ToolTip with Title and Icones
I came here to share with you this ressource given by Alexandre Simões posted at PCToledo forum and I adapted to HMG:
#define WM_USER                 0x0400
#define TTM_SETTITLEA           (WM_USER + 32)
#define TTM_SETTITLEW           (WM_USER + 33)
#define TTI_NONE                0
#define TTI_INFO                1
#define TTI_WARNING             2
#define TTI_ERROR               3
// Large icons only on Vista or higher
#define TTI_INFO_LARGE          4
#define TTI_WARNING_LARGE       5
#define TTI_ERROR_LARGE         6
Function Main()
SET TOOLTIPSTYLE BALLOON
// SET TOOLTIPSTYLE STANDARD
DEFINE WINDOW Form_1 AT 219 , 253 WIDTH 478 HEIGHT 186 ;
	TITLE "ToolTip with Title and Icone" Main
	DEFINE BUTTON Button_1
	    ROW    40
	    COL    20
	    WIDTH  100
	    HEIGHT 28
	    ACTION Nil
	    CAPTION "Print option"
	    FONTNAME "Arial"
	    FONTSIZE 9
	    TOOLTIP "Click here to start printing"
	END BUTTON
	DEFINE BUTTON Button_2
	    ROW    80
	    COL    20
	    WIDTH  100
	    HEIGHT 28
	    ACTION Nil
	    CAPTION "Cancel option"
	    FONTNAME "Arial"
	    FONTSIZE 9
	    TOOLTIP "Click here to cancel"
	END BUTTON
CENTER WINDOW Form_1
ToolTipChng("Form_1", "Preview of report", TTI_INFO)
ACTIVATE WINDOW Form_1
Function ToolTipChng(cForm, cTitle, nIconIndex)
hb_Default(@cTitle,"")
SendMessageString(GetFormToolTipHandle(cForm),TTM_SETTITLEW, nIconIndex, cTitle)
#pragma BEGINDUMP
#define COMPILE_HMG_UNICODE
#include <HMG_UNICODE.h>
#include <windows.h>
#include "hbapi.h"
HB_FUNC( SENDMESSAGESTRING )
   #ifdef UNICODE
      LPWSTR lpWCStr = HMG_parc(4) ;
   #else
      LPWSTR lpWCStr = (LPCWSTR) ( hb_parc(4) == NULL ) ? NULL : hb_mbtowc( (const char *) hb_parc(4) ) ;
   #endif
   hb_retnl( ( LONG ) SendMessage( ( HWND ) hb_parnl( 1 ), ( UINT ) hb_parni( 2 ), ( WPARAM ) hb_parnl( 3 ), ( LPARAM ) ( LPCWSTR ) lpWCStr ) );
#pragma ENDDUMP
This code could be adapted also to work in ANSI mode for replacing TTM_SETTITLEW by TTM_SETTITLEA.
You can also change TOOLTIPSTYLE BALLOON with STANDARD and icon style by choosing TTI_NONE, TTI_INFO, TTI_WARNING, TTI_ERROR, TTI_INFO_LARGE, TTI_WARNING_LARGE and TTI_ERROR_LARGE :!:
I hope you enjoy it :)
Re: ToolTip with Title and Icones
Gracias por compartir Pablo César, lo probaremos...
Muy bueno la adaptacion Pablo , gracias por compartir
Gracias Pablo César por compartir!
Qué bueno que les hayan gustado. :D
Si olvidar que tambien se puede cambiar los colores del ToolTip, como por ejemplo:
SET TOOLTIPBACKCOLOR {255,255,0}
Y se podria cambiar el color de las fuentes con:
#define TTM_SETTIPTEXTCOLOR     (WM_USER + 20)
Local nHndTT := GetFormToolTipHandle(cForm)
SendMessage( nHndTT, TTM_SETTIPTEXTCOLOR, RGB(0,92,233), 0 )                    // Só funciona sem o windows.manifest
SendMessageString(nHndTT,TTM_SETTITLEW, nIconIndex, cTitle)
Excelente Pablo César!, en cuanto formatie mi PC pruebo los demos!
Gracias por compartir :)
Good participation, thanks :)
Thank you Pablo César for sharing
Very good Pablo.
Hola Pablo César
He encontrado esta rutina de Marcos Antonio Gambeta
es muy parecida.
*--------------------------- TOOLTIP ----------------------------*
*--------- Rutina cedida  Por Marcos Antonio Gambeta ------------*
#define WM_USER             0x400
#define TTM_SETTITLE       (WM_USER + 32)
#define TTI_NONE                0
#define TTI_INFO                1
#define TTI_ERROR               3
Function Main()
       ROW    40
       COL    20
       WIDTH  100
       HEIGHT 28
       ACTION Nil
       FONTNAME "Arial"
       FONTSIZE 9
   END BUTTON
       ROW    80
       COL    20
       WIDTH  100
       HEIGHT 28
       ACTION Nil
       FONTNAME "Arial"
       FONTSIZE 9
   END BUTTON
*---------------------------------------------   TOOLTIP   --------------------------------------------*
       SendMessageString( GetFormToolTipHandle ("Form_1"), TTM_SETTITLE, TTI_INFO, "Preview of report" )
#pragma BEGINDUMP
#include "hbapi.h"
HB_FUNC ( SENDMESSAGESTRING )
  hb_retnl( (LONG) SendMessage( (HWND) hb_parnl(1), (UINT) hb_parni(2), (WPARAM) hb_parnl(3), (LPARAM) (LPSTR) hb_parc(4) ) );
#pragma ENDDUMP
Mustafa :)
