Has anyone built anything with 64 bit version yet?
serowe
Post by serowe »
OK so I am still coming to grips with the whole HMG/Harbour development cycle - building apps in 32 bits are now (sort of ) OK - in that I can generate code, compile and run an application.
However - trying to do the same with *any* code under 64 bit (and HMG.3.3.0) continually generates the following errors for me:
Harbour 3.2.0dev (r1306211258)
Copyright (c) 1999-2013, http://harbour-project.org/
c:/hmg.3.3.0/mingw/bin/../lib/gcc/mingw32/4.6.2/../../../../mingw32/bin/ld.exe: cannot find -lhbmemio
c:/hmg.3.3.0/mingw/bin/../lib/gcc/mingw32/4.6.2/../../../../mingw32/bin/ld.exe: cannot find -lhbmisc
c:/hmg.3.3.0/mingw/bin/../lib/gcc/mingw32/4.6.2/../../../../mingw32/bin/ld.exe: cannot find -lhbsqlit3
c:/hmg.3.3.0/mingw/bin/../lib/gcc/mingw32/4.6.2/../../../../mingw32/bin/ld.exe: cannot find -lsddodbc
c:/hmg.3.3.0/mingw/bin/../lib/gcc/mingw32/4.6.2/../../../../mingw32/bin/ld.exe: cannot find -lhbodbc
c:/hmg.3.3.0/mingw/bin/../lib/gcc/mingw32/4.6.2/../../../../mingw32/bin/ld.exe: cannot find -lhbhpdf
c:/hmg.3.3.0/mingw/bin/../lib/gcc/mingw32/4.6.2/../../../../mingw32/bin/ld.exe: cannot find -llibhpdf
c:/hmg.3.3.0/mingw/bin/../lib/gcc/mingw32/4.6.2/../../../../mingw32/bin/ld.exe: cannot find -lhbzebra
hbmk2[tutor08]: Error: Running linker. 1
gcc.exe c:/Temp/hbmk_nh6dqh.dir/tutor08.o c:/Temp/hbmk_nh6dqh.dir/hbmk_lbrpzy.o C:/hmg.3.3.0/SAMPLES/Basics/TUTORIAL/_temp.o    -Wl,--nxcompat -Wl,--dynamicbase -mwindows -Wl,--start-group -l"hmg-64" -l"crypt-64" -l"edit-64" -l"editex-64" -l"graph-64" -l"ini-64" -l"report-64" -l"hfcl-64" -l"hbvpdf-64" -lmsvfw32 -lvfw32 -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lhbodbc -lodbc32 -lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet   -Wl,--end-group -otutor08.exe  -Lc:/harbour/lib -Lc:/harbour/lib/3rd/win/mingw -L"c:/hmg.3.3.0/lib-64"
Obviously there is something I haven't set up properly BUT with so little information available about setting up anything within Harbour (or HMG) it becomes a hit and miss effort followed by long, fruitless Google searches.
I should point out that I *can* compile and run code from the SAMPLES folder using the Build64.bat file, so obviously the command line environment is set up OK - just not the IDE environment.
Any thoughts/help please?
Edit - I should have mentioned - this is simply using tutor08 from the hmg.3.3.0/samples folder - so nothing special about it)
Re: Has anyone built anything with 64 bit version yet?
Hola Serowe,
No yo utilizo 32 Bits, lamento no poderte ayudar, espera ayuda de los demás amigos del foro.
meneale
Post by meneale »
Hello,
as posted by Sr. Rathi, you should to install the 64bit libs to compile. Available here: site/download/Harbour-64%20and%20MinGW-64.rar
AMD Phenom II X6 1090T 3.2GHz (OverClock 3.9GHz) | Windows 8.1 Pro 64-bit
4GB DDR3 | GTX 550 Ti 1GB | MSI 880GMA-E35
serowe
Post by serowe »
I mentioned in the OP though that I *can* run and build HMG apps from the command line using the build64.bat file so, although I didn't specifically say so, I *have* installed the 64 bit libs etc. and followed the instructions in the 64bit threads as best I can.
The problem is in the HMG IDE only - although 64bit version is selected from the main menu barf, it is obviously looking for 32 bit libs and I can't find anything, in any documentation, that tells me how I can fix this. If there is another setting to be changed (path, lib setting etc although these have already been done) I can't find it stated anywhere.
Steed
Post by Steed »
I Just compile some examples in Hmg 64 Bits, i was having the same issue and after think I realized that I have to build the libraries in 64 Bits, Just Run: _BuildAllLib64 and all will be ok
Ed
