Some Elaboration on Excel functions (OLE)
Clip2Mania
Post by Clip2Mania »
I found some good information on this forum and in the Samples (C:\hmg.3.3.1\SAMPLES\Controls\OLE)
However, it is not always easy to translate the Excel Object Model to HMG. In the code below you will find some more elaborate examples
on how to open a sheet, select a worksheet, save a sheet, write in tabs, change color, pattern & borders of cells, etc.
You can rem out/in any part of code you like.
Maybe it can be useful for you too!
#include "excel.ch"
local cb1,b1
DEFINE WINDOW Main ;
   AT 90,90;
   WIDTH 300;
	 HEIGHT 200;
	 TITLE "Test Excel OLE";
   MAIN
   @ 10, 10 BUTTON b1 CAPTION "Ole Excel" ACTION ExcelSum()
 Main.Center
 Main.Activate
function ExcelSum()
   LOCAL cExePath := HB_FNameDir(ExeName())
   local oExcel, oSheet
   local row := 1
   oExcel:=CreateObject("Excel.Application")
	 // Alternative: Open Existing Excelsheet from default Excel save location
	 // oExcel:WorkBooks:Open("Demo")
   if Ole2TxtError() != "S_OK"
      MsgStop("Excel is not available - Error "+Ole2TxtError(), "Warning")
      return nil
   oExcel:WorkBooks:Add()
   oSheet:=oExcel:ActiveSheet()
    // MsgBox(oExcel:Activesheet:Name)    // Show current worksheet name
   oSheet:Name:="Test"                         // Give worksheet a name
   oSheet:Cells(row,1):Value := "Just a sum :"
   row := row + 1
   frow := row
   for i := 1 to 15
         oSheet:Cells(row,1):Value := i
         oSheet:Cells(row,3):NumberFormat:="##########0.00"
         row := row + 1
   next i
	 oSheet:Cells(row,1):Formula:="=sum(A"+alltrim(str(frow,5,0))+":A"+alltrim(str(row-1,5,0))+")"
	 oSheet:Cells(row,1):NumberFormat:="##########0.00"
         oSheet:Cells(row,1 ):Font:Bold := .T.        	   // Make a Cell bold
	 oSheet:Rows(1):Font:Bold:=.T.                        // Make first row Bold
	 oSheet:Cells(row,1):Font:Color:=RGB(255,0,0)    // Set last row to color red
	 // Border functions
	 oSheet:Cells(row,1):Borders:Color:=RGB(0,0,255)       // Blue border around a cell
	 oSheet:Cells(row,1):Borders:Weight:=xlThick             // Border thickness
	 oSheet:Range("A10"):Borders(xlEdgeBottom):LineStyle:=xlDouble     // Make Bottom Border double
	 oSheet:Range("A10"):Borders(xlEdgeBottom):Color = RGB(0,255, 0)  // Change bottom border color to green
	 oSheet:Range("A4:A6"):BorderAround(xlContinuous,xlMedium,,1)      // Draw border around range of cells
	 // Syntax: BorderAround(LineStyle, Weight, ColorIndex, Color)
	 // You must specify either ColorIndex or Color, but not both.
	 // Color & Pattern functions
	 oSheet:Range("A1"):Interior:Pattern:=xlPatternLightDown	// add a Pattern to a cell
	 oSheet:Range("A3"):Interior:ColorIndex:=6    			// Colors the cell yellow
	 // Cell comment
	 oSheet:Range("A3"):AddComment("This cell is yellow")       // Add comment to a cell
	 oSheet:Columns( 1 ):AutoFit()                                      // Does an autofit of a column.
        // Select another sheet
	 oExcel:WorkSheets("Sheet2"):Cells(1,1):Value:="Text in sheet 2"   // Write something directly in Sheet 2
	 // or alternatively, you could select sheet 2, then activate it & write in it.
	 // oExcel:Worksheets("Sheet2"):Activate() 				  // Activate second sheet
	 // oSheet:=oExcel:ActiveSheet()
	 // oSheet:Cells(1,1):Value:="Something"
	 oSheet:Range("B1"):Select()
         oExcel:Visible := .T.
	 //-> Save the sheet in the indicated location & stays open
	 // oSheet:SaveAs(cExePath+"Demo")  // if executed more than once and you say 'no' to overwrite,
	                                                    //  will raise error @ next command
	 //-> Show the name of the saved workbook
	 // MsgBox(oExcel:ActiveWorkbook:Name)
	 //->Propose to Close a workbook (it will ask for confirmation)
	 // If you put 2 previous commands after the other and execute for the first time, Exel will be closed.
	 // oExcel:Workbooks:Close()
return nil
When experimenting with Excel-functions one can encounter 2 errors:
"no exported value": combination x:y:z  not possible
"argument error":  command is correct, but form of argument is incorrect
ExcelTest.zip
(2.51 KiB) Downloaded 1010 times
Re: Some Elaboration on Excel functions (OLE)
Wonderful and very useful. Thank you very much.
Gracias por la inf.
Hola Clip2Mania,
Compile tu demo y me da este error:
Hay que tener alguna consideración al respecto?
Clip2Mania
Hi Javier,
What version of Excel are you using?
I've tested this on Excel 2010 & Win 7 Pro 32 bits and it's working just fine.
The "Worksheets("name") function has not changed in later version, as I recall...
Working in Xp and Excel-2007
Clip2Mania
Working in Xp and word-2007
Word? I guess you mean "Excel"? :)
The Excel 2007 Object Model already has the concept of Worksheets. I cannot test it (because I don't have Excel 2007 nor WinXP), but you can try & change Worksheets("Sheet2") simply by Worksheets(2), as far as I can see from the Excel 2007 "Worksheets" Object
Yo estoy utilizando Win7 32 bits y Office 2010 y HMG3.3.1
Y me da error como lo mostre en el anterior post.
Clip2Mania
:idea: When you open Excel manually, does it has "Sheet1","Sheet2","Sheet3" on the bottom?
If you don't have an English version of Office, you have to replace "Sheet2" with your "local language version" of it...
LOUIS
Post by LOUIS »
Ya lo probé, y Sí funciona en XP y Excel 2007
Sólo hice 2 cambios:
A la fórmula sum le agregué la letra A, y
cambié Sheet2 por Hoja2
Thanks for share Cilp2mania ;)
