Incremental Search in BROWSE
- Clip2Mania
I would like to implement an incremental search in a BROWSE.
E.g. When typing a character, 'seek' to the first occurrence in the indexed table - when typing a second character, seeking further in the index, and so on. "Clearing" the seek-string by means of a Ctrl-Key combination.
A bit like the example GridIncrementalSearch in \SAMPLES\Controls\Grid.
Is this possible in a BROWSE ? How can I do that?
Re: Incremental Search in BROWSE
You can do it with events.
I can post you my functions, but have no time to translate it to English (code is rather "clear")
If you are interested in it, please post.
a piece of code:
define Search textbox
define event for keys pressed in focused BROWSE:
Event handlie function:
And, proper search function, triggered by changes in Search textbox:
DEFINE BROWSE B_Towary
parent OknoTabTowarow
ROW 20
COL 10
WIDTH 900
HEIGHT 370
VALUE Nil
WIDTHS aLocalWidths
HEADERS aLocalHeaders
WORKAREA towary
FIELDS aLocalFields
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE OknoSzybkaTabelaTowarow_AktualizujPodglad()
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONDBLCLICK if(JakoSlownik, OknoSzybkaTabelaTowarow_ZwrocKodTowaru(), NIL)
MULTISELECT .F.
ALLOWEDIT .F.
ALLOWAPPEND .F.
ONHEADCLICK {{||ZmienKluczTowaru(1)},{||ZmienKluczTowaru(2)},{||ZmienKluczTowaru(3)},{||ZmienKluczTowaru(4)}}
ALLOWDELETE .F.
HELPID Nil
VALID Nil
VALIDMESSAGES Nil
LOCK Nil
VSCROLLBAR .T.
DYNAMICBACKCOLOR aLocalBackColors
DYNAMICFORECOLOR Nil
INPUTMASK Nil
FORMAT Nil
WHEN Nil
INPUTITEMS Nil
DISPLAYITEMS Nil
BACKCOLOR NIL
FONTCOLOR NIL
IMAGE Nil
JUSTIFY aLocalJust
NOLINES .F.
READONLYFIELDS Nil
HEADERIMAGES Nil
END BROWSE
DEFINE TEXTBOX T_Wyszukaj
ROW 498
COL 130
WIDTH 240
HEIGHT 30
FONTNAME "Arial"
FONTSIZE 12
TOOLTIP "Type characters to search..."
ONCHANGE WyszukajTowar()
ONGOTFOCUS NIL
ONLOSTFOCUS Nil
FONTBOLD .T.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER OknoTabTowarow.B_Towary.SetFocus
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .F.
DISABLEDBACKCOLOR Nil
DISABLEDFONTCOLOR Nil
CASECONVERT UPPER
BACKCOLOR NIL
FONTCOLOR {255,0,0}
INPUTMASK Nil
FORMAT Nil
VALUE ""
END TEXTBOX
CREATE EVENT PROCNAME WyszukiwanieWTabeli('OknoTabTowarow', 'B_Towary','T_Wyszukaj', 'WyszukajTowar()') HWND OknoTabTowarow.B_Towary.HANDLE MSG WM_CHAR
Function WyszukiwanieWTabeli
param cNazwaOkna, cNazwaTabeli, cNazwaPolaWyszukaj, cFunkcjaSzukajaca
STATIC flag := .F.
LOCAL hWnd, ch
local lFound := .f.
local cCzegoSzukac := ""
if flag == .t.
return nil // avoid re-entry
flag := .T.
ch := HMG_GetLastCharacter(@hWnd)
IF hWnd == GetControlHandle (cNazwaTabeli,cNazwaOkna)
cCzegoSzukac := GetProperty(cNazwaOkna,cNazwaPolaWyszukaj,"Value")
if (asc(ch)>31 .and. asc(ch)<128) .or. at(upper(ch),"ĄĆĘŁŃÓŚŻŹ")>0
HMG_CleanLastCharacter(.t.) // avoid re-entry
cCzegoSzukac += HMG_Upper(ch)
hPolaWyszukaj := GetControlHandle (cNazwaPolaWyszukaj,cNazwaOkna)
SetWindowText(hPolaWyszukaj, cCzegoSzukac)
lFound := &cFunkcjaSzukajaca
DoMethod(cNazwaOkna, cNazwaTabeli,"SetFocus")
if asc(ch) == 8 // backspace
cCzegoSzukac := left(cCzegoSzukac,max(len(cCzegoSzukac)-1,0))
HMG_CleanLastCharacter() // avoid re-entry
flag := .F.
//Return if(lFound,1,NIL)
Return 1
function WyszukajTowar
local cTekstSzukany := '', cKodSzukany := ''
local nOrder := towary->(Indexord()), i, lCyfrowy := .f., lFound := .f., sel := select()
local nIndeksTowarow := 5
//local nOdszukanyIndeks := 1
// czasem przy złej kolejności kontrolek trzeba sprawdzić, czy już można działać na kontrolce
private lAktywneSzukanieTowarow := .t.
cOkno := ThisWindow.name
if type("nOdszukanyIndeks") <> "N"
private nOdszukanyIndeks := 1
if IsControlDefined(R_IndeksTowarow, &cOkno)
nIndeksTowarow := GetProperty(cOkno, "R_IndeksTowarow","Value")
if !IsControlDefined(T_Wyszukaj,&cOkno)
return
if empty(cTekstSzukany := upper(GetProperty(cOkno,"T_Wyszukaj","Value")))
return
select("towary")
if nIndeksTowarow == 5
for i:=1 to len(cTekstSzukany)
lCyfrowy := isDigit(substr(cTekstSzukany,i,1))
if !lCyfrowy
exit
next i
if lCyfrowy
if len(cTekstSzukany)<=len(towary->towar)
towary->(DBSetOrder(1))
cTekstSzukany := strzero(val(cTekstSzukany),len(towary->towar))
lFound := towary->(DBSeek(cTekstSzukany,.t.))
if !lFound
// szukamy w KKresk
cTekstSzukany := GetProperty(cOkno,"T_Wyszukaj","Value")
towary->(DBSetOrder(4))
nOdszukanyIndeks := 4
if !lFound
// szukamy w symbolu
towary->(DBSetOrder(3))
nOdszukanyIndeks := 3
if !lFound
towary->(DBSetOrder(2))
if lFound
nOdszukanyIndeks := 2
if lFound
//if !lSzybkaTabelaTowarow
locate for cTekstSzukany $ nazwa
lFound := towary->(found())
if lFound
nOdszukanyIndeks := -2
//msgbox(if(lFound,"znaleziono","Nie znaleziono"))
locate for cTekstSzukany $ symbol
if lFound
nOdszukanyIndeks := -3
nOdszukanyIndeks := 0
//endif
i:= GetProperty(cOkno,"R_IndeksTowarow","Value")
towary->(DBSetOrder(i))
nOdszukanyIndeks := i
if i = 1
//cTekstSzukany := StrZero(val(cTekstSzukany),len(towary->towar))
if !lFound .and. i == 2
//MsgBox("Szukałem: "+cTekstSzukany +" w indeksie: "+str(towary->(IndexOrd()),1)+if(towary->(found())," i znalazłem", " i nie znalazłem"))
// ten fragment trzeba poprawić
// żeby sprawdzał czy początek pola z bazy jest równy temu, co szukam
do case
case nOdszukanyIndeks == 1
//lFound := towary->towar = cTekstSzukany
case nOdszukanyIndeks == 2
// rezygnuję, bo mogłem szukać po fragmencie nazwy
//lFound := cTekstSzukany == left(towary->nazwa,len(cTekstSzukany))
case nOdszukanyIndeks == 3
lFound := cTekstSzukany == left(towary->symbol,len(cTekstSzukany))
case i == 4
lFound := cTekstSzukany == left(towary->kodkresk,len(cTekstSzukany))
endcase
towary->(DBSetOrder(nOrder))
if lFound
SetProperty(cOkno,"B_Towary","Value", towary->(Recno()))
PlayBeep()
nPos := (len(GetProperty(cOkno,"T_Wyszukaj","Value"))-1)
SetProperty(cOkno,"T_Wyszukaj","Value", left(GetProperty(cOkno,"T_Wyszukaj","Value"), nPos))
SetProperty(cOkno,"T_Wyszukaj","CaretPos",nPos)
return
- Clip2Mania
Thanks Marek! I'll try this.
Still learning event handlers...
HiClip2Mania wrote:I would like to implement an incremental search in a BROWSE.
Have you ever seen this ( QuickSearch.zip ) ?
( Older and simpler
- Clip2Mania
That is a VERY nice and simple one indeed!
I derived my own "simple one" from Marek's code
Thanks also for your contribution esgici!
Then did a simple seekCREATE EVENT PROCNAME QuickSearch() HWND MainForm.br_Main.HANDLE MSG WM_CHAR
function QuickSearch()
local ch, hWnd
if asc(ch) = 8
cStr:=if(len(cStr)>1,left(cStr,len(cStr)-1),"")
cStr:=cStr+upper(ch)
if !DBSEEK(cStr,.T.)
DBSKIP(-1)
MainForm.Statusbar.Item(1):=cStr
MainForm.br_Main.Value:=recno()
MainForm.br_Main.Setfocus
return 1
- Clip2Mania
Can anybody help me what I have to change in the above code to also be able to trap the TAB and Function keys?
Thanks
(Please discard - found solution to the above changing WM_CHAR to WM_KEYDOWN)
Thanks
You can check using
if HMG_VirtualKeyIsPressed ( VK_F1 )
- Clip2Mania
Hi Rathinagiri,
I get a "Referenced, missing, but unknown function(s): MSG()" when I do that..
Something include I need to add?
Your HMG version?
