<WindowName>.Center
<WindowName>.Center
Hi Claudio,
I have found difference to use C_CENTER function specially when I try with GETDESKTOPREAL at maximum size.
Difference exists at y = GetSystemMetrics(SM_CYSCREEN) thru taking rect by GetWindowRect and y = rect.bottom - rect.top thru taking rect by SystemParametersInfo( SPI_GETWORKAREA, 1, &rect, 0 )
Would you agree with this replacement at:
y = GetSystemMetrics(SM_CYSCREEN);
by this:
SystemParametersInfo( SPI_GETWORKAREA, 1, &rect, 0 );
y = rect.bottom - rect.top;
I made this changing and working in properly.
I guess that our actual C_CENTER function is considering the window's title height and do not make the right centralizing.
Re: <WindowName>.Center
I will check this function.
The difference between: GetSystemMetrics(SM_CYSCREEN) - SystemParametersInfo (SPI_GETWORKAREA) = taskbar height
<WindowName>.Center
srvet_claudio wrote:I will check this function
Thank you Claudio, will be appreciated.
srvet_claudio wrote:The difference between: GetSystemMetrics(SM_CYSCREEN) - SystemParametersInfo (SPI_GETWORKAREA) = taskbar height
Also thank for your info, I forgot to check this because I was without internet during all that morning.
Simple test, you will see the difference.
Function Main()
DEFINE WINDOW Form_1 MAIN ;
    TITLE "Form with GETDESKTOPREAL size  demo"
Form_1.Center
Form_1.Activate
I have already changed and works ok for me.
P.S. Running on Win7 32bits and in classic mode.
