Autoscroll to bottom in EDITBOX
Clip2Mania
Post by Clip2Mania »
I'm "filling up" an editbox (with vertical scrollbar) with data, which is over a hundred lines long, refreshing the display after every line that I add. The default behaviour is that you only see the x number of first lines (depending on height you defined).
Is there a way to have the editbox automatically scroll down when you add lines beyond the height of the editbox?
Re: Autoscroll to bottom in EDITBOX
Did you try this?
form.editbox.caretpos := len( form.editbox.value )
Clip2Mania
Mr Rathinagiri,
Did you try this?
The caret-position is indeed at the end, but the editbox doesn't scroll to the bottom... :(
Adding piece of code attached.
Scroll.zip
(1.32 KiB) Downloaded 747 times
Clip2Mania wrote: Adding piece of code attached.
Thanks for your sample code.
Please take a look for the working updated sample below. 8-)
#define CRLF chr(13)+chr(10)
function main()
local cSMsg:="Do Something"
DEFINE WINDOW MainForm;
	AT 90,90;
	WIDTH 780;
	HEIGHT 550;
  TITLE 'Inventory Renamer';
	MAIN;
	NOSIZE
	DEFINE MAIN Menu of MainForm
		DEFINE POPUP "File"
			MENUITEM "Select From List" ACTION DoList()
			SEPARATOR
			MENUITEM "Exit" ACTION ThisWindow.Release
		END POPUP
	END MENU
	DEFINE STATUSBAR
		STATUSITEM cSMsg
		CLOCK
		DATE
	END STATUSBAR
	@ 005,005 EDITBOX Edit_1            ;
      WIDTH 760 HEIGHT 425 ;// READONLY    ;
			VALUE " ";
	    FONTCOLOR {000,000,255}           ;
		FONT "Courier New" SIZE 10
	@ 440, 665 BUTTON bn_Go;
		OF MainForm;
		CAPTION "Rename";
		ACTION MsgInfo("Go!")
	@ 443, 10  LABEL lb_Stat ;
	  VALUE " ";
		WIDTH 650;
		TRANSPARENT
MainForm.Center
MainForm.Activate
return NIL
function Dolist()
local cList, n, nTokens
local cStr:=""
if !file("list.txt")
   MsgInfo("Didn't find a list.txt")
	 return NIL
cList:=memoread("list.txt")
nTokens:=numtoken(cList,CRLF)
MsgInfo("List is "+str(len(cList))+" bytes long"+ CRLF + str(nTokens)+" lines in the list")
For n := 1 to nTokens
  cDir:=token(cList,CRLF,n)
  cStr:=cStr+"File "+strzero(n,3)+" "+cDir+CRLF
  MainForm.Edit_1.Value:=cStr
  MainForm.Edit_1.Caretpos := len(MainForm.Edit_1.Value)-1
  do events
Next
INSERT_CTRL_END()
return NIL
function strzero(nNum,nLen)
return right(replicate("0",nLen)+ltrim(token(str(nNum),".",1)),nLen)
#pragma BEGINDUMP
#include <windows.h>
#include "hbapi.h"
HB_FUNC( INSERT_CTRL_END )
	keybd_event(
		VK_CONTROL,	// virtual-key code
		0,		// hardware scan code
		0,		// flags specifying various function options
		0		// additional data associated with keystroke
	keybd_event(
		VK_END	,	// virtual-key code
	keybd_event(
		KEYEVENTF_KEYUP,// flags specifying various function options
#pragma ENDDUMP
Hope that helps :idea:
Clip2Mania
Unfortunately, don't know any C myself ... :(
Thanks for this solution Grigory!
Agil Abdullah
Post by Agil Abdullah »
For me, it's very useful, coz not only reading text/memo but also showing line numbers at every line.
Thanks Gregory.
Programmer Never Surrender
Thanks Gregory !
Gracias Gregory Filatov,
Excelente ejemplo! :)
Clip2Mania wrote:Unfortunately, don't know any C myself ... :(
Hi Erik
I agree with you :arrow:
We need something like HMG_KeyPut() same as HB_KeyPut() :?
Happy HMG'ing :)
