BROWSE Control
Source code related resources
BROWSE Control
Hi!
I'm still using BROWSE control in my apps.
Last, I've found some trouble with use of user defined (udf) function as field column.
Everything works ok while udf returns character value.
When I want to return numeric value, program crashes with runtime error.
It's caused by _BrowseUpdate function, which tests type of every field.
The problem is that type('udf()') always returns "UI".
I want to modify sources to resolve this problem. I'll post my solution.
Is it possible to include such a patch into next version?
Re: BROWSE Control
Any solution is welcome.
