Grid Out of Focus after Edit
Hello,
I don't know whether it's a bug or not. I found that after editing a cell/row in a grid (especially when CELLNAVIGATION is not used), form became out of focus.
Again, I am telling, I am not sure whether it's a bug or not. :?
Please check this.
Re: Grid Out of Focus after Edit
sudip wrote:Hello,
Please check this.
I can't verufy that, so, please, if you can post a little sample, could be very useful...
Lo que comenta sudip es correcto.
Sucede cuando editas la primera vez; al terminar de editar, el grid pierde el foco. Cuando vas a editar nuevamente la fila conserva el foco.
Esto no es nuevo, viene sucediendo desde varias versiones anteriores.
What sudip says is correct.
It happens when editing the first time, to finish editing, the grid loses focus. When you go back to edit the row keeps the focus.
This is not new, been happening since several earlier versions.
Luis VAsquez
luisvasquezcl wrote: What sudip says is correct.
Yes, that is I want to say.
A small sample is :-
      @ 96, 220 GRID grdCompoundRm ;
         WIDTH 300 ;
         HEIGHT 250 ;
         HEADERS { 'Raw Material', 'Qty', '%' } ;
         WIDTHS { 150, 75, 55 } ;
         COLUMNCONTROLS { { 'COMBOBOX', aRmnm }, ;
         { 'TEXTBOX', 'NUMERIC', '9999.999' }, ;
         { 'TEXTBOX', 'NUMERIC', '999.99%' }} ;
         CELLNAVIGATION ;
         edit ;
	      justify { 0, 1, 1 } ;
	      on LOSTFOCUS calctot() ;
	      COLUMNWHEN { { || .t. }, { || .t. }, { || .f. } }
Roberto, this is not a working sample. If you need I can send you my new project code also. :)
sudip wrote: Roberto, this is not a working sample. If you need I can send you my new project code also. :)
If you could post a complete small sample, ready to compile, it will help to me a lot.
         WIDTH 300 ;
         HEIGHT 250 ;
         CELLNAVIGATION ;
         edit ;
Your grid definition has references, to a function and an array that are unknown to me. Besides that, the eventual presence of other controls in the window or the window type could be related with the problem, so please post a complete small sample showing the problem, then I'll analyze it.
Thanks in advance.
Hello Roberto,
I have found that an out of focus problem occurs after first time edit in Grid in CHILD windows only but not in MODAL or MAIN windows.
(My net has some problems. So I shall post a complete sample after some time)
Hello Roberto,
Here is a working sample for the problem. Please run and try to change the "Qty" column of the grid first.
#include "minigui.ch"
   DEFINE WINDOW Win_1 ;
      WIDTH 700 ;
      HEIGHT 560 ;
      TITLE 'Grid Edit Problem' ;
      MAIN
      DEFINE MAIN MENU
         DEFINE POPUP 'Test'
            MENUITEM 'Test' ACTION GridTest()
         END POPUP
      END MENU
   ACTIVATE WINDOW Win_1
Function GridTest()
	aRmnm := {"Natural Rubber", "PVC", "Sulphur"}
  DEFINE WINDOW frmCompound            ;
      AT 0,0               ;
      WIDTH 635            ;
      HEIGHT 460            ;
      TITLE 'Grid'   ;
      child ;
      ON INIT FillGrid()
      @ 10, 10 GRID grdCompoundRm ;
         WIDTH 500 ;
         HEIGHT 400 ;
         CELLNAVIGATION ;
         edit ;
   CENTER WINDOW frmCompound
   ACTIVATE WINDOW frmCompound
Function FillGrid()
	local i, aGrid := { {1, 10, 0.00}, {3, 5, 0.00}, {2, 5, 0.00}}
	frmCompound.grdCompoundRm.DeleteAllItems()
	for i = 1 to len( aGrid )
		frmCompound.grdCompoundrm.additem( aGrid[ i ] )
	next
	return nil
static function CalcTot()
   local a, i, j, aTemp := { }, mTotWt := 0.00
   a := frmCompound.grdCompoundRm.value
   i := a[1]
   aTemp := frmCompound.grdCompoundRm.item( i )
   if i < 1
      return
   for j = 1 to frmCompound.grdCompoundRm.Itemcount
      mTotWt += frmCompound.grdCompoundRm.cell( j, 2 )
   next
   aTemp[ 3 ] := round(aTemp[ 2 ] / iif(empty(mTotWt), 1, mTotWt)*100, 2)
   frmCompound.grdCompoundRm.item( i ) := aTemp
   return nil
Thank you very much. :)
sudip wrote:Hello Roberto,
      WIDTH 700 ;
      HEIGHT 560 ;
      MAIN
      DEFINE MAIN MENU
         DEFINE POPUP 'Test'
         END POPUP
      END MENU
Function GridTest()
      AT 0,0               ;
      WIDTH 635            ;
      HEIGHT 460            ;
      TITLE 'Grid'   ;
      child ;
      ON INIT FillGrid()
         WIDTH 500 ;
         HEIGHT 400 ;
         CELLNAVIGATION ;
         edit ;
Function FillGrid()
	next
	return nil
   i := a[1]
   if i < 1
      return
   next
   return nil
Many Thanks!
I'll check it ASAP.
Please add the following line to the end (prior to 'return' line) in '_HMG_GRIDINPLACEEDIT' function ('h_grid.prg' file):
SETFOCUS ( _HMG_SYSDATA [3] [IDX] )
It should solve the problem.
Thanks for the report.
