHeight, _HMG_SYSDATA[ 92, i ], _HMG_SYSDATA[ 91, i ])
   _HMG_SYSDATA[ 92, i ] := nWidth
   _HMG_SYSDATA[ 91, i ] := nHeight
   MainForm.imgMainBK.Row := 52
   MainForm.imgMainBK.Width  := MainForm.ClientAreaWidth
   MainForm.imgMainBK.Height := MainForm.ClientAreaHeight - 75
   IF lvisible
      ShowWindow ( hWnd )
static function ArchiveExplore()
   EXECUTE FILE "explorer" PARAMETERS ArchiveHome
Here's my beginlogon() windows definition.
   LOCAL lRetVal := FALSE
   LOCAL acUser_ := ARRAY(3)
   PRIVATE nTries := 1
   PRIVATE lActivated := .f.
   PRIVATE lSwitchOff := .f.
   PRIVATE lUserName  := .f.
   DEFINE WINDOW frmLogin;
      AT 0,0;
      WIDTH 485 HEIGHT 222;
      TITLE "Login";
      ICON "MAINICON";
      MODAL NOSYSMENU ;
      FONT "Arial" SIZE 9 ON INIT ::Open() ON RELEASE ::Close()
      @  52,210 LABEL lblUserName OF frmLogin VALUE "User Name";
         ACTION Nil WIDTH  70 HEIGHT 20 FONT "Arial" SIZE 9
      @  87,210 LABEL lblPassword OF frmLogin VALUE "Password";
      @  48,290 TEXTBOX txbUserName OF frmLogin HEIGHT 24 VALUE "" WIDTH  120;
         FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 10 ON LOSTFOCUS Nil;
         ON ENTER ( frmLogin.txbPwd.Setfocus, frmLogin.txbPwd.CaretPos := 0 );
         ON CHANGE ::tbxChangeArg( This.Name )
      @  84,290 TEXTBOX txbPassword OF frmLogin HEIGHT 24 WIDTH  120;
         PASSWORD MAXLENGTH 10 UPPERCASE ON LOSTFOCUS Nil ON ENTER lRetVal := ::LoginButtonOK(@acUser_)
      @  84,290 TEXTBOX txbPwd OF frmLogin HEIGHT 24 VALUE "" WIDTH  120;
         MAXLENGTH 10 ON CHANGE ::tbxChangeArg( This.Name )
      @  10, 10 IMAGE imgLogo OF frmLogin PICTURE ::cImageFile WIDTH  150 HEIGHT 160 STRETCH
      @  10,130 IMAGE imgLock OF frmLogin PICTURE ::cImageHome + "key.bmp" WIDTH  30 HEIGHT 30 STRETCH
      @  10,170 LABEL Label_3 OF frmLogin VALUE "Please enter your security credentials...";
         ACTION Nil WIDTH  280 HEIGHT 20 FONT "Arial" SIZE 11 BOLD FONTCOLOR BLUE
      @  30,170 FRAME Frame_1 OF frmLogin CAPTION NIL;
         WIDTH  280 HEIGHT 100 FONT "Arial" SIZE 9 BACKCOLOR Nil FONTCOLOR Nil OPAQUE
      @ 140,280 BUTTON btnOk OF frmLogin CAPTION "&Ok" ACTION lRetVal := ::LoginButtonOk(@acUser_) WIDTH 80 HEIGHT 24 FONT "Arial" SIZE 9
      @ 140,370 BUTTON btnCancel OF frmLogin CAPTION "&Cancel" ACTION lRetVal := ::LoginButtonCancel() WIDTH 80 HEIGHT 24 FONT "Arial" SIZE 9
   frmLogin.Center
   frmLogin.txbUserName.Value := "User ID"
   frmLogin.txbUserName.FontColor := GRAY
   frmLogin.txbPassword.Hide
   frmLogin.txbPwd.Value     := "Password"
   frmLogin.txbPwd.FontColor := GRAY
   frmLogin.txbUserName.Setfocus()
   frmLogin.txbUserName.CaretPos := 0
   lActivated := .t.
   frmLogin.Activate
   IF lRetVal
      ::aUserInfo_ := acUser_
   IF nTries > LOGINTHRESHOLD
      ::AccessDenied := TRUE
   RETURN lRetVal
Here's how it looks
Here's how it looks
Danny
Manila, Philippines
dhaine_adp
Attached below is the Main Form Windows title after logon.
This is the main form title after logon.
Danny
Manila, Philippines
Excellent Danny !!!!
