PRN2PDF
PRN2PDF
When we have old systems in Clipper, was very common to create a printing or text files (PRN or TXT). I remember I had used a third party program to convert to PDF files.
Following example would be usefull for that propose which accepts in command line (Prompt at DOS command) or just execute without any parameter.
I shall make some another improvements with some more options. This is working with Epson and HP internal printer commands (ESC command).
I hope to contribute to assist in learning and you enjoy this example. :D
EpsonPDF.rar
(60.79 KiB) Downloaded 725 times
I intend to improve in line command options to add more parameters just to allow with:
1. No_Load PDF
2. Set nMargin
3. Set nTop
4. Set LandScape/Portrait
5. Force Epson or HP ESC commands
P.S. I have forgotten to thank to Fernando from PCToledo forum whos has contributed and I adapted and made some more implementations to our community. Thanks Fernando, thanks amigo Toledo for this opportunity.
Re: PRN2PDF
Nece Utility
Thank you Pablo for sharing
tonton2
Re: PRN2PDF
Post by tonton2 »
:o c'est vraiment du bon travail Merci
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
quartz565
Re: PRN2PDF
Post by quartz565 »
Thank you Pablo!
Nikos.
os: Windows Server 2019 - 64
Re: PRN2PDF
Gracias por compartir!
Agil Abdullah
Re: PRN2PDF
Post by Agil Abdullah »
Many Thanks.... I tried and it worked well.
What I love this forum is... Everyday I find new thing to learn & improve my skill+knowledge.
Programmer Never Surrender
Re: PRN2PDF
Thanks Pablo!
PRN2PDF
Thank you guys for your interest. :D
Sometimes same print command is defined in more than one way.
For example: CHR(27)+"P" and CHR(18) which makes to turn normal size of font.
So to attend this, PRN2PDF supports many other equivalent of same command by considering nested element of an array.
Some other print commands were added and user options in form for GUI.
Prn2Pdf (Executable file).rar
(1.06 MiB) Downloaded 675 times
PRN2PDF.rar
Source files
(4.81 KiB) Downloaded 545 times
Agil Abdullah
Re: PRN2PDF
Pablo,
Again, Thanks for sharing.
Awating for some new things you could share for us.
