The Clipper on HMG
dragancesu
DBs Used: DBF, MySQL, Oracle
The Clipper on HMG
Post by dragancesu »
I gave up on making program, I wrote a guide for beginners
If someone happens to like I can continue
manual1.zip
(817.31 KiB) Downloaded 664 times
Little manual for beginners
Hi Dragan,
Nice work and thank you to share with us. :D
I have some questions and a very important propose to do to you, if you are interested to know.
B.Rgds
dragancesu
Little manual for beginers
Yes, of course
dragancesu wrote:Yes, of course
Thank for this oportunity. :)
My questions:
  • Why your Harbour Wikipedia URL in your text:
    is redirecting to this one: http://en.wikipedia.org/wiki/Harbor ? :shock:
  • In your text:
    Now the current version 3.3.1 you need to
    download and install. At the end of
    installation, set the system variable, add
    C:\HMG in the PATH and define
    HMGPATH = C:\HMG
    Why are you indicating to make path of HMGPATH ?
    Sorry to ask if there is any reason that could be part of HMG installation and functionality of HMG that I'm unknown.
    Because I know, this is no necessary to work with HMG, but please let me know your reasons.
  • When you say:
    New extensions are
    HPB - hmg project
    RC - resource file
    These extension hbp (correct extension, not hpb) belong to Harbour (not HMG) and rc extension file came from Microsoft Windows resource scripts. We use WinRes which is a GNU Binary Utilities (not HMG). So why you said new extension file from HMG ?
  • In your capture screen, the picture is showing us some files/folders is not belonging to the HMG installation (hmgcase, Notepad++, HMGSQL...)
My suggestions:
  • To write only in one language. When ready, make it for other languages. Because for who doesn't understand Serbian make hard to pay more the focus.
  • Page #3, you can add windows 64-bit too
  • Page #5, IMHO you should not encourage change the installation folder from initial and recommended path of installation pack which is always changing according HMG version for one fixed folder name as "C:\HMG" (IMHO this is not good practice)
  • Page #5, when you said: "For the compilation of the program should be run BUILD.BAT" you can add "or run/compile at IDE" (two ways for build app).
  • You should write something for console mode. You can explain you can use our build.bat and especially HMG IDE, to recompile Clipper source with few changing to generate console apps.
I wish to make an important propose and I hope you could understand that I do not want with this, never belittle your work. IMHO it will be most useful to enrich our documentation HMG instead to create many other documentation. This is really very interesting propose. So, in this way, you would pass as a contributor to re-edit all our hmgdoc files (see at C:\hmg.3.3.1\DOC\data) and re-write with some examples and some undocumented cases in HMG.
I know it's a hard work, but it will be more powrful to work on in hmgdoc than create a other ones.
I hope be useful my comments and I really wish you take hmgdoc project and re-write it making each time better.
B.Rgds
quartz565
Re: Little manual for beginners
Post by quartz565 »
Continued Dragan, please .. :!:
Continue making your examples simple and understandable as is. No need - initially at least demonstration complicated programming.
Thank you!
Nikos.
os: Windows Server 2019 - 64
Very good Dragancesu initiative, congratulations !!!
In my humble opinion, I think it would be better to Pablo César, because the information would be ever present to all with HMG when it is installed!
And that handle two languages in a document is complicated, because if I want to translate a section, as it is copied twice using a translator would be best all in one language!
dragancesu
Pablo
The title should be "the Clipper on hmg"
Link is http://en.wikipedia.org/wiki/Harbour_%28software%29 but is poorly transferred / written
hmgpath? I do not know, it seemed logical to me
New extensions? in relation to the Clipper, HPB is clearly an error
Your suggestions:
- Write in one language ok
- Use build.bat to start, IDE will be described in the next part
- The installation folder, a matter of habit, mine is C: \ HMG stable version, when new version goes into your folder
Thanks for the suggestions
The Clipper on HMG
Ok Dragan, I've understood and subject of this topic, I changed as recommended.
Thank you for your clarification and providence. :)
Nice to help you.
Re: The Clipper on HMG
Nice job, Dragan!
