Systemwide Hotkeys
Systemwide Hotkeys
As I've commented in another post, I'm working in an utility that sits in system tray.
The purpose of this utility is to capture hotkeys (systemwide) and paste a specific code number according key pressed.
It must work with focused edit control in any application.
To implement this, the hotkeys must be trapped even when our HMG app, is not the active one (remember, we are waiting in the system tray).
This situation remembers me a problem at the start of MiniGUI library development.
The "problem" was that hotkeys were available systemwide :)
Then, to solve this, I've filtered the WM_HOTKEY message, to ignore hotkeys when our app is not active.
So, the only thing required to have (optional) systemwide hotkeys is to create a publc flag (living at _HMG_SYSDATA) and according to it, activate or deactivate WM_HOTKEY filter.
A very easy to accomplish wish :)
Thanks for your attention.
Systemwide Hotkeys
Interesting Roberto ! :)
Re: Systemwide Hotkeys
Roberto Lopez wrote:Hi All,
Hi Roberto,
Please take a look for the following code's snippet from the Minigui Ext source:
   CASE nMsg == WM_HOTKEY
      // Process HotKeys
      i := AScan ( _HMG_aControlIds , wParam )
      IF i > 0
         IF _HMG_aControlType [i] == "HOTKEY"
            IF _HMG_aControlParentHandles [i] == GetActiveWindow() .OR. _HMG_GlobalHotkeys == .T.
               IF _DoControlEventProcedure ( _HMG_aControlProcedures [i] , i )
                  RETURN 0
May be it give an idea to HMG developers :?:
gfilatov wrote: Hi Roberto,
Yes, of course. It's very easy.
In fact the Windows API function 'RegisterHotKey' reference, clearly states that 'Defines a system-wide hot key': http://msdn.microsoft.com/en-us/library ... s.85).aspx.
But I've selected this API function, since is extremely easier to implement than other alternatives and (at that time) that was my main development strategy :)
Hi Roberto,
see this demo:
   DEFINE WINDOW Form_1 ;
      WIDTH 500 HEIGHT 300 ;
      TITLE 'Press ALT+F9' ;
      MAIN
      ON KEY ALT+F9 ACTION MsgInfo ("HotKey Action")
   #define WM_HOTKEY      0x0312
   CREATE EVENT PROCNAME AllHotKey() MSG WM_HOTKEY
   Form_1.Center()
   Form_1.Activate()
// If the WM_HOTKEY message was generated by a system-defined hot key, wParam will be one of the following values:
#define IDHOT_SNAPWINDOW  (-1)   // The "snap desktop" hot key was pressed
#define IDHOT_SNAPDESKTOP (-2)   // The "snap window" hot key was pressed
#define MOD_ALT       1
#define MOD_CONTROL   2
#define MOD_SHIFT     4
#define MOD_WIN       8
Function AllHotKey()
LOCAL cFormName := ""
LOCAL hWnd   := EventHWND()
LOCAL wParam := EventWPARAM()
LOCAL lParam := EventLPARAM()
   GetFormNameByHandle    ( hWnd, @cFormName )
   VK     := HIWORD (lParam)
   MOD_VK := LOWORD (lParam)
   IF MOD_VK == MOD_ALT
      MOD_VK := "ALT"
   ELSEIF MOD_VK == MOD_CONTROL
      MOD_VK := "CONTROL"
   ELSEIF MOD_VK == MOD_SHIFT
      MOD_VK := "SHIFT"
   ELSEIF MOD_VK == MOD_WIN
      MOD_VK := "WIN"
   MsgInfo ({ "HotKey --> ID: ",ID ,"   FormName: "+cFormName, "   Mod: ",MOD_VK ,"   VirtualKey: ",VK })
Return NIL
srvet_claudio wrote:Hi Roberto,
see this demo:
Nice!
I usually forget the CREATE EVENT command :)
Agil Abdullah
Post by Agil Abdullah »
Interesting. I've no idea about it before reading this topic.
Many-many thanks.
Programmer Never Surrender
