HDROIDGUI SETUP TUTORIAL (UPDATED 2015.02.27)
1. Download Java Development Kit (JDK) version 7 for Windows (if you have other version installed, please uninstall first):
http://www.oracle.com/technetwork/es/ja ... 80260.html
2. Run it and accept suggested install location (at the date of this post, it is: C:\Program Files\java\jdk1.7.0_75. It will change according version number) .
3. Go to: https://developer.android.com/sdk/index.html ('SDK Tools Only' section, near the end of the page) and download Windows version.
4. Create the folder tree: c:\Android\sdk and install Android SDK there.
5. Run C:\Android\sdk\SDK Manager.exe and follow these directions found in android.com:
As a minimum when setting up the Android SDK, you should download the latest tools and Android platform:
Open the Tools directory and select:
Android SDK Tools
Android SDK Platform-tools
Android SDK Build-tools (highest version)
Open the first Android X.X folder (the latest version) and select:
SDK Platform
A system image for the emulator, such as
ARM EABI v7a System Image
6. Go to https://developer.android.com/tools/sdk/ndk/index.html and download Android NDK for Windows release 10d (at the time of this post) and extract in C:\Android\android-ndk-r10d
7. Go to https://github.com/alkresin/HDroidGUI and click on 'Download ZIP'. Unzip on C:\Android\projects\HDroidGUI
8. Edit the file C:\Android\projects\HDroidGUI\setenv.bat and change paths according to the location of the tools you've installed. With the versions installed at the time of this post, it should look as this:
@set path=c:\harbour\bin;%PATH%;
@set HRB_BIN=c:\harbour\bin
@set HRB_INC=c:\harbour\include
@set ANDROID_HOME=c:\Android\sdk
@set BUILD_TOOLS=%ANDROID_HOME%\build-tools\21.1.2
@set NDK_HOME=c:\Android\android-ndk-r10d
@set JAVA_HOME=C:\PROGRA~1\java\jdk1.7.0_75
@set ADB=%ANDROID_HOME%\platform-tools\adb.exe
@set ANDROID_JAR=%ANDROID_HOME%\platforms\android-21\android.jar
Tips:
- Please, be careful: Path names changes with tools versions!
- JAVA_HOME could be different according your Windows version and language. Please, check it.
- I have Harbour installed at c:\harbour. If that is not your path, please change it as needed. If you do not have Harbour installed, please download from: http://sourceforge.net/projects/harbour ... urce=files and unzip at c:\harbour
9. Build HDROIDGUI: C:\Android\projects\HDroidGUI\BuildAll.bat
10. Now, we will download a sample project called HDCALCUL. Go to https://github.com/alkresin/hdcalcul and click on 'Download ZIP'. Unzip on c:\hdcalcul
11. build the .apk running: c:\hdcalcul\build.bat. The .apk will be generated at c:\hdcalcul\bin. To avoid errors about keystore, please, delete the file 'myrelease.keystore'.
12. To test it, you only must to copy the .apk generated file to an Android device
and run it.
You can do that in many different ways. In my case, I do file transfers via FTP and
launch apks from a file management app.
Don't forget to change your device configuration to allow application installation
from sources different than Play Store.
Enjoy!
HDROIDGUI SETUP TUTORIAL (re-edited and translated)
Hi Roberto,
Thank you for your contribution in this tutorial.
What I have noted the script of C:\Android\projects\HDroidGUI\setenv.bat you have indicated as:
@set JAVA_HOME=C:\ARCHIV~1\java\jdk1.7.0_75
And in your previous item you indicate to be installed at C:\Program Files\java\jdk1.7.0_75.
Even considering jdk could be differed by its version, in that script shall it be not found because setenv.bat is lie as ARCHIV~1. IMHO should it be PROGRA~1 (Program Files) instead that.
I do not know if this is a No sé por que indicaste diferente, no sé si es una peculiarity from local version of Windows but for me is working like as PROGRA~1.
Shall it be re-edited or is this correct ?
When C:\Android\projects\HDroidGUI\buildall.bat execution is displaying an error due missing lib\armeabi\libh4droid.so file :(
Could you tell me if C:\hdcalcul\build.bat and C:\Android\projects\HDroidGUI\buildall.bat files must be corrected with lib\libh4droida.a in place of lib\armeabi\libh4droid.so ?
Rgds
HDROIDGUI SETUP TUTORIAL (UPDATED)
I've note Roberto changed your instruction. Thank you for your providences. :)
Some changing I made by my account due non response about:
Roberto Lopez wrote: then build the .apk running: c:\hdcalcul\build.bat. The .apk will be generated at c:\hdcalcul\bin
Some error occured when tried to execute this:
C:\hdcalcul>call c:\Android\sdk\build-tools\21.1.2\dx.bat --dex --output=bin/classes.dex obj \android\projects\hdroidgui\libs
 '\android\projects\hdroidgui\obj\local\armeabi\libharbour.so'...
 '\android\projects\hdroidgui\lib\libh4droida.a'...
keytool error: java.lang.Exception: Key pair not genearted; alias <key2> already exists
        at sun.security.tools.KeyTool.doGenKeyPair(KeyTool.java:1529)
        at sun.security.tools.KeyTool.doCommands(KeyTool.java:969)
        at sun.security.tools.KeyTool.run(KeyTool.java:340)
        at sun.security.tools.KeyTool.main(KeyTool.java:333)
*Red color was translated from portuguese. Orginal text: Par de chaves não gerado; o alias <key2> já existe
And at final one warning message:
Warning:
No -tsa or -tsacert is provided and this jar is not timestamped. Without a times
tamp, users may not be able to validate this jar after the signer certificate's
expiration date (2042-07-13) or after any future revocation date.
Verifying alignment of bin/hdcalcul.apk (4)...
      50 META-INF/MANIFEST.MF (OK - compressed)
    388 META-INF/KEY2.SF (OK - compressed)
    793 META-INF/KEY2.RSA (OK - compressed)
   1911 AndroidManifest.xml (OK - compressed)
   2777 classes.dex (OK - compressed)
   8870 \android\projects\hdroidgui\obj\local\armeabi\libharbour.so (OK - compressed)
  986691 \android\projects\hdroidgui\lib\libh4droida.a (OK - compressed)
Verification succesful
Files were created at C:\hdcalcul\bin:
hdcalcul.apk
hdcalcul.signed.apk
hdcalcul.unsigned.apk
classes.dex
Somebody got successful to run this hdcalcul project ?
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: HDROIDGUI SETUP TUTORIAL (UPDATED)
Post by dragancesu »
I managed to create and run .apk
The second time I started build.bat I received such a message
I delete myrelease.keystore and did not report an error next time
there is probably preserved certificate
Re: HDROIDGUI SETUP TUTORIAL (re-edited and translated)
Pablo César wrote:Hi Roberto,
Rgds
I've stopped in this point with:
Errors while compiling C sources
How to do next step?
I was also unsuccessfull with this, Marek... :(
Re: HDROIDGUI SETUP TUTORIAL (UPDATED 2015.02.27)
I found such an error describe:
obj/local/armeabi/objs/h4droid/hdmain.o:hdmain.c:symbols_table: error: undefined reference to 'HB_FUN___BREAKBLOCK'
make: *** [obj/local/armeabi/libh4droid.so] Error 1
I've addec some code:
FUNCTION __BreakBlock()
   RETURN {| e | Break( e ) }
to HDroidGUI\src\prg\hdmain.prg
and I passed to next errors:
src\su\harbour\hDroidGUI\Harbour.java:202: error: cannot find symbol
    private View CreateView( String sContent ) {
  symbol:   class View
src\su\harbour\hDroidGUI\Harbour.java:343: error: cannot find symbol
    private static void SetSize( View mView, String [][] aParams ) {
  symbol:   class View
src\su\harbour\hDroidGUI\Harbour.java:560: error: package DialogInterface does n
ot exist
    private static class BtnClickListener implements DialogInterface.OnClickList
ener {
src\su\harbour\hDroidGUI\Harbour.java:569: error: cannot find symbol
        public void onClick(DialogInterface dialog, int id) {
  symbol:   class DialogInterface
src\su\harbour\hDroidGUI\Harbour.java:71: error: cannot find symbol
       mainView = CreateActivity( (Activity)context, sMain);
  symbol:   class Activity
src\su\harbour\hDroidGUI\Harbour.java:76: error: cannot find symbol
          LinearLayout ll = new LinearLayout(context);
  symbol:   class LinearLayout
src\su\harbour\hDroidGUI\Harbour.java:77: error: cannot find symbol
          ll.setOrientation(LinearLayout.VERTICAL);
  symbol:   variable LinearLayout
src\su\harbour\hDroidGUI\Harbour.java:79: error: cannot find symbol
          TextView textview = new TextView(context);
  symbol:   class TextView
src\su\harbour\hDroidGUI\Harbour.java:92: error: cannot find symbol
       View rootView;
  symbol:   class View
src\su\harbour\hDroidGUI\Harbour.java:122: error: cannot find symbol
src\su\harbour\hDroidGUI\Harbour.java:133: error: cannot find symbol
src\su\harbour\hDroidGUI\Harbour.java:135: error: cannot find symbol
                   ll.setOrientation(LinearLayout.HORIZONTAL);
src\su\harbour\hDroidGUI\Harbour.java:141: error: cannot find symbol
          SetSize( (View)ll, aParams );
  symbol:   class View
src\su\harbour\hDroidGUI\Harbour.java:154: error: cannot find symbol
       View mView;
  symbol:   class View
src\su\harbour\hDroidGUI\Harbour.java:206: error: cannot find symbol
       View mView;
  symbol:   class View
src\su\harbour\hDroidGUI\Harbour.java:233: error: cannot find symbol
          TextView mtextview = new TextView(context);
src\su\harbour\hDroidGUI\Harbour.java:251: error: cannot find symbol
          Button mButton = new Button(context);
  symbol:   class Button
src\su\harbour\hDroidGUI\Harbour.java:262: error: package View does not exist
                   mButton.setOnClickListener(new View.OnClickListener() {
src\su\harbour\hDroidGUI\Harbour.java:274: error: cannot find symbol
          EditText medit = new EditText(context);
  symbol:   class EditText
src\su\harbour\hDroidGUI\Harbour.java:287: error: package View does not exist
                   medit.setOnKeyListener(new View.OnKeyListener() {
src\su\harbour\hDroidGUI\Harbour.java:304: error: cannot find symbol
          CheckBox mche = new CheckBox(context);
  symbol:   class CheckBox
src\su\harbour\hDroidGUI\Harbour.java:326: error: cannot find symbol
          ScrollView sv = new ScrollView(context);
  symbol:   class ScrollView
src\su\harbour\hDroidGUI\Harbour.java:329: error: package LinearLayout does not
exist
          LinearLayout.LayoutParams parms = new LinearLayout.LayoutParams(
exist
src\su\harbour\hDroidGUI\Harbour.java:330: error: package LinearLayout does not
exist
                LinearLayout.LayoutParams.MATCH_PARENT,LinearLayout.LayoutParams
.MATCH_PARENT);
exist
.MATCH_PARENT);
src\su\harbour\hDroidGUI\Harbour.java:357: error: package LinearLayout does not
exist
          LinearLayout.LayoutParams parms;
src\su\harbour\hDroidGUI\Harbour.java:359: error: package LinearLayout does not
exist
             iHeight = LinearLayout.LayoutParams.MATCH_PARENT;
src\su\harbour\hDroidGUI\Harbour.java:361: error: package LinearLayout does not
exist
             iWidth = LinearLayout.LayoutParams.MATCH_PARENT;
src\su\harbour\hDroidGUI\Harbour.java:363: error: package LinearLayout does not
exist
             parms = new LinearLayout.LayoutParams(iWidth,iHeight,1);
src\su\harbour\hDroidGUI\Harbour.java:365: error: package LinearLayout does not
exist
             parms = new LinearLayout.LayoutParams(iWidth,iHeight);
src\su\harbour\hDroidGUI\Harbour.java:376: error: cannot find symbol
          iColor = Color.parseColor( sColor );
  symbol:   variable Color
src\su\harbour\hDroidGUI\Harbour.java:453: error: cannot find symbol
       Log.i(TAG, message);
  symbol:   variable Log
src\su\harbour\hDroidGUI\Harbour.java:460: error: cannot find symbol
       TextView tview = null;
src\su\harbour\hDroidGUI\Harbour.java:475: error: cannot find symbol
             tview = (TextView) mainView.findViewWithTag( stag );
src\su\harbour\hDroidGUI\Harbour.java:501: error: package AlertDialog does not e
xist
       AlertDialog.Builder builder = new AlertDialog.Builder(context);
xist
src\su\harbour\hDroidGUI\Harbour.java:555: error: cannot find symbol
        AlertDialog alert = builder.create();
  symbol:   class AlertDialog
src\su\harbour\hDroidGUI\Harbour.java:568: error: method does not override or im
plement a method from a supertype
        @Override
src\su\harbour\hDroidGUI\Harbour.java:578: error: cannot find symbol
          return Environment.getExternalStoragePublicDirectory(Environment.DIREC
TORY_DOCUMENTS) + "/";
  symbol:   variable Environment
src\su\harbour\hDroidGUI\Harbour.java:580: error: cannot find symbol
TORY_PICTURES) + "/";
src\su\harbour\hDroidGUI\Harbour.java:582: error: cannot find symbol
TORY_MUSIC) + "/";
TORY_MUSIC) + "/";
src\su\harbour\hDroidGUI\Harbour.java:584: error: cannot find symbol
TORY_MOVIES) + "/";
TORY_MOVIES) + "/";
src\su\harbour\hDroidGUI\Harbour.java:586: error: cannot find symbol
TORY_DOWNLOADS) + "/";
src\su\harbour\hDroidGUI\Harbour.java:588: error: cannot find symbol
TORY_RINGTONES ) + "/";
src\su\harbour\hDroidGUI\Harbour.java:590: error: cannot find symbol
          return Environment.getExternalStorageDirectory() + "/";
84 errors
It's caused by missing some files, I think.
jparada
Post by jparada »
Hi Roberto,
To create a new project I just copy the entire contents of hdcalcul and edit all files that reference hdcalcul and does not work. how can I create a new project?.
I read a little about newproject.prg file in the util folder, but for now I do not know how to use it.
I appreciate any help.
Thanks.
Javier
