- From HMG Extended : - From LetoDB : Happy HMG'ing
Two announces from community
Hi all
Re: Two announces from community
Thanks Esgici !
This URL is wrongesgici wrote: - From HMG Extended :
Harbour MiniGUI Extended Edition build 2.4.6 is published
Full text of announce is :
Grigory Filatov wrote:Harbour MiniGUI Extended Edition build 2.4.6 is published
I am glad to announce a new version of the Harbour MiniGUI Extended Edition.
The new build 2.4.6 setup is published at the following URL:
http://hmgextended.com/files/CONTRIB/hm ... -setup.zip
and the MinGW-based self-extracting archive is placed at the following URL:
http://hmgextended.com/files/CONTRIB/hmg246-mingw.exe
There are the extra xHarbour.org-based and xHarbour.com-based archives
for this build also at the Minigui's download homepage.
There is the following changelog for this build:
2015/04/22: HMG Extended Edition 2.4.6 Published.
* Fixed: Possible memory leak in the main/context/notify menu with 'Image'
clause. Problem was reported by Russian user SergKis.
Contributed by Grigory Filatov <gfilatov@...>
(see menudemo.prg in folder \samples\Basic\Menu)
* Enhanced: The ReadOnly property is supported in the function SetProperty()
for the Spinner control.
You can set/get this property at runtime:
- function syntax:
SetProperty ( Form, Control, 'ReadOnly', lState )
GetProperty ( Form, Control, 'ReadOnly' )
- pseudo-OOP syntax:
Form.Spinner.ReadOnly := lState
Form.Spinner.ReadOnly --> lState
* Enhanced: The ComboBox control with DisplayEdit clause supports a changing
of the ReadOnly property at runtime:
- function syntax:
Form.ComboBox.ReadOnly := lState
Requested by Vianei Moreira de Lemos <vianeimoreira@...>.
(see demo2.prg in folder \samples\Basic\COMBO_4)
* Updated: DRAW GRAPH: correction of the default height of title and labels
for the font's size more than 10.
(see demo in folder \samples\Basic\Histogram)
* Updated: Changed DEFAULT TO command in MiniGUI core to the functions
hb_default()/__defaultNIL() and hb_defaultValue() for Harbour
requiring compatibility. It will set the value to the default one
even when the variable has any other type, not only NIL.
* Updated: Adaptation FiveWin Class TSBrowse 9.0 in HMG:
- updated for xHarbour compatibility after a recent change.
Based upon a contribution of Ivanil Marcelino.
* Updated: HbSQLite3 library:
- update for using SQLITE3 version 3.8.9 (from 3.8.8.3).
* Updated: Harbour Compiler 3.2.0dev (SVN 2015-04-09 00:20).
(look at ReadMe.txt in folder \harbour)
* New: 'Anchored Child window' sample.
Based upon a contribution of Pablo Cesar.
Adapted for Minigui Extended by Grigory Filatov <gfilatov@...>
(see demo2.prg in folder \samples\Basic\MoveWindow)
* New: 'Read a text from an another application' sample.
Contributed by Verchenko Andrey <verchenkoag@...>.
Revised by Grigory Filatov <gfilatov@...>
(see in folder \samples\Advanced\ExternalApp_3)
* Updated: 'Get DIR List' sample: pacified the warnings at prg level.
(see in folder \samples\Basic\DirList)
* Updated: 'Histogram' sample: added a print graph routine.
(see in folder \samples\Basic\Histogram)
* Updated: 'HPDF Print' sample is based upon the Haru Free PDF library:
- New: Added JPG image support to HPDFPRINT IMAGE command.
(see in folder \samples\Advanced\PDF_PRINT)
* Updated: 'Simple DBU' sample: minor changes.
(see in folder \samples\Applications\MiDBU)
* Updated: 'Process Killer' sample: minor changes.
(see in folder \samples\Applications\PROCESS_KILLER)
* Updated: 'Sqlite browser' utility: added column's metadata handling.
Contributed by Janusz Pora <januszpora@...>
(see in folder \Utils\SqlDBU)
There are also the others minor modifications in the Minigui core.
[MiniGUI Team]
