Status Bar
Vanguarda
Status Bar
Post by Vanguarda »
Hello HMG Users,
I have a form main with a StatusBar. when i try this command:
Main.StatusBar.Item(1) := " Text of status bar" :D
in my module main.prg, work fine. But when i try in other module it don´t work. :shock:
My form main is called in main.prg module.
When i try in another module, i get a message of error in line of command (Main.StatusBar.Item(1)) erro like "."
what´s going on?
Anybody help me?
PS: Sorry my bad english :lol:
Tank´s a lot, for your attention.
Re: Status Bar
Did you try to declare window MAIN in other module:
DECLARE WINDOW MAIN
before line that changes status line?
Marek
Vanguarda
Re: Status Bar
Post by Vanguarda »
Hello Marek,
i don´t understand your question :?:
Re: Status Bar
To refer a window in a different prg file, we have to use "declare window windowname" command before referring it. That is what Marek says.
Re: Status Bar
Hi Paulo
In addition to DEFINE WINDOW, we have a DECLARE WINDOW statement:
According to HMG Documentation:
DECLARE WINDOW : Declares a window name..
Syntax : DECLARE WINDOW <WindowName>
A window must be declared using this command, if you need to refer to it prior
its definition in code, or when you refer to it in a different .prg file from
the one it was defined using semi-oop syntax.
Vanguarda
Re: Status Bar
Post by Vanguarda »
i don´t try it. I´ll try today, in my house.
Thank very much Marek, rathinagiri, esgici.
you are amazing.
regards,
CCH4CLIPPER
Re: Status Bar
Post by CCH4CLIPPER »
Hi Marek, Rathinagiri & Esgici
Tx for providing an answer to one of my unasked questions :D
CCH
http://cch4clipper.blogspot.com
