HFCL (Hmg Forum Component Library)
Source code related resources
Roberto Lopez wrote: When it be ready I could adapt to work as an user component. This could serve to teach about how to do that in more complex situations, so in the future the group itself could do it.
I've reviewed and tested your code and I've noted that there is no need to convert to 'User Components Interface' since UCI was designed to fully new controls and 'ComboSearchBox' creates a high level TextBox with its name, inheriting all TextBox properties, events and methods. So you only need an include file for command definitions.
I've only added a little of 'organization' to code (considering it as a part in a component library):
- hfcl.ch (HFCL main include file)
- hfcl.prg (HFCL main procedure file)
- combosearchbox.prg (ComboSearchBox procedure file)
- combosearchbox.ch (ComboSearchBox include file file)
This structure will make easy the test and development process.
We could add later a makefile to build a the library (hfcl.a) to our projects and UCI file for IDE users.
This is only a proposal, please let me know what do you think about that.
And remember... this is YOUR project, please continue working on it! (I have lot of problems already :) )
Regards :)
combosearchbox.rar
(4.66 KiB) Downloaded 1104 times
Re: Incremental Search with Combo Box
Thanks a lot Maestro :D
Best Regards
Hi Maestro
Many thanks to your 'organization'; certainly we need this.
HFCL (Hmg Forum Component Library) structure is a very good concept. IMHO this is very important step for our Forum Component ( or Contrib ) library. I hope by the time it will be very useful source for our friends.
This is another good news.
As always your proposals are the best alternative :)
IMHO for continuing to work we need hearing some opinions by members.
In other hand, inheriting ALL from text box may not be problem at all. If user set a value to CSBox in definition, this value goes directly to text box. Since our users not real user, all of them are programmers, so they know what they are made :)
With best regards :)
Very proud Roberto.
Thanks a lot for your valuable guidance.
rathinagiri wrote:Very proud Roberto.
By the way... I guess that Grid2Print could be a good candidate for HFCL (if you agree, of course).
Yes. We can add that too.
Now, the autofill, given by Esgici would also be. :)
rathinagiri wrote:Yes. We can add that too.
I don't reviewed that, since I don't read all threads.
Could be a good idea if all 'candidates' were linked here or in a new forum area dedicated to the library.
What do you think?
Hi Maestro
Roberto Lopez wrote: Could be a good idea if all 'candidates' were linked here or in a new forum area dedicated to the library.
Yes, this is a good idea; but doesn't will be difficult to deciding or selecting candidates, especially by author himself ?
Best Regards
esgici wrote:Hi Maestro
Best Regards
At first, I've modified a little AutoFill. It needs only ONE parameter now (the list array) to make it easy to use (is attached to this message).
Regarding the decision, it could be reached by 'consensus' based on opinions of people involved.
I hope that all we here, agree in terms of code quality, reliability, backwards compatibility, style and consistency with the rest on MiniGUI library.
autofill2.rar
(2.24 KiB) Downloaded 1063 times
Hi Maestro
Roberto Lopez wrote: At first, I've modified a little AutoFill. It needs only ONE parameter now (the list array) to make it easy to use.
Many thanks for your interest my humble work :)
You are right as always :)
No doubt :)
Best Regards
