Transform labels' backcolor to grayscale
When we need to become Enabled to .F. for LABELS, BackColor doens't change ! :o
I can force to gray color, but there are many different tones of gray and depending what color is that (bright or dark color). Then I should use accordingly to the right tone of gray. That's the problem. :(
Upto till now...
Because I found a way, not only with backcolor's labels also with any colours. A simple solution I fund with this:
Function ChngToGray(aColor)
Local nGray:=(aColor[1]+aColor[2]+aColor[3])/3
Return {nGray,nGray,nGray}
Of course with help of internet...
See this demo:
DEFINE WINDOW Form_1 ;
	WIDTH 230 HEIGHT 130 ;
	TITLE "HMG Demo" ;
	MAIN ;
	FONT "Arial" SIZE 10 BACKCOLOR YELLOW
	DEFINE LABEL Label_9
        ROW    20
        COL    24
        WIDTH  90
        HEIGHT 20
        VALUE "Test"
        FONTNAME "Arial"
        FONTSIZE 9
        BACKCOLOR BLUE
        FONTCOLOR Nil
    END LABEL
    DEFINE BUTTON Button_3
        ROW    70
        COL    103
        WIDTH  100
        HEIGHT 28
        ACTION {|| Form_1.Label_9.BackColor := ChngToGray(Form_1.Label_9.BackColor)}
        CAPTION "Enabled Label_9"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
    END BUTTON
CENTER WINDOW Form_1
ACTIVATE WINDOW Form_1
Anyway if you want to disable any control, you still will need to change it, as follows:
<WindowName>.<ControlName>.Enabled := .F.
I hope, all of you enjoy it ! :D
Re: Transform labels' backcolor to grayscale
Pablo,
this is the best algorithm (C code):
#define bt_RGB_TO_GRAY(R,G,B) (INT)((FLOAT)R * 0.299 + (FLOAT)G * 0.587 + (FLOAT)B * 0.114)
Is very easy the adaptation to HB.
Thank you Claudio ! :D
Your algorithm is really better because I have adapted and compared.
Function ChngToGray(aColor,nGrayLevel)
Local nGray := ( (aColor[1] * 0.299) + (aColor[2] * 0.587) + (aColor[3] * 0.114) )
HB_DEFAULT( @nGrayLevel, 0.0 )
If nGrayLevel > 1.0
   nGrayLevel := 1.0
Endif
Return {aColor[1] + (nGray - aColor[1]) * nGrayLevel, aColor[2] + (nGray - aColor[2]) * nGrayLevel, aColor[3] + (nGray - aColor[3]) * nGrayLevel}
Nice one ! :D
I improved my function similar to BT. :)
I did not see this instruction in BT. :oops:
But please Claudio, tell me: is it right Label's BackColor do not becoming gray when at Enabled := .F. ?
Pablo César wrote: But please Claudio, tell me: is it right Label's BackColor do not becoming gray when at Enabled := .F. ?
Pablo, this works fine for my (Win 7):
	DEFINE WINDOW Form_Main ;
		WIDTH 640 HEIGHT 480 ;
		TITLE 'Main Window' ;
		MAIN
		@ 200,250 LABEL Label_1 ;
		WIDTH 150 HEIGHT 40 ;
		VALUE 'Click Me !' ;
		ACTION MsgInfo('Label Clicked!!!') ;
		FONT 'Arial' SIZE 24  CENTERALIGN
		@ 10,10 LABEL Label_2 ;
		AUTOSIZE ;
		VALUE '...' ;
		ACTION msginfo('test')
	Form_Main.Label_2.Value := 'Hello All, This Is An AutoSIzable Label!!!'
   Form_Main.Label_1.Enabled := .F.
   Form_Main.Label_2.Enabled := .F.
	CENTER WINDOW Form_Main
	ACTIVATE WINDOW Form_Main
Sorry Claudio for me insist, but probably you do not understood what I said.
The problem is in BlackColor of Label. See this example:
	WIDTH 230 HEIGHT 150 ;
	TITLE "HMG Demo" ;
	MAIN ;
        ROW    20
        COL    24
        WIDTH  90
        HEIGHT 20
        VALUE "Test"
        FONTNAME "Arial"
        FONTSIZE 9
        BACKCOLOR BLUE
        FONTCOLOR Nil
    END LABEL
        ROW    70
        COL    10
        WIDTH  200
        HEIGHT 28
        ACTION {|| Form_1.Label_9.Enabled := .F.}
        CAPTION "Enabled to .F. for Label_9"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
    END BUTTON
As you can see below, the blue color is still blue:
I have attached my executable file. I do not believe is a bug in my HMG version.
Demo2.rar
(1.05 MiB) Downloaded 447 times
Or it would be at my OS ? :? (I do not use Aero)
Pablo César wrote:Or it would be at my OS ? (I do not use Aero)
Ok, I understand now your question.
Windows set to gray only the text, see this:
   TITLE "HMG Demo" ;
   MAIN ;
   aLabelBackColor := GREEN
        ROW    20
        COL    24
        WIDTH  90
        HEIGHT 20
        VALUE "Test"
        FONTNAME "Arial"
        FONTSIZE 9
        BACKCOLOR aLabelBackColor
        FONTCOLOR Nil
    END LABEL
        ROW    70
        COL    10
        WIDTH  200
        HEIGHT 28
        ACTION {|| Form_1.Label_9.Enabled := .NOT. Form_1.Label_9.Enabled, SetControlBackColorGray ( "Label_9", "Form_1", aLabelBackColor ) }
        CAPTION "Enabled/Disable Label_9"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
    END BUTTON
PROCEDURE SetControlBackColorGray ( cControlName, cParentName, aBackColor )
LOCAL nGray
  IF _IsControlEnabled ( cControlName, cParentName ) == .T.
      SetProperty ( cParentName, cControlName, "BackColor", aBackColor)
     nGray := INT ( (aBackColor[1] * 0.299) + (aBackColor[2] * 0.587) + (aBackColor[3] * 0.114) )
     SetProperty ( cParentName, cControlName, "BackColor", { nGray, nGray, nGray } )
Thank you Claudio for your clarification.
But making tests with FontColor:=BLACK and BackColor:={0,0,128} (dark blue), I got following results:
With your last code ( nGray := INT ( (aBackColor[1] * 0.299) + (aBackColor[2] * 0.587) + (aBackColor[3] * 0.114) ) ):
With my first example ( nGray:=(aColor[1]+aColor[2]+aColor[3])/3 ):
I know that colors BLACK with DARK_BLUE is no ideal for editing source. But if I give chance to user for changing, I need to do it in better results.
It's strange to see the difference and I made many other combinations, perhaps I saw this formula INT ( (aBackColor[1] * 0.299) + (aBackColor[2] * 0.587) + (aBackColor[3] * 0.114) ) ) in many C codes but maybe for images ? I don't know.
