Textbox Password Property ...
hmgchang
Post by hmgchang »
Dear Masters,
The Password property of the TextBox control can be set as .T. or .F. when we defined/designed...
But i get an error saying syntax error while tried to change :
Main.txtPass.Password := .T.
or are there any other ways to alter the property ?
TIA
best rgds,
Chang
Just Hmg It !
Re: Textbox Password Property ...
No entiendo el porque quieres alterar esta propiedad, o es Texbox "normal" ó para "Password".
Creo que solo lo puedes hacer al momento de la definición.
En la lista de propiedades no aparece esta propiedad.
I do not understand why you want to alter this property or is "normal" or to "Password" TexBox.
I think you can only do when the definition.
In the list of properties this property does not appear.
      DEFINE TEXTBOX <Controlname>
            PASSWORD <lValue>
      END TEXTBOX
Properties:
- Value
- Enabled
- Visible
- Row
- Col
- Width
- Height
- FontName
- FontSize
- FontBold
- FontItalic
- FontUnderline
- FontStrikeout
- ToolTip
- BackColor
- FontColor
- DisabledBackColor
- DisabledFontColor
- CaretPos
- ReadOnly
- Name (R)
- TabStop (D)
- Field (D)
- Parent (D)
- InputMask (D)
- Format (D)
- MaxLength (D)
- RightAlign (D)
- HelpId (D)
- CaseConvert (D)
- DataType (D)
D: Available at control definition only
R: Read-Only
hmgchang
Post by hmgchang »
Thks for your info, but...
so... if the checkbox is checked...
then i need to display the password entered at the textbox...
my idea is to just set the password property to .F.
and when the checkbox is unchecked... then
but it wont compile.....
pls advise n TIA
best rgds
Chang
Just Hmg It !
Chang,
I believe it has been hardcoded in order to avoid to see passwords.
Against creating checkbox Show password and display eneted password in Password field, you can create something like in widows 8 - picture with eye, when you go to this picture, the password will show in balloon.
hmgchang wrote:...
Hi Chang,
Please be so kind to review the following simple sample:
#include "minigui.ch"
FUNCTION Main
	DEFINE WINDOW Form_1 ;
		WIDTH 400 ;
		HEIGHT 300 ;
		TITLE "MiniGUI Password Demo" ;
		MAIN ;
		FONT "Arial" SIZE 10
	MakePasswordControl( 'Secret', .T. )
	@ 40,10 CHECKBOX Check_1 CAPTION 'Show password' ;
		VALUE .F. ;
		WIDTH 120 ;
		TOOLTIP 'CheckBox Control' ;
		ON CHANGE MakePasswordControl( Form_1.Text_pass.Value, ! Form_1.Check_1.Value )
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
RETURN Nil
FUNCTION MakePasswordControl( cPass, lShow )
	IF IsControlDefined (Text_pass, Form_1) == .T.
		Form_1.Text_pass.Release
	DEFINE TEXTBOX Text_pass
		PARENT   Form_1
		ROW	 10
		COL	 10
		VALUE    cPass
		PASSWORD lShow
		FONTNAME "Arial"
		FONTSIZE 10
		TOOLTIP  'Password TextBox'
		MAXLENGTH 16
	END TEXTBOX
RETURN lShow
Hope that useful :idea:
PeteWG
Post by PeteWG »
Hi Chang,
as already stated, PASSWORD property isn't available/changeable at runtime.
However you can achieve what you're looking for with various tricks like this one posted by Grigory.
below is an other approach which you might consider.
FUNCTION Main
      WIDTH 400 ;
      HEIGHT 120 ;
      TITLE "Show/hide Password" ;
      MAIN ;
   DEFINE TEXTBOX Pass_Shown
      PARENT   Form_1
      ROW    30
      COL    70
      VALUE  ""
      FONTNAME "Arial"
      FONTSIZE 10
      MAXLENGTH 16
		INVISIBLE .T.
   END TEXTBOX
   DEFINE TEXTBOX Pass_Hidden
      PARENT   Form_1
      ROW    30
      COL    70
      VALUE    ""
      PASSWORD .T.
      FONTNAME "Arial"
      FONTSIZE 10
      MAXLENGTH 16
   END TEXTBOX
   @ 33,200 CHECKBOX Check_1 CAPTION 'Show password' ;
      VALUE .F. ;
      WIDTH 120 ;
      ON CHANGE ShowPassWord( This.Value )
RETURN Nil
PROCEDURE ShowPassWord( lShow )
	IF lShow
		Form_1.Pass_Shown.Value := Form_1.Pass_Hidden.Value
		DoMethod( 'Form_1', 'Pass_Hidden', 'Hide' )
		DoMethod( 'Form_1', 'Pass_Shown', 'Show' )
		Form_1.Pass_Hidden.Value := Form_1.Pass_Shown.Value
		DoMethod( 'Form_1', 'Pass_Hidden', 'Show' )
		DoMethod( 'Form_1', 'Pass_Shown', 'Hide' )
rgrds,
Pete
Hola PeteGW,
Existe la propiedad:
INVISIBLE .T. en HMG? que versión usas?
Hola Chang,
Yo lo hago así:
FUNCTION Main
LOCAL cPass := "Secret"
      WIDTH 400 ;
      HEIGHT 300 ;
      MAIN ;
      PARENT   Form_1
      ROW    10
      COL    10
      VALUE    cPass
      PASSWORD .T.
      FONTNAME "Arial"
      FONTSIZE 10
      MAXLENGTH 16
   END TEXTBOX
   DEFINE TEXTBOX Text_NoPass
      PARENT   Form_1
      ROW    10
      COL    10
      VALUE    cPass
      PASSWORD .F.
      FONTNAME "Arial"
      FONTSIZE 10
      MAXLENGTH 16
   END TEXTBOX
      VALUE .F. ;
      WIDTH 120 ;
      ON CHANGE Cambia(This.Value)
   Form_1.Text_NoPass.Hide
RETURN Nil
FUNCTION Cambia(lValue)
   IF lValue == .F.
		Form_1.Text_pass.Show
		Form_1.Text_pass.Hide
		Form_1.Text_NoPass.Show
PeteWG
Post by PeteWG »
Javier Tovar wrote:Hola PeteGW,
Hi Havier
INVISIBLE property last time i looked at 3.3.1. docs, was there. You mean it doesn't work? ( I didn't test with HMG, though)
I do use both HMG & Mingui extended.
PS. btw, your sample you posted needs some edit. check it and i'm sure you'll find what i mean. ;-)
rgrds,
Pete
