Hola :
Ultimamente en forma aleatoria el sistema me provoca este error que les posteo en el control browse (Form_100.Browse_1.Refresh) , estoy realizando un ejemplo simple para reproducirlo , aun asi en mi pc con una copia del sistema no puedo provocarlo , pero me gustaria saber si esto puede ser un error del sistema o un bug del control browse .
Mario Mansilla
hi:
Lately the system randomly gives me this error posting them on the browse (Form_100.Browse_1.Setfocus) control'm doing a simple example to reproduce, even so my pc with a copy of the system can not provoke him, but I wonder if this may be a mistake system or browse bug control.
Mario Mansilla
Date:22/11/2014 Time: 19:20:07
Error BASE/1132 Error de rango: acceso al array
Called from _BROWSEGETVALUE(1269)
Called from _BROWSEREFRESH(1046)
Called from EVENTS(2229)
Called from REDRAWWINDOW(0)
Called from _REFRESH(3796)
Called from DOMETHOD(8226)
Called from ACTUALIZA_VENTA(2361)
Called from ACEPTAR_VENTA(2154)
Called from (b)ALTA_VENTA(292)
Called from _DOCONTROLEVENTPROCEDURE(5622)
Called from EVENTS(1640)
Called from DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(5290)
Called from ALTA_VENTA(989)
Called from (b)FACTURA(1178)
Called from FACTURA(150)
Called from (b)MAIN(112)
Called from EVENTS(1602)
Called from MODI_VENTA(1090)
Called from (b)FACTURA(811)
Called from EVENTS(2427)
Called from DOMETHOD(8146)
Called from MAIN(169)
Problema Control Browse
- srvet_claudio
Re: Problema Control Browse
The _BROWSEREFRESH() function (line 1046) calls _BROWSEGETVALUE() function where occurs an overflow of the array (the variable i is out of range, at line number 1269).Mario Mansilla wrote: Date:22/11/2014 Time: 19:20:07
It is rare because that should not happen.
Hola Mario
Quizás debas revisar si no estás pasando algún valor diferente en "ACTUALIZA_VENTA(2361)", puede que de ahí venga el problema.
Hola Mario Mansilla,
Puede ser lo que dice el Dr. Claudio Soto o lo que dice Andrés o..., pero siempre sugiero que se suba un demo mínimo completo para poder probar, de otra manera es difícil.
Yo te diria fijate desde la primer linea que te da el error y siguelo:
SaludosCalled from MAIN(169)
