Mapping of Open and Close command
tiampei
Post by tiampei »
We use open and close method for Excel OLE object. But sometime the object will mapping to wrong AninateBox command.
Example 1, this is OK
Local hExcelApp := CreateObject("Excel.Application")
Local hWorkBook := hWorkBooks:Open("test")
hWorkBook:Close()
hExcelApp:Quit()
But if we pass extra parameters, for open and close then the compiler will map the command to _OpenAnimateBox and _CloseAnimateBox.
Example 2, NOT OK.
Local hWorkBook := hWorkBooks:Open("test", 0, .t. ) // Open in readonly mode without update external link
hWorkBook:Close(.t. , "test2") // Close and save in test2
hExcelApp:Quit()
Test Code:
Procedure Main()
   Local hWorkBook
   Local hWorkBooks := hExcelApp:WorkBooks
   Local bSaveHandler, oError
   Local cTemPath1 := GetTempFolder(), cTemPath2
   If Right(cTemPath1, 1) <> '\'
      cTemPath1 := cTemPath1 + '\'
   EndIf
   MsgInfo("Temporaray path is: " + cTemPath1)
   cTemPath2 := cTemPath1 + "test2"
   cTemPath1 := cTemPath1 + "test1"
   // Using 3 parameters will cause the HMG select OpenAnimateBox function
   // hWorkBook := hWorkBooks:Open(FileName:="D:\test.xls", UpdateLinks:=0, ReadOnly:=True)
   // hWorkBook := hWorkBooks:Open("D:\test.xls", 0, .t., 1) // This is OK
   // hWorkBook := hWorkBooks:_Open("D:\test.xls", 0,  .t.) // Try this also
   hWorkBook := hWorkBooks:Add // Add new workbook
   hWorkBook:SaveAs(cTemPath1)
   hWorkBook:Close() // Close
   hWorkBook := hWorkBooks:Open(cTemPath1) // Open again (not problem)
   hWorkBook:Close(.f.) // Close without saving (not problem)
   // Here will problem. Put error handling.
   bSaveHandler := errorblock( { |x| break(x) } )
   BEGIN SEQUENCE
      hWorkBook := hWorkBooks:Open(cTemPath1, 0, .t. ) // Open again in readonly mode (without update external link)
   RECOVER USING oError
      * This is the code to execute if the above code fails
      MsgStop( oError:Description + " " + oError:Operation  , "Report Error:" )
      MsgInfo("Try to open again", "Trying")
   END
   errorblock( bSaveHandler )
   BEGIN SEQUENCE
      hWorkBook:Close(.t. , cTemPath2) // Close and save the workbook in new name
   END
   hExcelApp:Quit()
	MsgInfo("Click OK to quit", "Finish")
Kek
Agil Abdullah
Re: Mapping of Open and Close command
Post by Agil Abdullah »
Hi Tiempei,
I am following this topic...
Thanks.
Programmer Never Surrender
Clip2Mania
Post by Clip2Mania »
Will test this.
dhaine_adp
Post by dhaine_adp »
Hello Tiempei,
Example 2, NOT OK.
Code:
hExcelApp:Quit()
I think the best way to address the problem is by doing the straight forward approach (code not tested):
   hWorkBook:SaveAs(cTemPath2)
That simplifies the handling, and ensures backward and forward MS Excel compatibility. IMHO, that minimized the risk of recoding to support the current, previous and new Excel versions.
Danny
Danny
Manila, Philippines
