Here is a code snippet of my Generic Browse Class to browse a flat table like;
Products.DBF, ProductSize.DBF, etc for making input and as an initial form when a module was loaded by the user from Menu. The goal is to make a rapid application prototyping for presentation to customer/client and eventually use the same prototype for production or development of the application. Instead of making a separate module for each type of flat table you can call the routine by using something like this as an example:
BEGIN SEQUENCE
oTable := GenericBrwObj():New()
oTable:cWndTitle := "Collectors Master File"
oTable:cMainAlias := "COLLECTOR"
oTable:cMainFocus := "IDNbr"
oTable:cMainFile := Kolektor
oTable:cImageHome := ImageHome
oTable:acFields_ := { "COLLECTOR->F1", "COLLECTOR->F2", "COLLECTOR->F3",;
"COLLECTOR->F4", "COLLECTOR->F5", "COLLECTOR->F6",;
"COLLECTOR->F7" }
oTable:acHeaders_ := { "ID No.", "Surname", "First Name", "Second Name", "Middle Name",;
"Mobile No.", "Address"}
oTable:anWidths_ := { 80, 120, 120, 120, 120, 120, 300}
oTable:bTaskAdd := {|| GraphicUserInterface( "ADD" ) }
oTable:bTaskEdit := {|| GraphicUserInterface( "EDIT" ) }
oTable:bTaskExit := {|| BrowseWindowCloseEvent() }
oTable:bTaskDel := {|| DelRecord() }
oTable:bKpressInsert := {|| GraphicUserInterface( "ADD" ) }
oTable:bTaskWndInterActiveClose := { || BrowseWindowInterActiveClose() }
oTable:bKpressCtrlEnter := ""
oTable:bTaskDblClick := {|| GraphicUserInterface( "EDIT" ) }
IF lBTNExtra2
oTable:lExtra2 := lBTNExtra2
oTable:cExtraCaption2 := "Update Easter"
oTable:bTaskExtra2 := {|| EasterUpdate() }
IF TableDefinitions( @nBrowseType ) = Failure
BREAK
oTable:BeginBrowseDisplay( nBrowseType )
END SEQUENCE
DBCLOSEALL()
RELEASE WINDOW ALL
CLASS GenericBrwObj //
// Purpose: HB CLASS handling of Tables, a generic table maintenance routine //
EXPORTED:
DATA bTaskAdd
DATA bTaskEdit
DATA bTaskDel
DATA bTaskPrint
DATA bTaskExtra1
DATA bTaskExtra2
DATA bTaskExit
DATA bTaskPrint
DATA bTaskDblClick
DATA bTaskOpen
DATA bTaskClose
DATA bTaskRelease
DATA bTaskWndInterActiveClose
DATA bKpressInsert // shortcut: action when Insert key is press - default is nil
DATA bKpressEscape // shortcut: action when Escape key is press - defaul is nil
DATA bKpressF1 // shortcut: action when F1 key is press - default is nil
DATA bKpressF10 // shortcut: action when F10 key is press - default is nil
DATA bKpressDel // shortcut: action when Del key is press - default is nil
DATA bKpressCtrlEnter
DATA acFields_
DATA acHeaders_
DATA anWidths_
DATA abHeadClicks_
DATA cMainAlias
DATA cMainFocus
DATA cMainFile
DATA cImageHome
DATA cWndTitle
DATA cQFind
DATA cExtraImage1
DATA cExtraImage2
DATA cExtraCaption1
DATA cExtraCaption2
DATA lExtra1 // logical variable to show or hide the Control Object Buton Extra 1, default is hidden
DATA lExtra2 // logical variable to show or hide the Control Object Buton Extra 2, default is hidden
DATA aColumnAlignment_
DATA abrwImages_
DATA cTooltip
METHOD New() CONSTRUCTOR
METHOD BeginBrowseDisplay()
METHOD BrowseRestoreFocus()
METHOD BrowseCurrentPos()
METHOD BrowseRefresh()
METHOD AddNewRecod() INLINE EVAL( ::bTaskAdd )
METHOD EditRecord() INLINE EVAL( ::bTaskEdit )
METHOD DoPrintingJob() INLINE EVAL( ::bTaskPrint )
METHOD ExtraButton1() INLINE EVAL( ::bTaskExtra1 )
METHOD ExtraButton2() INLINE EVAL( ::bTaskExtra2 )
METHOD Open() INLINE EVAL ( ::bTaskOpen )
HIDDEN:
METHOD DummyMsg()
METHOD BrowseStatusChanged()
METHOD QuickFindChanged()
METHOD QFindLostfocus()
METHOD DeleteKeyPress()
METHOD Destroy()
METHOD Close()
END CLASS
METHOD New( ) CLASS GenericBrwObj
::bTaskAdd := {|| ::DummyMsg() }
::bTaskEdit := {|| ::DummyMsg() }
::bTaskDel := {|| ::DummyMsg() }
::bTaskPrint := {|| ::DummyMsg() }
::bTaskExit := {|| ::DummyMsg() }
::bTaskExtra1 := {|| ::DummyMsg() }
::bTaskExtra2 := {|| ::DummyMsg() }
::bTaskDblClick := {|| ::DummyMsg() }
::bTaskOpen := {|| ::DummyMsg() }
::bTaskClose := {|| ::DummyMsg() }
::bTaskRelease := {|| ::DummyMsg() }
::bTaskWndInterActiveClose := {|| ::DummyMsg() }
::bKpressInsert := ""
::bKpressEscape := ""
::bKpressF1 := ""
::bKpressF10 := ""
::bKpressDel := ""
::bKpressCtrlEnter := ""
::acFields_ := {}
::acHeaders_ := {}
::anWidths_ := {}
::abHeadClicks_ := { {|| ::DummyMsg( "No task is associated with this event", "DLBRW001" ) } }
::cMainAlias := ""
::cMainFocus := ""
::cMainFile := ""
::cImageHome := ""
::cWndTitle := ""
::cQFind := ""
::cExtraImage1 := ""
::cExtraImage2 := ""
::cExtraCaption1 := ""
::cExtraCaption2 := ""
::lExtra1 := FALSE // default is false, means do not show this button
::lExtra2 := FALSE // default is false, means do not show this button
::aColumnAlignment_ := ""
::abrwImages_ := ""
::cToolTip := ""
RETURN Self
Thanks,
Danny
