Anyway, thank you very much for willing to investigate. Really appreciate itYou are right, my conversion method not convenient to your needs
Erik
Convert Unicode 32 string to ANSI
PROCEDURE Main
cANSI := Uni322ANSI( MEMOREAD( "Chanson_EAC.txt" ) )
MemoWrit( "ChansonANSI.txt", cANSI )
FUNCTION Uni322ANSI( cUni32Str ) // Convert Unicode 32 string to ANSI
RETURN ( SUBSTR( STRTRAN( cUni32Str, CHR(0), '' ), 3 ) )
Convert Unicode 16 string to ANSI
PROCEDURE Main
cANSI := Uni162ANSI( MEMOREAD( "Chanson_EAC.txt" ) )
MsgBox( HMG_ANSI_TO_UNICODE ( cANSI ) )
* MemoWrit( "ChansonANSI.txt", cANSI )
FUNCTION Uni162ANSI( cUni16Str ) // Convert Unicode 16 string to ANSI
RETURN ( SUBSTR( STRTRAN( cUni16Str, CHR(0), '' ), 3 ) )
I'm glad that you like itClip2Mania wrote:Perfect! Unmistakenly the shortest working conversion in this post!
And I learned a lot of new functions which I didn't even knew they were part of Harbour
Hi KanaKana wrote:I have code where I write XML file from DBF with
nHandle := FCreate( xmlfile, 0 ) )
FWRITE
FClose(
This function save ANSI XML file
I don't want convert file with notepad.exe or notepad++ from ANSI to UTF8
Is it posible to save UTF8 file from code?
esgici wrote:
Hi Kana
Last version of an ANSI to UT8 file conversion utility is here.
I haven't any experience on .xml file, so I'm not sure this is convenient for your needs.
Please try and inform us about result.
Happy HMG'ing
