whats wrong in program?
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
I'm trying to make a tool that we facilitate programming now trying to present what will be on the screen
The question is why a program error occurs on line 69?
Green fields are label and there need display L_Name
Orange fields are fields and there need display F_Name
wrong.zip
(1.37 KiB) Downloaded 827 times
Re: whats wrong in program?
Hi Dragan,
Try
   _labx = 'label' + hb_ntos(_GetId())
   _labv = l_name
   // labels
   //altd()
   @ _rowl, _coll LABEL &(_labx) VALUE _labv OF FromTest
Hope that helps :idea:
dragancesu
Yes, it's help
Solve is
FUNCTION main //       fm_test
DEFINE WINDOW FromTest ;
		AT 10,10 ;
		WIDTH 800 ;
		HEIGHT 800 ;
        TITLE 'Preview Form' ;
		MAIN ; // MODAL
      ON KEY ESCAPE ACTION FromTest.Release
      @ 700, 700 LABEL label1x ;  // << label1 is  duplcate name
         VALUE " LEGEND "
      @ 720, 700 LABEL label2x ; // << label2 is  duplcate name
         VALUE " GRID "
      @ 735, 700 LABEL label3x ; // << label3 is  duplcate name
         VALUE " LABEL "
      @ 750, 700 LABEL label4x ; // << label4 is  duplcate name
         VALUE " FIELD "
   fmTest()
	CENTER WINDOW   FromTest
	ACTIVATE WINDOW FromTest
function fmTest
// make line
DRAW LINE IN WINDOW FromTest AT 710,5 TO 710,795
// show legenda
DRAW RECTANGLE IN WINDOW FromTest AT 720,680 TO 730,690 pencolor { 128,128,255 } FILLCOLOR { 128,128,255 }
DRAW RECTANGLE IN WINDOW FromTest AT 735,680 TO 745,690 pencolor { 55,201,48 } FILLCOLOR { 55,201,48 }
DRAW RECTANGLE IN WINDOW FromTest AT 750,680 TO 760,690 pencolor { 255,102,10 } FILLCOLOR { 255,102,10 }
// show grid
DRAW RECTANGLE IN WINDOW FromTest AT 90,10 TO 390,710 pencolor { 128,128,255 } FILLCOLOR { 128,128,255 }
use _my_frm
dbgotop()
do while .not. eof()
   _row1 = f_row
   _col1 = f_col
   _row2 = f_row + 20
   _col2 = f_col + f_width
   _rowl = f_row + l_row
   _coll = f_col + l_col
   _labx = 'label' + alltrim(str(recno()))
   _labxx = 'label' + alltrim(str(recno()+100))
   _labv = l_name
   _labf = f_name
   // labels
   if !empty(L_name)
      DRAW RECTANGLE IN WINDOW FromTest AT _rowl, _coll TO _rowl+15, _coll+50 pencolor { 55,201,48 } FILLCOLOR { 55,201,48 }
      @ _rowl, _coll LABEL &(_labx) VALUE _labv OF FromTest transparent           // << tranparent if you want see rectangle
   // fields
   DRAW RECTANGLE IN WINDOW FromTest AT _row1, _col1 TO _row2, _col2 pencolor { 255,102,10 } FILLCOLOR { 255,102,10 }
    @ _row1, _col1 LABEL &(_labxx) VALUE _labf OF FromTest transparent          // << tranparent if you want see rectangle
   dbskip()
enddo
RETURN 0
Thank you
