HMG IDE 2.8.6a
HMG IDE 2.8.6a
Harbour MiniGUI IDE 2.8.6a:
English:
- Fixed: Main window not focused at program startup (introduced in 2.8.6).
Español:
- Solucionado: Ventana principal no enfocada al iniciar el programa (
introducido en 2.8.6).
Download/Descarga: http://harbourminigui.googlepages.com
Re: HMG IDE 2.8.6a
Thanks as usual Roberto.
Re: HMG IDE 2.8.6a
Thanks a lot Roberto
Best Regards
Re: HMG IDE 2.8.6a
I think, there is another problem with IDE yet.
Try to define simple main window with one button with caption "&Button"
Then compile program and try to press Alt-B - nothing happens till you will press any arrow key or TAB or Shift-TAB.
This situation exist in all of my projects - is it OK?
Best regards, Marek
Re: HMG IDE 2.8.6a
I've got one wish with installation process of IDE - could install program doesn't write standard config file? I'm using notepad++ as my editor and with every new version I need do change preferences....
Marek
Re: HMG IDE 2.8.6a
I'm trying to define GRID via IDE with CellNavigation = .T. Everything seems to be OK, but when I open window program generates runtime error:
little thasaurus:
Nieprawidłowy = incorrect
Nieprawidłowa liczba argumentów = incorrect number of arguments
Error BASE/1068 Nieprawidłowy argument: Nieprawidłowa liczba argumentów</p><BR>
Called from _SETVALUE(476)
<BR>
Called from _DEFINEGRID(326)
<BR>
Called from USTAWFILTR(246)
what's going on?
Marek
EDIT:
I found that after saving definition of window I need manually edit FMG file and change initial value of GRID declared with CellNavigation from number to array.
During building grid with IDE, property VALUE is NUMBER defined with spinner, I think it must be changed to textbox, when we can write array like that: {0,0}.
Sorry, for my bad English, but I hope, Roberto, you will know what's going on.
Marek
Re: HMG IDE 2.8.6a
mol wrote:I think, there is another problem with IDE yet.
Best regards, Marek
If the problem arises at program execution the problem is in the HMG library, not the IDE.
As I've said in a previous post, I've identified the problem and I'll publish soon.
Re: HMG IDE 2.8.6a
I think, problem with buttons isn't so impartant - most of users are using mouse.
But I have a friend who is blind - I want to write application for him with buttons with hotkeys - and in this case this problem grows up...
More important is problem with IDE and value property for grid with cellnavigation.
Marek
Re: HMG IDE 2.8.6a
mol wrote: EDIT:
Marek
You are right. I've forgot that initial value for by cell grid should be an array.
I'll try to fix ASAP.
Again: Thanks for the report.
Re: HMG IDE 2.8.6a
mol wrote:I'm trying to define GRID via IDE with CellNavigation = .T. Everything seems to be OK, but when I open window program generates runtime error:
little thasaurus:
<BR>
<BR>
what's going on?
Marek
EDIT:
Marek
Again: You are right about that 'Value' property for Grid. IDE should allow entering an array for it when 'CellNavigation' is .t.
But, even when the initial value for the grid is numeric (not an array) there is not runtime error because 'Value' property check data type and if it is invalid, ignores the whole operation and Grid is initiated without cells selected (equivalent to {0,0}).
So... please, post a sample showing the problem.
