Text Editor for Harbour
- MigSoft
- DBs Used: DBF, MySQL, MariaDB, SQLite, PostgreSQL, FireBird
A good alternative to edit your code.
- 2015-08-02_225558.jpg (276.58 KiB) Viewed 11538 times
Re: Text Editor for Harbour
Thank you for referring.
http://www.uvviewsoft.com/synwrite/
This is the link for this writer.
Please let me know how to configure for Harbour syntax highlighting. Now officially we are recommending Notepad++. What are all the advantages of this writer over notepad++?
+1Rathinagiri wrote:Thank you for referring.
- MigSoft
Hello Rathinagiri,
Attachment syntax Harbour, we must go to Options / Customize Lexer... / Import / Apply
More information about SynWrite in http://www.thewindowsclub.com/synwrite- ... ource-code
- 2015-08-03_092940.jpg (263.45 KiB) Viewed 11474 times
- Harbour and GUI.zip
- (6.61 KiB) Downloaded 862 times
- dragancesu
Thanks,
this is a very interesting solution
Hi Migsoft,
Excellent. Have you configured SynWrite to compile programs also ?, If so, how.
Warm regards,
Jayadev
Warm regards,
Jayadev
Really good tool, thanks to notify and "lexer" file, Miguel
Maybe useful, not tried yet by me
Regards.
There is a topic namely "How to make an IDE for your own language?" under "Miscellaneous" section of Help.jayadevu wrote:... Have you configured SynWrite to compile programs also ?, If so, how.
Regards.
- dhaine_adp
Hi MigSoft,MigSoft wrote:Hi,
Thanks for sharing the the link about SynWrite. For me, here's what I'm looking for a code editor:
1. Ability to use code folding.
2. Column mode editing
3. Tabs as space (because it allows me to used other editors preserving the alignment)
4. Syntax highlighting.
5. Support for Ansi and Unicode.
6. Ability to Search and Replace whole or selection (block)
In the old days I used ne.com (Norton Editor) because of its simplicity. Then I moved to CodeWright and finally with Crimson Editor (though it do not support code folding). Maybe I should try SynWrite.
Thanks,
Danny
Manila, Philippines
Danny
Manila, Philippines
Danny,
I have verified. SynWrite has all the above features.
I'm using notepad++. It has everything I need, but I'll try it after my holidays.
Thanks for info!
Thanks for info!
