hmg and oracle
- dragancesu
hmg and oracle
I'm trying to access Oracle database, I looked forum, I tried but I could not. I found this and I wonder if anyone used it? Tips are welcome
http://orclib.sourceforge.net/documentation/
Re: hmg and oracle
I have an access to oracle db at my work.I'll try tomorrow
Re: hmg and oracle
I hope this code will be useful
cConstr := 'DSN=MyBase;UID=USER;PWD=password'
dsFun2 := TODBC():New(cConStr)
cError := dsFun2:SQLErrorMessage()
IF cError <> 'Error 00000 - '
MsgExclamation(cError + cCRLF + 'Conexión: ' + cConstr)
RETURN cDato
nRegi := 0
nOk := 0
nModi := 0
WITH dsFun2 DO
WAIT WINDOW 'Buscando datos' NOWAIT
cSQL := 'select des_login, des_nombre, des_apellido' + ;
' from adpr_tusuario' + ;
' order by des_login'
dsFun2:SetSQL(cSQL)
dsFun2:Open()
nRegTot := dsFun2:RECCOUNT()
IF nRegTot > 0
dsFun2:First()
DO WHILE .T.
IF (dsFun2:EOF()) ; EXIT ; ENDIF
nRegi ++
cLogin := ALLTRIM(dsFun2:FieldByName('DES_LOGIN'):Value)
cNombre := LEFT(ALLTRIM(dsFun2:FieldByName('DES_NOMBRE'):Value) + SPACE(20), 20)
cApellido := LEFT(ALLTRIM(dsFun2:FieldByName('DES_APELLIDO'):Value) + SPACE(30), 30)
IF nRegi == 1
f_SeqOpen(1, cFichLis, 'e')
f_SeqWrite(1, 'Usuarios' + SPACE(20) + DTOC(DATE()) + ' ' + TIME())
f_SeqWrite(1, '')
f_SeqWrite(1, 'Login OLD Login New Nombre Apellidos ')
f_SeqWrite(1, '---------- ---------- -------------------- ------------------------------')
cLogNew := SPACE(10)
*--- Correcto
IF LEN(cLogin) == 10 .AND. SUBSTR(cLogin, 1, 4) == 'ES00' .AND. fEsNume(SUBSTR(cLogin, 5, 6))
cLogNew := 'OK '
nOK ++
IF (LEN(cLogin) == 6 .OR. LEN(cLogin) == 8) .AND. fEsNume(cLogin)
cLogNew := 'ES' + IF(LEN(cLogin) == 6, '00', '') + cLogin
nModi ++
f_SeqWrite(1, LEFT(cLogin + SPACE(10), 10) + ' ' +;
cLogNew + ' ' + cNombre + ' ' + cApellido)
dsFun2:Skip()
ENDDO
dsFun2:Close()
WAIT CLEAR
ENDWITH
dsFun2:Destroy()
IF nRegi > 0
f_SeqWrite(1, '')
nMal := nRegi - nOK - nModi
f_SeqWrite(1, 'Leidos: ' + TRAN(nRegi, "@E 999,999"))
f_SeqWrite(1, 'OK....: ' + TRAN(nOK, "@E 999,999"))
f_SeqWrite(1, 'Modifi: ' + TRAN(nModi, "@E 999,999"))
f_SeqWrite(1, 'Mal...: ' + TRAN(nMal, "@E 999,999"))
f_SeqClose(1)
fReader(cFichLis, .F., 'V')
Re: hmg and oracle
I'm trying to connect to server, but without success
Re: hmg and oracle
I have installed Oracle Client 11g and I've defined an ODBC data source.
http://www.interfaceware.com/manual/odbc_oracle.html
- dragancesu
Re: hmg and oracle
This promise, I'll try
- Ismach
- DBs Used: DBF, mySQL, Mariadb, postgreSQL, Oracle, Db2, Interbase, Firebird, and SQLite
Re: hmg and oracle
Yo si pude conectar a Oracle.... trabajo en una entidad financiera... y alli no puedo subir el ejemplo
porque tengo restriccciones por todos lados, por un tema de seguridad...
pero tengo varios desarrollo en HMG conectado a Oracle
lo importante a tener en cuenta:
1) usar como nombre del HOST la TNS NAME de la base oracle
en mi caso yo mi TNS NAME de mi base es ARGDESA45
2) User con todos los GRANTs necesarios
3) probar con un cliente tipo PL/SQL dev o Toad
#include "FileIO.ch"
#include "Minigui.ch"
#include "adordd.ch"
#include "Abc\SysDefs.ch"
SET PROCEDURE TO "Gestab\Class\A012.prg"
static wifmain
static aChItems := {}
static aErItems := {}
static aMtItems := {}
static aCbItems := {}
static cFecha // FECHA DE LA TABLA DE FECHA CONTABLE.
static bConectado // ESTADO DE APLICACION (TRUE/FALSE)
static cTerm // TERMINAL DEL USUARIO
static cUser := "ismach" // USUARIO ATLAS II
static cPass := "ismach" // PASSWORD
static cHost := "ARGDESA45" // NOMBRE DEL HOST
static cBase := "ARGDESA45" // BASE DE DATOS DEL AMBIENTE
static cProv := "MSDAORA.1" // PROVEEDOR DEL API CONNECTOR
static cUsuario // FECHA DE LA TUSR231
static cSucursal // SUCURSAL DEL USUARIO
static nSucursal := 0
static oA012
FUNCTION Main()
Local nMedio := (nWIDTH/2)-180
Private fClr := { || if ( This.CellRowIndex/2 == int(This.CellRowIndex/2) , BLUE, NEGRO ) }
Private zClr := { || if ( This.CellRowIndex/2 == int(This.CellRowIndex/2) , BEIGE, AGUA ) }
Public oOra // OBJETO DE ADOCONEXION
SET EXCLUSIVE OFF
SET DELETE ON
SET DATE ITALIAN
SET CENTURY ON
SET EXACT ON
SET NAVIGATION EXTENDED
SET EPOCH TO YEAR(DATE()) - 50
REQUEST HB_LANG_ES
SET LANGUAGE TO SPANISH
SET MULTIPLE OFF WARNING
SET INTERACTIVECLOSE ON
//SET DATE FORMAT TO 'dd/mm/yyyy'
GetConfig()
Gb_Oracle()
DEFINE WINDOW wifmain AT 00, 00 ;
WIDTH nWIDTH HEIGHT nHEIGHT ;
TITLE SISTEMA ;
ICON "PINO";
NOCAPTION ;
BACKCOLOR {000,128,000} ;
NOSIZE ;
MAIN ;
ON INIT Gb_LoginUser()
ON KEY ALT+F4 ACTION Salir()
FUNCTION Gb_Oracle()
oOra := TOLEAuto():New('ADODB.Connection')
oOra:Open("Provider=" + cProv + ";" + ;
"Data Source= " + cHost + ";" + ;
"User ID=" + cUser + ";" + ;
"Password=" + cPass + ";" )
- Ismach
Re: hmg and oracle
Podes probar esta funcion para ver cono es tu string de conexion:
// MSDAORA.1 es el provider OLE estandar de Microsoft para acceder a una
// base de datos Oracle, aunque el mismo Oracle tiene otro provider-OLE
// propio. Si usas la función siguiente (cortesía de Biel), puedes
// probar si la conexión es correcta, usando el Datalink de Microsoft.
static FUNCTION FDATALINK (oCon)
LOCAL oDataLink := TOleAuto():New("Datalinks"), ;
oConn := oDataLink:PromptNew()
msginfo (oConn:ConnectionString)
oCon:CLOSE()
RETURN nil
- Ismach
Re: hmg and oracle
Ahi va ele ejemplo con el que empecé
FUNCTION MAIN()
Public cProv := "MSDAORA.1"
Public cHost := "b32atlas1"
Public cUser := "atlas"
Public cPass := "atlas"
Public cConn := Nil
cHost := "b32atlas1" // tambien puedes poner el nombre de la BD
cUser := "atlas"
cPass := "atlas"
GetConfigApps()
Oracle_Connect()
If !Conectado
MsgInfo("No se Puede Conectar a Base de Datos")
Release Window All
Quit
EndIf
Load Window WinMain
Activate Window WinMain
static FUNCTION Oracle_Connect()
cConn := "Provider=" + cProv + ";" + ;
oCon := TOLEAuto():New('ADODB.Connection')
TRY
oCon:Open("Provider=" + cProv + ";" + ;
CATCH
MSGSTOP ("Provider: " + cProv + CRLF + ;
"Host: " + cHost + CRLF + ;
"Usuario: " + cUser + CRLF + ;
"Clave: " + cPass, "Error de Conexión")
RETURN nil
END
- Ismach
Re: hmg and oracle
Buscando un RECORDSET
STATIC FUNCTION CA_BuscaCaja()
LOCAL cSuc
LOCAL cRaiz
LOCAL oRs
LOCAL cSQL
LOCAL k, nLen
LOCAL cFila0, cFila1, cFila2, cFila3, cFila4, cFila5
LOCAL cFila6, cFila7, cFila8, cFila9, cFila10, cFila11
LOCAL cFila12, cFila13, cFila14, cFila15, cFila16
LOCAL cFila17, cFila18, cFila19
IF EMPTY(fmCajas.txtA0090.Value)
MsgInfo('Ingrese al menos la Sucursal')
fmCajas.txtA0090.SetFocus
cSuc := fmCajas.txtA0090.Value
IF LEN(cSuc) > 0
cSuc := ALLTRIM(cSuc)
cRaiz := fmCajas.txtA1010.Value
IF LEN(cRaiz) > 0
cRaiz := ALLTRIM(cRaiz)
IF LEN(cRaiz) > 0
cSQL := SQLSelCACliente(cSuc,cRaiz)
cSQL := SQLSelCASucursal(cSuc)
CA_BusCliente()
oRs := TOleAuto():New("adodb.recordset")
oRs:ActiveConnection(oOra)
oRs:CursorLocation(3)
oRs:CursorType := adOpenStatic
oRs:CursorLocation := adUseClient
oRs:LockType := adLockOptimistic
oRs:Open(cSQL, oOra ,adOpenKeyset, adLockOptimistic)
IF oRs:RecordCount = 0
MsgInfo( "Producto Caja de Seguridad Inexistente", SISTEMA )
fmCajas.txtA0090.Setfocus
nLen:=oRs:RecordCount
fmCajas.gCheq12.DeleteAllItems
FOR k:=1 TO nLen Step 1
cFila0 := ALLTRIM(oRs:Fields(0):value) // 0 Suc.(Ky)
cFila1 := ALLTRIM(oRs:Fields(1):value) // 1 Raiz(Ky)
cFila2 := oRs:Fields(2):value // 2 Prod(Ky)
cFila3 := ALLTRIM(oRs:Fields(3):value) // 3 Nro.(Ky)
cFila4 := oRs:Fields(4):value // 4 Valor Real
cFila5 := oRs:Fields(5):value // 5 Cod.Com.
cFila6 := oRs:Fields(6):value // 6 Bonif.
cFila7 := oRs:Fields(7):value // 7 Vto.Bonif.
cFila8 := oRs:Fields(8):value // 8 ComCobro
cFila9 := oRs:Fields(9):value // 9 Cuota 1
cFila10 := oRs:Fields(10):value // 10 NroCuota
cFila11 := oRs:Fields(11):value // 11 Año
cFila12 := ALLTRIM(oRs:Fields(12):value) + "-" + ; // 12 SucDeb
ALLTRIM(oRs:Fields(13):value) + "-" + ;
ALLTRIM(oRs:Fields(14):value) + "-" + ;
oRs:Fields(15):value
cFila16 := ALLTRIM(oRs:Fields(16):value) // 16 ModoFac
cFila17 := oRs:Fields(17):value // 17 NumeroCaja
cFila18 := ALLTRIM(oRs:Fields(18):value) // 18 Estado
cFila19 := oRs:Fields(19):value // 19 Suc.de la Caja
fmCajas.gCheq12.ADDITEM( {cFila0,cFila1,cFila2,cFila3,cFila4,cFila5, ;
cFila6,cFila7,cFila8,cFila9,cFila10,cFila11, ;
cFila12,cFila16,cFila17,cFila18,cFila19})
oRs:MoveNext()
Next k
oRs:=Nil
