HMG DOCS!
- HMG Founder
HMG DOCS!
The documentation is (perhaps) the most 'weak' thing on MiniGUI library.
There is a reason for that:
- 3 Window types
- 34 Controls
- 133 Properties
- 29 events
- 26 methods
- 56 Functions
- 33 Commands
- And LOTS of other things
As you can imagine it is very time consuming to create a professional grade reference for all library elements.
I've decided to invest all of my available time to complete the documentation, at least, in its basic form, and I've finished it.
I'll include in the next HMG full release.
Meanwhile, I'm attaching it to this message for testing.
Please, If you find some missing or erroneous thing, let me know to correct it prior the release.
Thanks in advance.
- 3 Window types
- 34 Controls
- 133 Properties
- 29 events
- 26 methods
- 56 Functions
- 33 Commands
Thanks in advance.
- hmgdoc.rar
- (66.72 KiB) Downloaded 445 times
- luisvasquezcl
Re: HMG DOCS!
Excelente Roberto,
muchas gracias.
muchas gracias.
- salamandra
- DBs Used: DBF, MySQL, SQL
Re: HMG DOCS!
Thank you very much !!
[]'s Salamandra
Re: HMG DOCS!
Thanks a lot Roberto!
We really need it
If I am not wrong, I found \HMG\DOC folder already contains some documentation.
I was trying to find some information about GetTextWidth() function. But, I didn't find it in my first search.
There is a ".chm" help for hmg, created by Rathinagiri (which is really helpful to me). So, can we expect your documentation will be merged with Rathi's chm file?
We really need it
- HMG Founder
Re: HMG DOCS!
Yes, but it was not finished.sudip wrote: If I am not wrong, I found \HMG\DOC folder already contains some documentation.
This is an internal function (it returns the size in pixels of a string).sudip wrote: I was trying to find some information about GetTextWidth() function. But, I didn't find it in my first search.
It requires low level knowledge to be used, since you must pass it the font handle besides the string.
Re: HMG DOCS!
Thank´s master Roberto for this documentation.
I believe that was for sure hard work. Thank´s a lot
regards,
regards,
- HMG Founder
Re: HMG DOCS!
When the documentation be completely finished and revised it could be easily converted to any format (chm, pdf, etc).sudip wrote: There is a ".chm" help for hmg, created by Rathinagiri (which is really helpful to me). So, can we expect your documentation will be merged with Rathi's chm file?
- HMG Founder
Re: HMG DOCS!
And yes. It could easily merged, since Rathinagiri had left blanks for non documented thingssudip wrote: There is a ".chm" help for hmg, created by Rathinagiri (which is really helpful to me). So, can we expect your documentation will be merged with Rathi's chm file?
I hope that he can do that soon.
Re: HMG DOCS!
Roberto,
Thank you very much.
And now it is very good
Actually, I saw some reference of GetTextWidth() function in Rathinagiri's Grid2Print utility and tried to find it out in the help. Thank you very much for the information about this function. Sorry to bother you. I didn't know it's a low level function.
Documentation is a very hard work, but it is very essential both for novice user (like me) and experienced user.
Thank you again for such "hard work" for us
