how to put a table in the clipboard
- dragancesu
in the examples I've found to put some text in the clipboard
Question: how to put a table (or part) to the clipboard, in larger systems, it is the simplest way to transfer data from a table in Excel (for example)
Re: how to put a table in the clipboard
You can separate cells by chr(9) and end rows with chr(13)+chr(10)
Such a prepared string you should paste to clipboard:
System.Clipboard := cClipboard
- dragancesu
Thanks for the tip
Based on that, I made a program that creates a program for it, is independent but it is easily converted to a routine
What better way to transfer the date field?
- program.zip
- (1.44 KiB) Downloaded 344 times
Yeah, you're right Marek !
Dragan, please see this example: http://hmgforum.com/viewtopic.php?p=22771#p22771
- dragancesu
I saw a program ok but I need something different
HMG in the windows world, and as I understand Clipboard is a powerful system, other programs to use so I thought I take this opportunity
Often faced with the problem of data transmission, Excel knows to open DBF, knows and openoffice but the question is whether it knows the user. I think that is enough for click button "Copy to the clipboard <Ctrl-C>", open Excel (or OpenOffice) and choose Paste <Ctrl-V>
No entendi
Hi Molmol wrote:You can separate cells by chr(9) and end rows with chr(13)+chr(10)
As far as I know you are an expert on working with Excel files
My question is : which method is the best for import / export Excel files ?
Better : would you give a SSW sample ?
Thanks in advance
Sr. Esgici,
Que es "SSW", busque información sin buenos resultados.
Hola Javier...
cuando busques algo especifico que este en un foro como en este caso SSW al buscarlo en Google usa
"SSW hmgforum" por supuesto sin comillas, te traerá un enlace y a simple vista esto
SSW (short, simple and working) ...
Gracias DanielMaximiliano por el Tip!
