Is this a bug ?
Is this a bug ?
Hi All
I'm very desolated and ashamed with this post.
- I had already sent "clean" report on 2.8.6
- This subject introduced by my "spinners" sample
- It's not correct way changing value of controls by interactive manner
- Roberto is very struggled with this "double execution" problem
Nonetheless I feel must inform. Because in new HMG-Ex version ( applied all new Grid features ), the spinner sample works no problem :((((
Now our problem is : when spinners activated (added to test sample) up and down arrow key causing double skip on rows.
This occurs after first row. That is: down arrow select second row from first, but fourth (not third) from second.
The worst is this isn't new, exists since beginning.
Again, I am very sorry.
Best Regards
Re: Is this a bug ?
Esgici,
Please, could be you so kind to post the sample again in this thread (I have not the file anymore).
Re: Is this a bug ?
* MiniGUI Grid Demo
* (c) 2009 Roberto Lopez
#include "minigui.ch"
Local aRows [40] [3]
	DEFINE WINDOW Form_1 ;
		WIDTH 640 ;
		HEIGHT 400 ;
		TITLE 'Mixed Data Type Grid Test' ;
		MAIN
        ON KEY ESCAPE ACTION Form_1.Release
		DEFINE MAIN MENU
			DEFINE POPUP 'File'
				MENUITEM 'Set Value To {5,2}'	ACTION Form_1.Grid_1.Value := {5,2}
				MENUITEM 'Set Value To {0,0}'	ACTION Form_1.Grid_1.Value := {0,0}
				MENUITEM 'Get Value'		ACTION GetSelectionValue()
				MENUITEM 'Delete Item 5'	ACTION Form_1.Grid_1.DeleteItem(5)
				MENUITEM 'AddItem'		ACTION Form_1.Grid_1.AddItem({'X','X','X'})
				MENUITEM 'Delete All Items'	ACTION Form_1.Grid_1.DeleteAllItems
			END POPUP
		END MENU
		aRows [1]	:= {'Simpson','Homer','555-5555'}
		aRows [2]	:= {'Mulder','Fox','324-6432'}
		aRows [3]	:= {'Smart','Max','432-5892'}
		aRows [4]	:= {'Grillo','Pepe','894-2332'}
		aRows [5]	:= {'Kirk','James','346-9873'}
		aRows [6]	:= {'Barriga','Carlos','394-9654'}
		aRows [7]	:= {'Flanders','Ned','435-3211'}
		aRows [8]	:= {'Smith','John','123-1234'}
		aRows [9]	:= {'Pedemonti','Flavio','000-0000'}
		aRows [10]	:= {'Gomez','Juan','583-4832'}
		aRows [11]	:= {'Fernandez','Raul','321-4332'}
		aRows [12]	:= {'Borges','Javier','326-9430'}
		aRows [13]	:= {'Alvarez','Alberto','543-7898'}
		aRows [14]	:= {'Gonzalez','Ambo','437-8473'}
		aRows [15]	:= {'Batistuta','Gol','485-2843'}
		aRows [16]	:= {'Vinazzi','Amigo','394-5983'}
		aRows [17]	:= {'Pedemonti','Flavio','534-7984'}
		aRows [18]	:= {'Samarbide','Armando','854-7873'}
		aRows [19]	:= {'Pradon','Alejandra','???-????'}
		aRows [20]	:= {'Reyes','Monica','432-5836'}
		aRows [21]	:= {'Fernandez','Raul','321-4332'}
		aRows [22]	:= {'Borges','Javier','326-9430'}
		aRows [23]	:= {'Alvarez','Alberto','543-7898'}
		aRows [24]	:= {'Gonzalez','Ambo','437-8473'}
		aRows [25]	:= {'Batistuta','Gol','485-2843'}
		aRows [26]	:= {'Vinazzi','Amigo','394-5983'}
		aRows [27]	:= {'Pedemonti','Flavio','534-7984'}
		aRows [28]	:= {'Samarbide','Armando','854-7873'}
		aRows [29]	:= {'Pradon','Alejandra','???-????'}
		aRows [30]	:= {'Reyes','Monica','432-5836'}
		aRows [31]	:= {'Fernandez','Raul','321-4332'}
		aRows [32]	:= {'Borges','Javier','326-9430'}
		aRows [33]	:= {'Alvarez','Alberto','543-7898'}
		aRows [34]	:= {'Gonzalez','Ambo','437-8473'}
		aRows [35]	:= {'Batistuta','Gol','485-2843'}
		aRows [36]	:= {'Vinazzi','Amigo','394-5983'}
		aRows [37]	:= {'Pedemonti','Flavio','534-7984'}
		aRows [38]	:= {'Samarbide','Armando','854-7873'}
		aRows [39]	:= {'Pradon','Alejandra','???-????'}
		aRows [40]	:= {'Reyes','Monica','432-5836'}
		DEFINE GRID Grid_1
		    ROW             10
		    COL             10
			WIDTH           500
			HEIGHT          322
			HEADERS         {'Column 1','Column 2','Column 3'}
			WIDTHS          {100,100,100}
			ITEMS           aRows
			VALUE           { 1, 1 }
			ALLOWEDIT       .T.
			CELLNAVIGATION  .T.
			ONCHANGE { ||  IF( ( _IsControlDefined( "spnRow", "Form_1" ) .AND. ;
                                 _IsControlDefined( "spnCol", "Form_1" ) ) ,;
                                 ( aCurValue := this.value,;
                                 SetProperty( "Form_1", "spnRow", "Value", aCurValue[ 1 ] ),;
                                 SetProperty( "Form_1", "spnCol", "Value", aCurValue[ 2 ] ) ), '' ) }
		END GRID // Grid_1
        @ 13, 520 LABEL lblRow WIDTH 50 VALUE "Row No:"
        @ 53, 520 LABEL lblCol WIDTH 50 VALUE "Col No:"
		DEFINE SPINNER spnRow
		   ROW   10
           COL   580
           WIDTH 50
           RANGEMIN 1
           RANGEMAX LEN( aRows )
           VALUE 1
           ONCHANGE { || aCurValue := GetProperty( "Form_1", "Grid_1", "Value" ),;
                         aCurValue[ 1 ] :=  this.Value,;
                         SetProperty( "Form_1", "Grid_1", "Value", aCurValue ) }
        END SPINNER // spnRow
		DEFINE SPINNER spnCol
		   ROW   50
           COL   580
           WIDTH 50
           RANGEMIN 1
           RANGEMAX 3
           VALUE 1
                         aCurValue[ 2 ] :=  this.Value,;
        END SPINNER // spnCol
 	Form_1.Grid_1.setfocus
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
Function GetSelectionValue
Local a
	a := Form_1.Grid_1.Value
	MsgInfo( Str (  a [1] ) + ' ' + Str (  a [2] ) )
Return nil
Re: Is this a bug ?
Roberto Lopez wrote:Esgici,
Some clarification:
Your sample was very useful.
From it, I've created the 'GRID_23' sample. It probes that interactively or programmatically, 'OnChange' event is executed once and the value property passed to the event is correct.
As I've said to you in another thread, IMHO the problem with your original sample could be solved checking current value of the control prior to set to the same value again (yet I've not tested).
From an HMG perspective, we could do the same. This means, that _SetValue internal function, test the value passed and if is the same as current, do nothing.
Again, I've not tested, so, this is only a theory.
Moreover, we should consider the implications that a change on _SetValue could have on current applications.
Since you mentioned HMG extended, perhaps, Grigory be informed about this issue and can help us.
Re: Is this a bug ?
esgici wrote:
* MiniGUI Grid Demo
[/quote]
Thanks.
I'll work on it.
Re: Is this a bug ?
Hi Roberto
Thanks you very much.
Now I feel less depressed :)
Best Regards
Re: Is this a bug ?
Well...
A 'good' person should not say 'I told you' but...
I told you :)
* MiniGUI Grid Demo
      WIDTH 640 ;
      HEIGHT 400 ;
      MAIN
      DEFINE MAIN MENU
         DEFINE POPUP 'File'
         END POPUP
      END MENU
      DEFINE GRID Grid_1
          ROW             10
          COL             10
         WIDTH           500
         HEIGHT          322
         ITEMS           aRows
         VALUE           { 1, 1 }
         ALLOWEDIT       .T.
         CELLNAVIGATION  .T.
         ONCHANGE 	GridChange()
      END GRID // Grid_1
         ROW   10
           COL   580
           WIDTH 50
           RANGEMIN 1
           VALUE 1
           ONCHANGE 	SpinnerRowChange()
         ROW   50
           COL   580
           WIDTH 50
           RANGEMIN 1
           RANGEMAX 3
           VALUE 1
           ONCHANGE 	SpinnerColChange()
Local a
Return nil
Procedure GridChange
Local aCurValue
	IF	_IsControlDefined( "spnRow", "Form_1" )  .AND. ;
		If aCurValue [1] <> GetProperty( "Form_1", "spnRow", "Value")
		EndIf
		If aCurValue [2] <> GetProperty( "Form_1", "spnCol", "Value")
		EndIf
	EndIf
Procedure SpinnerRowChange
Local aCurValue
	If aCurValue[ 1 ] <>  this.Value
	EndIf
procedure SpinnerColChange
Local aCurValue
	If aCurValue[ 2 ] <>  this.Value
	EndIf
Re: Is this a bug ? (An interesting debate)
Now, that the 'problem' is identified we must to make a decision.
- Should internal HMG funtion _SetValue() be changed to test current value prior to take action?
It could esily done, but:
- Does that impact on current code, breaking backwards compatibility?
I'm listening...
Re: Is this a bug ?
Roberto Lopez wrote: A 'good' person should not say 'I told you' but...
I told you :)
Personally, I'm not a "good" person; only a "sassy" student !
So I can say only : "Yes sir, you have already told me !"
Best Regards
Roberto Lopez wrote: - Should internal HMG funtion _SetValue() changed to test current value prior to take action?
IMHO, yes.
IMHO, no.
Best Regards
